Question about Hotpoint NBXR463EBWW Electric Dryer
Hot Point Dryer wont start
I've had my hot point dryer for 7 years with no problem...then today after taking one load out and putting another in (small load) the dryer will not start. It makes a sound like it is going to start but the drum does not start moving.
I've checked to make sure it is plugged in and the circuit did not blow (I don't think it would make any sound if this were the case). Lint filter is clean. Any help would be appreciated, I live in an area where there are no GE service people.
    Sniper:
  • 100 Answers
Might be the capacitor that starts the motor. if the drum can be push started to get it going this will be the proof. you would need to get a cap. of the same rating.
Posted on Jan 27, 2009
3 Suggested Answers
  • 78 Answers
SOURCE: This is the 2nd dryer of this style I have had, in
im not a fan of lighting striking in the same place twice i would make a claim againt sears, take pics of it and document everything who you talk to and when, make them give you and answer not just blow itofff, this does not seem normal to me ive been doing this a long time, even in comm laundry condition and i have not seen a fire in the same place twice, let me know imm interested thks larry hope this helps
Posted on Apr 24, 2010
  • 3074 Answers
SOURCE: Whirlpool gas dryer WGD5540SQ it is getting power,
there is a reset button on the motor more then likely it tripped, there are actually two one resets the other trips, but here is a website it will help with the dissemblance of the dryer, Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Posted on Oct 19, 2010
Hot Point Dryer won't dry, gets hot on top.
An educated guess would be either the lint tube or the tube that exhausts the air outside is blocked with lint----no airflow or greatly reduced flow will cause this symptom.
Nov 06, 2012 | Hotpoint Dryers
Dryer hot but not drying quickly.
Sounds like you have a clogged vent. Hopefully you've gotten this repaired.
Feb 25, 2012 | Frigidaire Washing Machines
My hot point will not fill with water the supply is ok
The screens where the hoses connect to the washer are clogged with mineral deposits, which is not allowing the water to flow into the washer. I've had the same problem.
Sep 03, 2011 | Hotpoint Ultima WDM73 Front Load Washer /...
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
Long time to dry clothes
The dryer has one of its rows of heaters open. Open up the dryer and check the coils behind the drum. read more
Mar 09, 2009 | Hotpoint NVL333EY Electric Dryer
Hot Point electric dryer squeaking when in use.
It could be one of the pulleys on the bottom of the drum. Take the top and front panels off of the dryer. Get some WD-40. Now the hard part, there is no easy way, but put your right arm in underneath the drum (the right side of the drum)and spray the pulley the best you can. This is the hardest, but the easiest way to fix this problem, without having to take the entire dryer and drum apart. I had the similar problem. I didn't completely fix the problem, but the squeak has been significantly quieted.
Feb 14, 2009 | Hotpoint NWSR483EBWW Electric Dryer
No heat
vpflueger,
I am not sure why.
But I will tell you that at only 5 years old you should repair it.
This is a fine machine!
Try our premium service and they will fix you up!
Sep 22, 2008 | Kenmore 64982 Electric Dryer
Hot point dryer
Three problems
  1. :Heater thermal fuse is blown, not a repairable/resettable item, replace the thermal fuse.
  2. the controller that turns on the heater, is fubar
    it is a relay with 120v solenoid coil and 120v terminals for the motor and 240v terminals for the heater. the 240v side has fused closed so does not turn off. not a repairable item replace the relay
  3. The scraping noise could be from drum bearings/rollers Check the roller bearings under the rear of the drum, to make sure they still turn freely and have not dropped, check the felt ring at the front of the drum to see if it is worn out
  1. as soon as you started the motor a rush of very overtemperature air travelled down the exhaust duct and melted the thermal cutout screwed on the side of the duct, inside the dryer. These items are between $7-$13, and every washer/dryer parts store has them, there are only 4 or five different ones in all the makes of dryer.
  2. Locate the run relay, and remove it, test with a ohmmeter or battery and bulb, across the load terminals, ALL load terminals should have, no light on the lamp, infinity ohms on the meter,
    solenoid coil terminals should have about 100ohm on the meter, faint glow on the lamp
    relays are $18 -$90 (rippoff but some have to use OEM parts)
  3. roller kits are $9+, felts between $12-$30
Aug 02, 2008 | Kenmore 63942 Dryer
Kenmore All in One?Dryer Heat Minimal?Excessive Dry time
be sure vent to outside is not plugged or partially block be sure vet tube in back is not compressed flat or folded basically be sure you have good air flow to outside to take the moisture to the outside away from the clothes
Jun 06, 2008 | Kenmore 45081 Front Load Washer / Dryer
Hot point WD440 wash/dry :How to put tumble spin off.
i know this may sound stupid but did you follow the instructions on removing the Transit Braket? with tht un removed it will cause the machine to "Dance" around the room
Jan 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint NBXR463EBWW Electric Dryer Logo
143 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
