Question about Intel DG31PR Motherboard
Power issue Everytime i plug in my 4pin atx 12v into the mother board my computer powers up for a breef second then turns of i unplug it and the power turns on.. any ideas what the problem is
    Scholar:
  • 55 Answers
You should try looking for a short, and reseat your connections. Make sure your power supply voltage is set correctly. If that doesn't help, test your power supply and if it fails, replace it.
If that does not help you there's still quite a bit that could be wrong. You could try restarting with only the essential hardware and if it turns on you'll have to check each componant one by one for the cause. Maybe you might need to reseat the CPU. If you still don't find the cause, you may try a POST card. If you don't have a POST card or do not want to buy one you can try swapping parts from an older machine if avaliable and compatible.
If none of the above helps, then I would suggest taking it into a shop. Otherwise your only option is to begin replacing all the parts which can be expensive. I hope this helps and that it turns out to be nothing serious.
Posted on Jan 27, 2009
ATX motherboard connector pin out
Black=0V(GND)
Yellow=12V
Red=5V
Orange=3.3V
Purple=5Vsb(everytime on)
Gray is PWRGOOD or PWROK(pwr=power) must be at 5v
White=-5V(optional)
Blue=-12V
Green is PWRon must be connected to a black wire to turn on the PSU
Nov 16, 2012 | Enhance Technology ATX-1123B, Enhance...
Mobo on my rosewill armor mid tower wont function. have repalced mother noard an gpu I do not know what to do it turns on fans spin but no mobo activity
Make sure that your power connectors into the motherboard are all firmly connected. I had the same problem, the solution was that the CPU , 4pin molex connector was disconnected.This connector may initially be 6 or 8 pins but the 4 can be separated from the others. This should solve your issues.
Feb 18, 2011 | Rosewill ARMOR Gaming ATX Mid Tower...
Can you connect the 4pin power supply to the 8pin on board 12v
Yes, you can connect the 4 pin power supply to the 8 pin with little trouble but, you should not try any advanced features like overclocking or crossfire. If you would like to do those things I suggest getting a 4 to 8 pin adapter (very cheap usually less than $5) at most local computer stores.
Oct 10, 2010 | Gigabyte GA880GMUD2H AM3 AMD 880G HDMI...
E Machine ATX 250 -12E replacement PS
With emachine MOBO's you have to make sure you plug in the 20 pin plug from the power supply to the mobo. Also make sure all hard drives, cd/dvd roms, floppy drives, etc are turned on. Make sure the red switch on the PS is set to 115. Make sure the PS is plugged into a known working outlet. Make sure MOBO is properly in place with all grounds/screws in place and nothing metal near or touching board which may short it out.
You can review the E Machines PS replacement guide here for further instruction.
Good Luck,
Jesse
Jan 11, 2010 | Gateway Emachine Bestec ATX-250-12E PS...
Power supply will intermittantly not turn on when start button is depressed. After a period of time, it will start. Ten or 20 minute wait period insufficient. Sometimes successfull after several hours. No...
This could be one of two issues: Your motherboard may be set to shut down when your CPU reaches a low temperature, which can be fixed by getting into your computers' BIOS settings...Or replace your power supply.
Oct 13, 2009 | Antec 650W EarthWatts ATX Power Supply 80...
PC won't 4power on.
Failures in the motherboard, memory, or any installed card could cause that symptom. All I can suggest based on the above information is remove memory one piece at a time and retest, remove/reseat video card if you have one, and attempt to reset the CMOS using the jumper on the board. You might also try removing the battery on the board and unplugging everything, then attempt to reboot.
Jan 03, 2009 | Acer Aspire™ T180 PC Desktop
Missing -5VDC and -12VDC
Could be.Some do some don't.Some have a circuit breaker. Take the cover off and check. Be careful though as some parts in the power supply can hold a pretty significant charge for quite a while even after the power supply is turned off.If there is no fuse or if you change the fuse and it blows again I would say a new power supply is in order. Good luck.
Dec 14, 2008 | Aspire (ATX-AS500W) (atx-as500w 12v) Power...
P4T-E PSU
your connector is of two part.it has total of 24 pin, can be divided into 20 and 4 pins.connect  20 pin  in your mother board .switch on ur psu and connect 4 pins to another port.
Jan 19, 2008 | Powmax 400 Watt ATX Switching Power Supply...
Intel DG31PR Motherboard Logo
47 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
