Question about Canon MP49D Calculator
Printing faint on my tape, replaced ribbon, no improvement, any way to fix?
2 Suggested Answers
  • 286 Answers
SOURCE: printing
Likely your purge unit needs cleaning...
Make sure by printing out a test page from printer (not from computer).
If test page is good, you have a software issue. If test page is bad, you need to clean your head and/or purge unit.
Posted on Dec 30, 2007
How do you change ink on a canon p20-dh calculator
For accounting offices and stores, calculators that produce a printed paper are indispensable. Canon's desktop or commercial printing calculators use ribbon tape, and you'll need to change the ribbon when it is used up. All Canon desktop and commercial printing calculators use the same method for changing the ribbon.
  • Turn off the calculator.
  • Pull up on the tab on the far side of the printer cover to remove the cover.
  • Pinch together the ribbon lock (the arrow shows you the direction to pinch). Lift the ribbon spools off the shafts and discard them.
  • Separate the new ribbon spools. Guide the ribbon tape around the four guiding pegs and set the spools on the shafts. The spools should be peg side down.
  • Rotate the spools so the peg at the bottom of the spool goes into the hole of the spool holder. Release the ribbon locks.
  • Rotate the spools to make the ribbon taut, keeping the ribbon positioned around the guide pegs.
  • Replace the printer cover and turn the calculator on.
How to Change the Ribbon in Canon Calculator eHow
Feb 06, 2016 | Canon Office Equipment & Supplies
The ribbon cut or crack when printing
scotch tape will fix a torn ribbon without having to remove it completely from the printer
Jan 14, 2014 | Datacard Office Equipment & Supplies
Install lift off tape cartridge
Remove the ribbon by pushing the blue lever to the right and front of the ribbon. The correction tape cartridge is attached to the bottom
of the Printing ribbon. Depress the center of Printing ribbon to release the correction ribbon. Snap on a new one.
Nov 04, 2013 | IBM Personal Wheelwriter 2
Zebra S600 not printing..replaced ribbon withe as paper/ribbon light solid..still no print after attempting reprint many times (the printing result are white labels)
Just a thought, Zebra Ribbons are Coated Side Out. Take a piece of tape and press it against the ribbon, ink should come off on the tape.
If not then make sure the ribbon is the correct type and that you have it loaded properly. Also, if you use multiple ribbons i.e. wax, wax resin or resin make sure that you have the correct ribbon for the media installed.
Hope that helps.
mikeo@acebarcode.com
www.acebarcode.com
Aug 21, 2011 | Zebra Stripe S400 Label Printer
Hi I work in a restaurant and we have a Epson TM-U220A Model M188A printer. The last few days the printer has not been printing on the White receipt paper. We've tried replacing the ink and it doesn't do...
If this is the thermal head model, you will need to have the print head replaced. These were also sold under the Dell label, so finding a used replacement printer may be more economical. If it takes ribbons, you will need:
Ribbons
This printer needs a ribbon cassette to print receipts.
EPSON ribbon cassette, ERC-38 (B) (Life: 3,000,000 characters / Color: Black) EPSON ribbon cassette, ERC-38 (P) (Life: 4,000,000 characters / Color: Purple) EPSON ribbon cassette, ERC-38 (B/R) (Life: 1,500,000 characters / Color: Black)
(Life: 750,000 characters / Color: Red)
You can order replacement parts here: http://www.umd.com.au/itd/products/spareparts_epson.html
Thanks
Jan 08, 2011 | Epson TM-U220 Matrix Printer
I have a TA Adler-Royal 1123 PD nova printing calculator. (It is very old.) The numbers printed on the tape are very faint. Do I need a new ribbon or something else? Is there such a thing as an ink...
You need a new ribbon.
Older or much older desk top calculators used a small sized ribbon such as the old typewriters used except that the reels were about 1 inch across. Often they were divided into a red and black side.
It the calculator had all of the numbers strike the paper at the same instant, then it would use an
ribbon.
Here is a link to an Amazon.com page that sells the correct ribbon for your calculator.
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=1123+PD+&x=17&y=17
Here is a picture
Hope this helps,
Best Regards,
Mark
Dec 29, 2010 | Vacuums
Printing is very faint. How to change or add ink printer device.
This is most likely a ribbon impact system. Any office supply store should have the ribbon you need, with information on compaitability on the package.
Remove the paper roll and gently but firmly pry on the bezel surrounding the paper exit path. Examine the sides of the ribbon casing for any clips or fasteners.
May 22, 2009 | Victor 1280-5 Calculator
Printing faintly
It sounds like the printhead temperature needs to be increased in the print driver. This will enhance the color and density of the ribbon transfer to the card.
For techncial assistance for id card printers by blog, visit our blog at www.safecardid.com/blog
Nov 04, 2008 | Datacard SP35 Printer
The ribbon is no longer printing on the tape.
are you sure it uses a ribbon? Or does it use an ink roller. If it uses a ribbon it should reverse by it self. Make sure it is installed properly, there is not a ribbon reverse switch it should do it automatically. if its installed right.
May 28, 2007 | Sharp EL-2615G Calculator
Canon MP49D Calculator Logo
21 people viewed this question
old marine
old marine
