Question about Adagio Teas Trinitea Electric 32-ounce Tea Maker
Trinitea tea maker keeps beeping when turned on
Ice tea maker keeps tripping gfci
You have a bad machine. One of the AC lines is touching the case. Take it back or replace it before somebody gets hurt.
Jan 16, 2014 | Bunn Ice Tea Maker 3 Gallon Tall TB3 29"
Will not make entire pot???
Look at all the lines and at the hole the hot water comes out ,there might be some blockage somewhere.Also try and put a mix of 6 oz of white vinegar and then 26oz of water and stop it after it starts for about 1 minute or two the let the mix sit in the machine. Hopefully there is scale built up on the heating coil and the mix of water and vinegar will most likely do the trick . Also look for blocked hole where the hot water comes ,Check the unit out for something blocking any holes. good luck.
May 02, 2012 | Adagio Teas Trinitea Electric 32-ounce Tea...
I don't have a manual on how to use the Sunbeam Tea Drop Hot Tea maker, where do I find how to use it ?
I had the same problem as mine was given to me without the instructions, but its very simple to use. You just open the top of it, remove the little tea basket and the basket holder. Next you want to fill the little pot to the desired amount of ounces and then poor it down into the tea maker. never go past the fill line that's etched inside cause you will be cleaning up water from everywhere! Next, put the pot on the heated plate and put the tea basket and holder back in place. Put your chosen tea in the little basket and then close the top of the tea maker. It will start to brew the tea now. Always have your pot in place before closing the top, otherwise the tea will start brewing all over the hot plate. you'll probably hear this crackling popping sound, and that's just the tea maker heating and pushing the heated water through the machine. Once the tea maker has stopped crackling and popping and is no longer dripping, the tea is ready. When you get done using it, run a full pot of water through the machine to clean it. Repeat until water comes out clear. Also clean your basket and holder and occasionally you're gonna want to clean the part where the tea drips from the maker into the pot. You just reach under and pull it out, clean it and replace it. It just slides right out and back in. Tea can stain it and build up there, so you definitely want to clean that. Be really careful because it gets really hot, and releases lots of steam if you happen to open it while its brewing for some reason. Occasionally you will need to clean the inside of the actual tea maker. When you do this, make sure it is unplugged. Make sure not to get the hot plate wet. Clean with soapy water and carefully rinse it out. there's a little rubber stopper inside at the back of it and you want to take it out while cleaning and put it back when you're done. Once you've gotten it all cleaned and rinsed out, run a few pots of water through it, and if there's nothing in the machine or pot, it should be clean. If there is, carefully rinse the inside of the machine out again, then run a pot of water through again. If there's still stuff in the machine, just keep repeating til the water and machine are clear. I cant stress enough to be careful because of the electrical parts and you don't want to ruin the machine. Just take your time and be careful. Hope this was helpful!
Sep 22, 2011 | Sunbeam Tea Drop Tea Maker HTM5B
When making iced tea, what measurements of tea should I use?
Use the suggested amount of tea noted below:
3 Quarts - 5-7 bags or 2-3 Tbsp. of loose tea
2 Quarts - 3-5 bags or 1-2 Tbsp. of loose tea
1 Quart - 1-3 bags or 1/2-1 Tbsp. of loose tea
Sep 02, 2011 | Philips Senseo HD-7810 Coffee Maker
How do i make iced tea with my Keurig coffee maker?
In my experience it is not possible to make good tea with a coffee maker.
Tea needs to soak. 2 minutes for weak tea or if you like it like me 5 minutes for strong tea.
Coffee makers simply run hot water over the bean powder and don't soak it long enough.
L8ers
Sep 12, 2010 | Keurig Elite B40 Coffee Maker
How do you make sweet tea in the pitcher?
put sugar in cup and not in machine now have to descale and clean
Oct 22, 2009 | Back to Basics IT400 TEA MAKER 2.5qt GLASS...
Can loose tea be used with this tea maker?
Loose tea can be brewed. I had researched more on the internet.
Jul 30, 2009 | Back to Basics IT400 TEA MAKER 2.5qt GLASS...
"Tea Drop" manual
It's December, so you may not still be looking, but you put in 1 tea bag in each side for 1/2 pot of tea, or 2 tea bags in each side for a full pot. If you are using loose tea (tastes better - I just buy Lipton), then you put in 1 Tablespoon in each side for a 1/2 pot and 2 Tablespoons in each side for a full pot. Hope this helps!
Jan 21, 2008 | Sunbeam Tea Drop Tea Maker HTM5B
Adagio Teas Trinitea Electric 32-ounce Tea Maker Logo
35 people viewed this question
Top Adagio Teas Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Adagio Teas Kitchen Appliances - Other Expert? Answer questions, earn points and help others
