Bosch nexxt 800 washing machine
The select button next to the menu button does not work anymore (machine is 1 year old). I can go through all the menu options, but cannot select anything. Machine works fine otherwise.
  • 15,935 Answers
It appears your touch panel has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
I have a 2009 bosch 100 series washer that won't wash or spin, but will drain?
I realize that this post really old but I wanted this to be available for the next guy. I bought Bosch part number 154740 which are brushes that worked for me. They will tell you it wont work but it did for my Bosch (wfmc1001uc/09) washing machine.
Mar 06, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
How do you shut off the annoying Bosch Nexxt 500 Dryer wrinkle guard?
Click HERE to get the Users Manual for your machine, from what I can see, it's in the selection option of the machine.
From the manual:
Select the option to be changed with the "Menu" button. Press the button to move to the next option on the display. The active symbol starts flashing.
The current active option setting is displayed on the right. These settings can now be changed with the "Select" button. Press the button to jump to the next possible setting. Pressing the "Menu" button again saves the setting. If you don't press any buttons for 10 seconds the settings are saved automatically.
Hope this answers your question. Please rate and comment. Thank You
Joe
Sep 01, 2011 | Bosch Nexxt 500 Plus Dryer
Bosch Nexxt 800 series. We have continued problems with the message "suds or blocked pump" we use HE detergent.. what else?  I have drained it once.. it seems that it continues to not pump out the...
Hello,let the machine rest for a while so suds can disappear then unplug the unit for 1 min then plug it back in it should drain by its self if not do not select wash cycle but a spin/drain then you should hear the pump running, if you don't hear the pump running you can get a wet/dry vac stick on the drain hose and empty the washer, that way if water does not come out you have to access the pump and pinch off the drain hose from the tub and remove the object from the pump, be careful that you don't have a mess with water leaking from the tub good luck.
Thanks
Jun 03, 2010 | Bosch Nexxt 800 WFMC8401UC
TURN OFF ALARM
Assuming you have allready checked the operators manual, check again on page 19 for "Accoustic Signal".  To deactivate the signal select a program press two of the option buttons and hold until a short signal is emitted.  There you have it.
Jun 16, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
How do you clean the drain in a bosch next 800 series washer?
Almost all Bosch machines have a manual drain trap that usually can be accessed from a small door in the front panel. Open the door and you will see the trap access.
Jun 05, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Washing machine does not spin
Nexxt 100 Series WFMC1001UC Front Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 23, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washer will not spin
Carbon brushes in motor have worn down clean armture and replace brushes.
Nov 26, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Beeping on spin cycle
It is most likely out of balance, could be for many reasons.
1 could be too many heavy items such as jeans, towels, etc in one load.
2 could be the machine or floor is unlevel.
3 Could be a balance sensor needs replacing.
Mar 09, 2008 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
