Question about Cobra Mr Hh425li Vp Marine Hand Held Dual Band Transceiver
My Cobra MR HH425LI don't transmit and received after 5 minutes
I have two Cobra MR HH425LI. After 5 minutes from power up, the radio stop to transmit or received.
On first 5 minutes all MR HH425LI work well (received and transmit ok with the same cobra radio and with other model).
After 5 minutes from power up, the radio stop to transmit or received.!!!:
When I press TX on the screen appared the TX indicator but I don't received anything on all other station on this chanel (on bouth band).
When I press Tx on  other model station (I have many other station) all MR HH425LI don't received the signal (but all other station receiv all ok).
When I press Tx on Cobra MR HH425LI other station don't received the signal.
If I power off the Cobra MR HH425L and Power Up this radio work ok again for only 5 minutes!!!
What can I do to resolvate the problems?
Thank you
Cristian
SOURCE: cobra 148gtl
tomcat 1 back ...i have found the fault no modulation on am/usb/lsb.tr -23 a bc458 transister .replaced this transister and wow modulation on all 3 modes thanks zeppfrog for telling me where to look .
Posted on Mar 01, 2007
  • 9 Answers
SOURCE: Cobra 148GTL Missing TX Modulation
The problem is most likely the audio ic . open the radio and see if the diode 44 is blown or see if you see anything that looks like it got hot around the plug area. if not contact me and i will buy it. is it an old or new 148 gtl.Read more
Posted on Dec 06, 2008
  • 14 Answers
SOURCE: Have Cobra 29 LTD CB
Sounds like the PLL circuit....... no channel synthesizer will kill the transmit and receive...... bad crystal or IC could be at fault or if someone has attempted to add more channels could also be cause.
Posted on Dec 22, 2008
Shuttle83
  • 1139 Answers
SOURCE: radio sticks in TX mode after I let go of the button on the mic
Hello williamhicks,
There is a relay in side of the cb that might be sticking. The problem is that this situation might be environmental. You say that you sent it back to Cobra twice for repairs. I think that the place you are sending it to differs enough environmentally so that the problem does not manifest itself. You can test this by exposing the unit to different temperatures, to determine if the internal relay is sensitive to variations in temperatures.
If you do find that the relay has become tempurature sensitive, you can order the part from Cobra, or strangly enough from Radio Shack, since they do carry the same part just by a different part.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Mar 11, 2009
  • 773 Answers
SOURCE: Cobra 148GTL can't TX on USB
Its the cap that feeds the first transistor to the first of the finals. It is either shorted or burned out.
Or the audio IC. It could be putting just enough out on AM to seem like its working, and then not enough for side band.
look at the caps near the finals. Look for a burn one, or one that could be twisted, or shorted in any way.
Posted on May 05, 2009
How do i correct engine noise while transmitting on a cobra MR F45-D marine radio
you'll need a filter capacitor in the power line to the radio. wiring varies according the the individual unit, but typically one side to power, the other to ground.
Nov 29, 2014 | Cobra Mr F45-d Marine Class-d Dsc...
Meter don't work
Hook radio to a dummy load with a watt meter in line---if no actual power being transmitted radio will not go to cal or show transmit power.
May 19, 2012 | Cobra 29 LTD CB Radio
How to wire a HG M73 mike to a galaxy DX 959
Stock
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
Cobra
Stock
1- Audio
2- Transmit
3- N/C
4- Shield
5- Receive
Dec 04, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
Do i need ariel for cobra MR F55 EU radio
? I assume you are asking if you need an ariel antenna for this radio in order to receive and transmit? if that is the case then yes you do, Any radio requires a matched antenna in order to transmit, if you were to transmit without an antenna, most of the RF energy will transfer back into the radio and over heat "burn out" the output transistors. always make sure to have a proper antenna connected before transmitting on any radio.
Jun 19, 2011 | Cobra MRF55 2-Way Radio
Need a service manual need to modify a MR f55 radio to transmit on 161.600 mhz can you help?
You want to be able to transmit to the Coast Station on this frequency I assume. The Coast Guard monitors channel 16 at all times. This would be the primary channel in the United States. Your radio is VHF Marine Radio and has a built in frequency range of 156.050 MHz to 163.275 MHz. There is no need for a modification. This is a duplex frequency. What that means is you will transmit on one frequency and receive on another, while on channel 20. You will not need to transmit on 161.600. Turn your radio to channel 20. When you transmit, you will transmit on 157.000. And when the Port responds to you your radio will automatically receive their signal on 161.600. So if you are trying to figure out how to communicate with the port authorities then for that frequency turn your radio to channel 20 and you will be able to communicate with them.
Regards, Tony
Mar 31, 2011 | Cobra MR- F55 Base CB Radio
Stops working when I try to transmit.
problem may be the button loose connection to the main board...we can fix these radios. cb shop temple, tx on yahoo search. The button is connected in so it controls both sections.
Aug 03, 2009 | Cobra 75 WX ST 40-Channels Handheld CB...
Low transmitting range on Cobra MRF55
Hi dstrand, sorry you are having a problem. I will need some more info if you can. Is this radio in a base situation or mobile? Have you had any work don recently? Have you changed anything on the system? (Microphone, antenna, coax, etc)
Haave you checked your swr recently/ If yes, did you use a seperate meter or did you use one built in the radio?
Hope to hear from you soon.
Tom
Dec 30, 2008 | Cobra MR- F55 Base CB Radio
Diesel #8-32 echo power mics
cobra 4 pin is pin1= shield, pin2= mic audio (usually the shield is wrapped around the mic audio wire).pin 3= transmit or push to talk usually red or white whichever isnt wrapped with the shield, and pin4 = receive or speaker complete
5 pin cobra=1-Audio 2- Shield 3-Receive 4-Switching Wire 5-Transmit, you can jump pins 4 and two
Dec 21, 2008 | Magnum 257 CB Radio
Transmits but does not Receive
Check your microphone by swapping with another duplicate. If no differance, you will need a SWR meter (standing wave ratio) to find the culprit. It attaches in line of the coax and determinds power out and reflected power. The reading should be 25 watts foward and max of 1 reflected.
Oct 22, 2008 | Cobra Mr F75b Marine Vhf Radio Fixed Mount...
Cobra Mr Hh425li Vp Marine Hand Held Dual Band Transceiver Logo
Top Cobra Boating Experts
RFburns
Level 1 Expert
Are you a Cobra Boating Expert? Answer questions, earn points and help others
