Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Won't print from Word or Excel
The printer will not print from the Windows programs Word or Excel though it prints fine from email. We have changed the ink cartridge several times and it may work for one copy but then fades away & usually just sounds like it is printing but a blank sheet of paper comes out. What can we do to fix this problem
  • pattandallan Jan 27, 2009
    This worked like a charm. Thank you very much. Well worth the $9.99
  • 741 Answers
Given the fact that you are able to print some documents then at rules out any hardware or driver problems. As if it were a faulty connection or a corrupted print driver then you would not be able to print anything. The printer spooler sometimes becomes full and it just needs to be cleared out and restarted. So try this we will reset your print spooler:
Step 1: Click on Start
Step2: Click on Run
Step 3: In the small window type services.msc
Step 4: Scroll down until you find the Print Spooler
Step 5: Right click on it and click Restart
This close all windows and print. Let me know how it turns out and if you have any questions please let me know.
Posted on Jan 27, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Sounds like a glitsch in your text software, e.g. MS Word... Some of these MS programs are not as intuitive as they should be... You may have used an envelope template which was set up -- and worked fine -- for a different printer.
Try checking your software's envelope setup to ensure the feeder orientation matches the printer's design. For example, if using MS Word97, go into "Tools", "Envelopes and Labels", "Options", "Printing Options", and indicate the "feed option" that corresponds with your printer. (Look for an icon embossed on the paper feeder somewhere, or in the printer manual, for the envelope feed orientation that the printer is designed for...)
  • Rylee Smith
    Rylee Smith Jan 27, 2009
    I don't think its your printer's issue however there is some problem with ms word. Reinstall ms word(before reinstalling, restart your pc) and then it will print with ms word & excel.
    Thanks
    Rylee
  • 177 Answers
Hello and welcome to FixYa!
It sounds like there may be a Missing or Corrupted Driver on the Computer Causing this Problem, Please Re-Download the Driver off the Manufacturer Website!
If not it may also be a Faulty Printing Sensor/Lens!
Hope this works and Remember to Rate My Answer, --P3NGYJ03
    Sniper:
  • 92 Answers
I actually have this same problem at work some of the time. What i do to fix it is I turn off the printer and disconnect it from the PC then I reboot the PC and reconnect the printer to a different USB port and turn the printer back on. After that it prints correctly.
  • Michael Cunningham
    Michael Cunningham Jan 27, 2009
    You are very welcome if you need anymore assistance feel free to contact me via FixYa.com
    http://www.fixya.com/users/rayborn
Outlook won't print to Brother MFC7360N AllInOne Laser Printer
Must be set on Brother MFC-7360N series. Set on PC-FAX will not print with all programs, as it is printing with an output through the fax. Go to control panel, select devices, printers to change to pc-7360 series. This should print on all programs.
Mar 17, 2014 | Brother HL-5240 Laser Printer
Canon pixma mp287
Are you sure the correct printer is selected in Excel? I would compare Excel print settings with Word settings, since Word is printing docs.
Dec 08, 2013 | Office Equipment & Supplies
Printer will not print e-mails
Once you give print command of an email, your email program should ask you to select printer.
If you are using MS Office, by default One Note printer might be selected.
Please check which printer is assigned when you click print.
I hope this information helps.
May 11, 2011 | HP LaserJet 1020 Printer
Since upgrading to Windows 7, I can't print from Excel (Office 2003). When I try, a "Print to File" window pops up even though that check box is unchecked in the print window. I can print from Word and...
try to make the installed printers as a default printer and then try to print.
in case that does not work when you try to print from excel, click on the drop down for printer name and select the correct printer.
This should help you
Jul 12, 2010 | Microsoft Excel for PC
Using XP sp2, excel 2000 and HP 4250 printer. Any
The print settings can be different for different programs. Open Excel and in the File menu, choose Page Setup. Click on Options, and towards the bottom is a setting that says Copies. Change this to "1" and hit OK, and you should be fine.
Hope that helps!
Mar 09, 2009 | HP LaserJet 4250n Printer
MY printer will not print Excel spreadsheets
I had this problem on my Vista pc but it was for all programs it would say its printing and nothing happened,what I did was leave the old one installed on the pc and created another and then deleted the old.But have you tried uninstalling excell and re-installing it to see if that changes anything, and when you reinstalled epson did you go to their site and download the updated firmware/software for the printer this could be another cause?!
Nov 05, 2008 | Epson Stylus CX6600 All-In-One InkJet...
HP Deskjet F380 All In One Printer
did you choose the name of your printer in the printer option when printing in the other programs?...try it...else maybe you need to wait while your printer spool... or is it compatible with the program you are using?
Aug 18, 2008 | HP DeskJet F380 All-In-One Printer
Problems with printing
Try uodating your printer drivers ,Try to change default printer
Jul 20, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printer won't print email or confirmation notes
I've ran into a similar problem at a client. They have about 20 printers in the work environment, a few of them are bigger copier/scanner/faxes that prompt for a department code upon printing. A few of the workstations were having problems printing emails to one of these multifunction printers to where the computer acted like everything printed fine, but there was no prompt for the department code so the email did not print. I could go into Word/Excel/Acrobat and it would prompt for a department code and everything would print fine, but Outlook never prompted for this code.
My fix was to just simply reinstall the problem printer and the workstation started prompting for department codes again upon printing from outlook.
Apr 24, 2007 | Epson Stylus Photo R340 InkJet Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Sajid Najmi
Sajid Najmi
Level 1 Expert
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
