Question about Samson Resolv A6 Active Studio Monitors
My samson resolv A6 wont turn on
Using my decks i noticed one of my speakers was not working right so i turned it off and on but it never came bk on and i changed the fuse still nothing
3 Suggested Answers
  • 5603 Answers
SOURCE: i use vista and my Samson C01U usb condenser mike
Try this site:
http://www.samsontech.com/main/misc.cfm?pageID=51
Posted on Nov 09, 2009
  • 1212 Answers
SOURCE: no sound from samson resolve a6 speaker
Is the input cable okay on othe systems? Is the voltage switch setting correct for yourpart of the world? Is the GND/LIFT switch fully set to one side or the other?
If you are plugged into the 1/4 ich jack- is you plug the correct length? There are 5 different lengths on thses.
It also would not hurt to spray some LPS-1 into the controls and switches and cycle them to clean contacts as well. And into the 1/4 inch jack directing the spray towards the interrupt contacts.
Posted on Sep 26, 2012
I have a pair of VP1220D Active PA Speakers in my home studio, & there is a varying whistle coming through which is very annoying. The studio is on a separate power circuit to the rest of the house, & I've...
Some kind of feedback perhaps? Are you using a multi core with sends & receive inside it but NOT individually screened? i.e. "pick up" inside the cable? Is it both speakers? Try them one at a time in case one is faulty but affecting the other? Unplug the input leads & see if the speakers by themselves are making any sound ( a small hiss?) If the speakers with no input (but powered :-) makes no whistle then it's coming from other gear...... Also the speakers may have switch mode power supplies & if you don't have a decent ground you could have problems. Make sure you have a good ground connection back to the fuse board. If you studio is in a shack at the end of the garden running on extension cords you may need a local connection to ground..... Good Luck!
Mar 24, 2017 | Behringer VP1220D Eurolive 2-Way Powered...
Samson Resolv 40A,no sound, power light on cables good.
Your best bet is to take them to an authorized repair center. You may also want to talk to Samson directly. Here is their support link-
Support SamsonTech
Mar 19, 2013 | Samson Resolv 40A Monitor Speakers
No sound from samson resolve a6 speaker
Sep 25, 2012 | Samson Resolv A6 Two Way Active Studio...
Speaker humms only. what causes that?
Incorrect connections or volume settings.
• In powering up, mixer first then amp
• In turning off , amp first then mixer
If hum still persist, without the mixer connected
then speaker amp may need servicing.
Jul 31, 2012 | Samson Auro D415A Speaker PA Active
My samson microphone c01u works but i cant hear my mic thru my speakers it does not record out
That's normal. You're supposed to record a track and then play it back. In order to hear it live you would need to enable "software playthrough" in your recording software, but there will be a delay, so it probably won't be much use.
Aug 27, 2011 | Samson Audio C01upak C01u Microphone and...
Played samson 412 aura speakers for about 6 hours today with the volume at 1/4 of the way turned up.. the speakers became very hot and turned off by them selves.. I have them mounted on stands in a corner...
The volume setting on the speakers has LITTLE to do with how hard you are driving them. Your source might be extra hot and overdriving them. Read the specs on the speakers and use a sound meter to check your level. The speakers, being only 12 inch, should fill a room 20 foot by 20 foot to about 95 to 100 Db which you are only allowed 2 hours in MAX to prevent hearing loss. At 6 hours you should keep it down to 85 Db SPL. I know several deaf musicians that were exposed to high sound levels in rock bands... a deaf musician is kind of washed up.
Jul 03, 2011 | Samson Auro D412 2Way Active Speaker
Hey, i bought a new pair of samson auro D415 speakers and i connect them in parallel because one of my main mixer outputs ain't working.but even if al my signal gains and fader levels are low,the peak...
Check only one active speaker at the mixer output and report the results.
Connect only one of the audio inputs from the power amp at the mixer output (and the passive speakers at the output) and report the results.
Sometimes (in parallel connections) there are interferences from the volume controls.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 30, 2011 | Samson Auro D415 - 2-Way Active Speaker...
My Samson Airline UHF wireless kit is not working. I have all new batteries, cables and all the lights are on, except on the AG1 transmitter. When I turn it on, the light comes on, pops and then goes off
Make sure you are using ALKALINE batteries... rechargeables have lower voltage that does not work with a lot of these devices... Often the batteries are marked with the voltage they are intended to replace rather than their actual voltage. NiCad batteries only produce 1.25 volts and that is under what is required. The device will come on and immediately go off.
Mar 05, 2011 | Samson Airline AG1 UHF GuitarBass Wireless...
Samson Resolv A6 Active Studio Monitors Logo
29 people viewed this question
Top Samson Music Experts
Matthew Spark
Matthew Spark
Michial Gueffroy
Vito Vacirca Jr.
Are you a Samson Music Expert? Answer questions, earn points and help others
