Question about Ridgid Reconditioned 12 In. Compound Miter Saw
I have a Rigid 12 in sliding compound miter saw that squeels when turned on. How do I fix it?
It's a new saw. 1st day was fine. Then it started to squeel when you first turn it on. Then it stops when the blade reaches full rpm.
4 Suggested Answers
efs_perpends
  • 1996 Answers
SOURCE: 12 inch miter saw blade turns slowly and doesn't
There's no debris or wood jammed in the housing around the blade, is there? Try unplugging and removing the blade, to make sure some wood hasn't gotten wedged in there somewhere.
Otherwise, make sure the blade is on tight. If so, there is likely a problem with the motor itself.
If it's still under warranty, I'd contact Ridgid at this link: http://www.ridgid.com/Tools/Support/
Otherwise, they have a tools forum where you might be more likely to find someone who's experienced a similar problem.
Being reconditioned, it sounds suspect to me...
Sorry I couldn't be any more helpful...
Posted on Mar 26, 2009
  • 33 Answers
SOURCE: My blade gaurd will not automatically rotate out
MS12502 has a solid arm actuation to move the blade guard, this is either bent, broken, unattached or otherwise not functional. sometimes the moving parts get full of sawdust and a major cleaning is all thats needed. generally all woodworking tools should be blown out with air after each use or end of day.
actual model number of your saw would be more helpful.
Posted on Dec 02, 2009
SOURCE: Ihave a GMC (Ryobi) Slide
I have a question about your GMC miter saw-Please contact me at verng@craneengineering.com if you still have this saw.
Thanks,
Vern
Posted on Mar 17, 2011
How big of a Miter saw should i get?
a good 10 incher will handle most DIY jobs .compound slide saw
Mar 02, 2016 | Dewalt DW715 Heavy Duty 12" Single -...
DW718 miter saw base is pitting less then 2 years old, my 10" is fine
I wonder if you have been cleaning it with a cleaner that contains an alkaline solution as this reacts with aluminium and turns the bright bits black
Mar 30, 2013 | Dewalt 12" Beveling Sliding Compound Miter...
My brand new DW718 Double bevel sliding compound miter saw won't turn on
The only thing to do is go through the machines electrics bit by bit untill you find out the problem. First check the plug wiring (and fuse if 240V), then check the continuity from the plug terminals to the switch terminals to determine if the cable is ok. Always worth just popping the brush overs off and making sure the brushes aren't sticking. Any further than that and you should really have it checked by a professional. It should be covered by a twelve month warranty, and if there is a definate problem I know as a UK service agent we are instructed to just exchange the machine within thirty days of purchase/delivery (subject to workshop examination).
DeWalt European warranty info.
Jul 21, 2012 | Dewalt DW715 Heavy Duty 12" Single -...
Dewalt 12 inch compound sliding miter saw
This saw has locking indexing to set bevels for 52 degree crown molding the other common crown angle is 45 degrees, the bevel setting needs to be other than where the locking indexs are for the 52 degree crown. Problem is that the bevel lock does not securely hold at the bevel angle required. Is their an adjustment to get this lock to hold tighter.
Jan 04, 2012 | Dewalt 12" Beveling Sliding Compound Miter...
Nee the instruction manual for the dewalt dw718 compound miter
You can grab the manual and any replacement parts or accessories that should of came with it from eReplacementParts.com - They are DeWALTs supplier for manuals, parts, accessories, and tools online.
Apr 11, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
Craftsman 10-in. sliding compound miter saw
there should be a safety latch on the right ..down by the base or at the back you should have to press down on the saw to release it.hope that helps..
Jan 13, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Ridgid Reconditioned 12 In. Compound Miter Saw Logo
23 people viewed this question
Top Ridgid Saws Experts
ken skalski
John Trevino
Are you a Ridgid Saw Expert? Answer questions, earn points and help others
