Question about Compaq fs740 17" CRT Monitor
Compaq monitor I have a concave image problem on my Compaq FS740 also. First the screen flickered for awhile ehn th monitor came on. Now the flicker has stopped but the image is still distorted. Any ideas as to what's causing this or what to do about it?
  • Tom Fletcher Jul 24, 2007
    Thanks Silverdragon. I pretty much expected the monitor was about to fail and you've confirmed it.
  • Anonymous Aug 28, 2008
    hello to the people who go gowin to see this . I have a COMPAQ < FS740 3 or 4 Days a go my Monitor is not acting right , I came and to torn on my PC the Pic on my Monitor it was and looks like freise. and the pic looks bigger and to the mouse is not working
  • Compaq Master
  • 12,061 Answers
OK your monitor is failing in the Horizontal circuitry.... OR the PSU is failing to supply the correct Voltages. Either way it is probably going to fail completely soon. With monitors so cheap now, here in NZ they are about NZ$20.00 - $50.00, repair isn't adviseable to do so, it would make more sense to put the Repair monies into a NEW screen... maybe time for an LCD?
Posted on Jul 24, 2007
Compaq monitor FS740 is turned off after some time
Step 1:
Check your screen saver setting.
Step 2:
check your monitor setting to always in active mode.
Jan 10, 2013 | Compaq FS740 Color Monitor
Compaq fs740 text too faint and fuzzy to read well
Firstly you need to switch to the monitor's optimal resolution of 1024x768 @ 85Hz and before anyone posts anything about resolution 1024x768 @ 85Hz is the optimum not the maximum. To change to this resolution: Assuming you are using Windows XP click with the right mouse button an an empty part of the desktop and select Properties (or click Start, then click Control Panel then click Display), on the Settings tab, under Screen resolution, drag the slider bar until it says 1024x768 and then click Apply. Also in Display settings you'll find an advanced button, in the advanced panel you'll see the option to adjust the refresh rate, try adjusting this to 85Hz. Now press the Menu Button on the front of the monitor and press + of - until you see an option called "Degauss" and press the select button on the front of the monitor, your screen will do a disturbing jump and flicker accompanied by a metallic thud, this is normal. If this doesn't help message back.
Aug 26, 2007 | Compaq fs740 17" CRT Monitor
Fix flickering screen
Flickering screen is often caused by a defective cable. Check all the cables attached to your monitor.
If you think all your cables are in good condition, the problem is probably with the environment. Monitors are sensitive to magnetic fields. Change the position where you have your laptop.
The problem might also be caused due to refresh rate not properly being set. In this case your screen will flicker when you open images or videos. Just adjust the refresh rate that will be available in graphic properties.
If the above solutions don't work, you probably will have to change your display.
Sep 17, 2012 | HEWLETT-PACKARD Compaq Presario CQ62-225NR...
My monitor compaq model MV520 is always blinking every time I open my computer, How can I fix it?.
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to answer and solve your problem. Your Compaq MV520 Monitor is always blinking every time you turn on your computer and you want to know how you can fix it? First, we need to troubleshoot the problem. I'm thinking you probably need to refresh the flicker rate on your monitor. The flicker rate is probably set on a low setting, which is causing you screen to blink (flicker). This can be bad for your health as well because it can cause eyestrain and headaches. Your monitor is a CRT (Cathode-Ray Tube) model. These types of monitors can cause a lot of screen flickering. Now that we've troubleshooted the problem, now it's time to solve the problem. There are two ways you can solve this problem. You can either refresh the flicker rate or you can buy an LCD monitor. LCD monitors flicker-free. My suggestion is that you refresh the screen flicker rate. To refresh the flicker rate, go into your System Preferences or Control Panel, click your operating system's appearance and display link and click your screen adjustment link. You may have to click your advanced settings link. Click your monitor tab and from there adjust you screen refresh rate. You may have to adjust your screen resolution before you refresh the screen rate. If you have to do this, make sure the screen resolution you choose supports you monitor's height and width as well as visibility. The higher the resolution, the higher the screen rate. The instructions I'm giving you may sound like this because I'm not sure what your operating system is. I'm not to familiar with Mac Operating Systems, but if you have a Windows Operating System and you need better detailed instructions, just reply back. I hope this decreases your screen flickering and gives you a better viewing experience.
Jul 07, 2011 | Computers & Internet
Samsung 226bw visible flickers just after it is turned on
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Aug 31, 2009 | Samsung 226BW Monitor
Philips 170S4 white screen not display.
its in the power suppy section,most of the lcd monitor has this problem,try to check the capacitor electrolytic or replace all th 16v capacitor
Apr 03, 2008 | Gateway FPD2275W LCD Monitor
Flickering screen
i had this problem & the circittree on the back of the monitor has a little ajustable screw if you ajust this till the flickering stops hope this helps
Nov 30, 2007 | Compaq FP 7317 17" LCD Monitor
Monitor flickers and image is reduced and squeezed
Heat related dry solder issue Horizontal output side.
Apr 02, 2007 | HP Compaq FS7600 17" CRT Monitor
Concave screen problem also
OK All these Compaq's have a Power Supply problem, or a Horizontal Voltage problem.. meaning they are on the way out. The SMPSU's in these units often fail along with the Horizontal Drive Circuitry. I think it is time for a new one? Repair of such a unint would barely be "Ecconomical" IMHO.
Jun 08, 2006 | Compaq fs740 17" CRT Monitor
Compaq fs740 17" CRT Monitor Logo
336 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
