Question about Samsung ML 1710 Laser Printer
Samsung ML1710 screeching as it prints...
How do I fix this? Does it need oiling? WD 40? What???
  • 68 Answers
Get some wd-40 spray and target areas where the rollers are turning. Pull the tray out first, then look for those areas. Avoid spraying too much in one area, spray in bursts.
Posted on Sep 29, 2010
    Problem Solver:
  • 11 Answers
When this happened to me, it was because of a paper misfeed that drew a wad of sheets through the printer and into the fuser. The guides for the fuser roller were damaged, resulting in a clattering of gears. I was not able to obtain a set of replacement plastic roller guides at a reasonable price. I replaced my printer.
Posted on Aug 17, 2009
WD-40 oil
WD-40 should not have damaged your shredder if you have used it on metal parts, and though certain plastics can be melted with WD-40, probably hasn't done any damage. However WD-40 is not an oil, nor a lubricant (it is a degreasing solvent). If you want to apply a lubricant, use a light machine oil such as this: amazon.com/dp/B00200B22S. Much better.
Apr 16, 2014 | Office Equipment & Supplies
Tip
I Want My (Digital) Rights!
In 1958, the Rocket Chemical Company realized that selling WD-40 for public use as a lubricant spray could be a very profitable endeavor. Today, WD-40 widely available in hardware and discount stores. There are five delivery systems for the product: WD-40 aerosel is the traditional delivery format; the WD-40 Smart Straw is a can with a permanently attached straw; the WD-40 No-Mess Pen allows you to use the product while on the run; WD-40 bulk/non-aerosol is offered in gallon and 55-gallon containers for large jobs; and the WD-40 Big Blast provides a wider spray pattern and larger can size.
Although WD-40 has a very distinctive smell, there is nothing dangerous in the product. The odor is simply the result of a fragrance added during the manufacturing process. The primary ingredients in the product are mineral spirits, liquefied petroleum gas, and mineral oil. The exact formula of WD-40 is a highly guarded trade secret, however.
For automotive repair, WD-40 has many uses. It can drive moisture out of the high- and low-tension electrical components of a motor engine and loosen nuts or screws. If you're trying to keep your car in top shape, WD-40 is also good for restoring and cleaning padded leather dashboards in vehicles.
Around your home, WD-40 can fix noisy door hinges, keep scissors working smoothly, loosen rusted screws, stop electric fans from squeaking, and lubricate the tracks in your windows to make them easier to open. Many people also report that spraying WD-40 on hand tools is a good way to prevent rust damage. Although it seems hard to believe, WD-40 is also a great household cleaning product. It is good for removing lipstick or tomato stains from your laundry. You can use it to remove stubborn duct tape residue, clean splattered grease off your stove, keep glass shower doors free of water spots, clean stainless steel sinks, and camouflage scratches in ceramic or marble floors. WD-40 will even take oil spots off concrete driveways.
dont remember to rate this tip...
thank you !
on Aug 16, 2010 | Audio Players & Recorders
Tip
What is WD 40 ?
on Aug 14, 2010 | Price Pfister 43-OOXC Bathroom Faucet,...
Engine screeches when running. revving the motor makes it stop momentarily
Could be a belt screeching. Fan belt, A/C belt, Serpentine Belt, alternator belt, etc. Easiest way to isolate which belt is to open the hood and use your ears to see where the screeching is coming from. Left, right, front, behind the engine? Spray some WD-40 on the belt you think is making noise and if it quiets right away, then that is the belt making the noise. Either the tensioner needs adjusting or the belt needs replacing. The WD-40 does not hurt the car, it'll start screeching again in a few days when it wears off.
Sep 30, 2013 | 2005 Chevrolet Express Cargo
I need to download the printing software to my new computer for the ml1710 black ink only
http://www.samsung.com/sg/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=ML-1710
Jan 30, 2011 | Samsung ML 1710 Laser Printer
Fedders dehumidifier making high pitched noise
The fam motor bearings are dry and need oil..wd-40 with the long spray nozzle maybe the best way to get oil on the bearings... some motors are sealed and it is very dificult the get them quiet again...spray right where the shaft comes out of the motor and then lean the unit back so the oil runs into the motor and let it set for awhile..then try it...
http://www.fixya.com/support/r3877515-dehumidifier_problems_dehumidifier
heatman101
Apr 20, 2010 | Fedders A7DH65B2A Dehumidifier
Samsung printer CLP-350N wont print
Possibly a full waste toner container. I had the same problem, took pout the waste container, tilted it and tapped it to get toner away from the sensor window, and then it printed perfectly. I will empty the container ASAP before it overflows.
Jan 10, 2010 | Samsung CLP-350N Laser Printer
My Carrier Weathermaker 8000 makes a screeching sound when it first starts but quits screeching about 45 seconds later. I turned the heat down today and it quit about 2 seconds after. The blower still...
the screech is probably the condenser or exhaust fan as you guessed. And yes, a decent handi-man can fix it. Check the horsepower, RPMs,rotation,shaft size, and frame # of motor and order a new one from www.grainger.com or a local carrier dealer.
Install the new motor exactly as the old one was and wire according to the motor literature or the graphic on the side of the motor.
Use care when removming the old fan blade. a good file on the shaft and some WD-40 makes the job easier. Also a bit of patience... :-)
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 17, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Canon pixma mp780 load squeals when paper returns for duplex printing
Remove the duplex unit, there is a bundle of gears in the back of it on the side. Get grease if you have it, otherwise you can use WD-40 or Vaseline and cover them really good, do not spill the WD-40 on the wheels (it'll put oil spots on the paper.) See if this stops the noise.
If it does, you can do this every few weeks as needed or get the grease and use that on the gears for a more permanent fix.
Nov 09, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Fridge hot to touch
dont run the fridge untill fan is replaced compressor damage will occur if you do.
Jul 26, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung ML 1710 Laser Printer Logo
191 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
