Sunbeam kerosene heater 3625-2 manuals
How to replace wick
SOURCE: dyna glo kerosene heater
smoking problem
Posted on Nov 23, 2008
heavy389
SOURCE: I need to change the wick on my dk 23 corona kerosene heater
what make and model is it? They are very simple to change,never heard of 1 "Not" lighting tho,unless you have water in tank and the wick sucked up the water...water don't burn,You can also raise the wick in their now if it has never been raised,as long as it don't have "riviet"looking things attached to sides of wick to fit it wick housing(Sears is good for that)If it a round or square heater it pretty much the same you have to remove the outer shell of heater, its always a good idea to dump out fuel first,at the base of wick their is usually 3 wing nuts or screw that hold wick Assembly in,after removing them you pull housing up to remove ,notice how the old one is on and remove and put new one on,when putting back in make sure wick fans out and goes to bottom tank,put back to gether and your done,most replacement wicks come with directions and height setting for the wick, Its not real hard as long as you pay attention
Posted on Nov 30, 2008
  • 39 Answers
SOURCE: 12-dk kerosene heater
well other then getting dirty and tearing it apart...... on the dk-12 when you install the new wick the black line needs to match up with the adjusting coller then you push the wick onto the teeth and assemble the hard part on mine is the piece below the wick that guides the wick in the bottom there needs to be a little slack so the wick can get raised and lowered. I hate to sound like I like ace hardware but from where I am at there guy there is great rebuilding these.
Posted on Dec 14, 2008
  • 3 Answers
SOURCE: kerosene heater
Dyna Glo 95 c4 Manual
http://www.owneriq.com/mdownloads/8979e0af-dfee-45f1-a8ba-c05c2f5ed4a8.pdf
Posted on Dec 07, 2009
  • 30 Answers
SOURCE: Changing Wick in Kerosene Heater
http://www.ghpgroupinc.com/heaters/manuals.aspx
Here is the complany website..parent group name is GHP group..crazy they don't link DynaGlow more easily in a web search
Posted on Nov 06, 2010
Changed wicks and change wick light is still on. how to reset?
Humidifiers - Frequently Asked Questions - iAllergy
www.iallergy.com/humidifier_answers.html
Do I need to replace filters, and if so, how often? ... quietest humidifiers available, and the ideal choice when noise level is a concern (if you are a light sleeper). ... Most evaporative cool moisture humidifiers use replaceable wick filters, and these should bechanged every 2 months on average (wick filter life varies depending ...
[PDF]OWNER'S CARE & USE MANUAL - Appliance Factory Parts
www.appliancefactoryparts.com/content/pdfs/116710-1.pdf
Refill light with Automatic Shutoff. • 2-Speed Fan ... If it still does not fit, ... Thishumidifier is ETL listed with Essick Air brand evaporative wicks in place. ... wick, the water evaporates into the air, leaving behind any white dust, ... We recommendchanging the wick ... Use only Essick Air brand replacement wicks and chemicals.
Amazon.com - AIRCARE 1041 Replacement Console Wick ...
www.amazon.com/...Replacement...Wick/.../B0002GD...
Amazon.com, Inc.AHAM certified output; Longer lasting, still at 96-2/5-percent after 90 days; Less energy consumption ... Essick Air 1970 Humidifier Bacteriostatic Treatment, 1-Quart ... BestAir CB41 Essick 1041 Replacement Wick Filter ... Super Wicks trap minerals and other particulates to prevent white dust and sprays, which are often seen ...
Jan 04, 2016 | Humidifiers
How do you replace the wick on a comfort glo kerosene heater?
open the vent of wick, turn the knob clock wise to dismantle the wick from its fixing hole,after completion to out the wick,then try to insert the wick in its hole from below side,push gently the wick in &
rotate the adjusting knob to set the wick in
Dec 09, 2014 | Heating & Cooling
How do replace the wick in a turco kerosene heater
This a very odd question about cell phones, isn't it? There are two videos on you tube to help you do this.
Kerosene Heater Wick Replace - YouTube
How To Replace a Kerosene Heater Wick Tutorial - YouTube
Jan 26, 2014 | Lands Phones
I need to know how to replace the wick and what size wick is required, I guessed a 95mm. The dial that controls the wick wont stay turned holding the wick up so i cant light the heater. would this be due...
It possibly could, if the wick is not installed properly. Also, the height mechanism (the control knob and the gears) may have lost it's tension and will need to replaced.
However, without knowing what brand/manufacturer and model number kerosene heater you have, there's not much more I can tell you.
May 12, 2011 | Heating & Cooling
The wick will not raise
If you allowed the fuel to run out then the wick is probably ruined, you will have to replace it.
Feb 26, 2010 | Corona 23-DK Compact Heater
How do i change the wick?
You need a pair of Pliers, a flat-tip screwdriver and a plastic bag (for old wick)
ALSO - make sure the tank is empty (or as close as possible)
1. Turn the control knob to OFF.
2. On the left and right side (bottom, just under the wire cage are two cabinet screws. Remove these.
3. Using the handle, lift straight up to remove the cabinet (entire upper assembly)
4. Gently pull off the wick adjustment knob (you will need to push in the little square button.
5. Remove the "dressing plate" (the ring about 3" high) that the "Off" "Low" and "High" markings. The chain attaches this the fuel cap, but you don't have to remove the cap. Just set the "dress plate" ring aside as far as the chain lets you.
6. Either trip the manual shut-off or push against the wobbly pendulum to the left of the control knob shaft to drop the wick all the way down.
7. Remove the four wing nuts that holds the heater on the wick assembly and carefilly lift teh sick assembly from the heater.
8. Reset the automatic shut-off, put the know back on temporarily and raise the wick all the way.
9. Turn the Wick Assembly upside down. Place the white plastic strip, packed with the new Wick, on the Wick Cover to protect your fingers.
10. While holding the Wick Assembly upside down, pull off the Wick Cover with a sharp tug.
11. Remove the Wick while folding it to the inside. (Remove the Wick Sleeve together with the Wick).
12. Take the new wick and insert the Wick pins into the three holes of the Wick Sleeve. (Make sure the short portion of the Wick is UP.)
13. Attach the Wick wo the retainer teeth of the Wick Sleeve stick into it, making sure the Wick fits evenly arount the inside with no wrinkles or bunching.
14. Fit the Wick and Wick Sleeve back onto the Wick Guide, making sure you fit the pins through the slanted grooves of the Wick Guide and Press on each of the three pins from the back, making sure they are inserted securely through the holes on the Wick Guide. (This is where most people screw up Wick Replacement, so make sure you get this right)
15. Turn the Wick Adjustment Knob to make sure the Wick slides up and down freely. (Note, the wick should automatically be set to 3/8 of an inch when fully raised.)
16. Turn the Wick Assembly upside down and replace the Wick Cover by: Align the four tabs on teh Wick Cover with the four screw holes on the bottom of teh assembly and snap it into place.
17. Hold the Set Lever to down position with your finger.
18. Remove the protective strips from the Wick Cover. Turn the Wick Adjustment Knob to the fully raised position and light pull on the "skirt" of the Wick to remove any slack. Then press the skirt lightly onto the teeth on the Wick Cover to hold it in place.
19. Replace the Wick Assembly on the heater WITH THE WICK RAISED. Replace the wing nuts, tightening gradually, tightening opposites sides first(If counting clockwise, tighten screw 1, 3, 4, 2 - go through several rounds, tightening gradually so it seats evenly
20. Before further reassembly, trip the Auto shut-off and reset it to make sure it works properly. Test the Wick adjustment knob to make sure Wick slides up AND down freely.
21. Remove the knob and replace the "dressing plate ring.
22. Replace the entire upper assembly "Heater Cabinet" and repalce the two screws. Replace the Wick Adjustment Knob.
Oct 11, 2009 | Corona 23-DK Compact Heater
Change wick corona dkc22
u need to start at top . remove cage from top. there should be a few screws on the side of the upper case (the round upper part of the heater) once that is removed u will see the shaft the wick is attached to,the heater control are mounted here too. there should be some screws or wing nuts remove them. now lift the shaft out the wick will come with it (carefull wick wiill be wet with kerosene) remove old wick. when replacing new wick make sure to allign the top of the colored band with the top of the wick holder(the piece with the pins that adjusts the wick up & down) lower shaft & wick back onto heater and reasemble heater .be sure all controls and shut off work smoothly and correctly.
Jan 10, 2009 | Corona 23-DK Compact Heater
Why am I replacing wicks every 3 weeks
could be you got the flame a little too high so its burning off the top of the wick.
Dec 27, 2007 | Corona 23-DK Compact Heater
Heating & Cooling Logo
185 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
