Question about Akai CFTD2011 20 in. EDTV-Ready LCD Television
Dvd stuck in dvd
Easy question: DVD stuck in DVD player will not eject, how do I get it removed>
  • 2 more comments
  • sSandy65 Nov 18, 2007
    two dvds are in the dvd player which is built into the tv. how do you eject them?
  • Anonymous Nov 21, 2007
    I have a Mitsubishi dvd progressive scan unit that suddenly had the door not open. The unit promt says "opening" but it doesn't. I tried to pull by gently grabing the front flap to no avail.
  • techunsavvy Jan 06, 2008
    sony home theater system 5 disc dvd player. put a dvd in that was sticky on the middle section of the top(image) side. watched the whole movie, pressed stop, eject, tray came out but empty, then put the tray back and hit eject again but wudn't open. tried unplugging power/plugging in and restarting but still will not open. should i try to take it apart? dvd player is located below the left speaker (speaker and player attached) please help.
  • Anonymous Mar 23, 2014
    dvd tries to eject but only moves about an inch
There is a elease button on one side of the tray you can get to with a paperclip
Posted on Aug 27, 2007
How do I remove a stuck DVD?
It sounds like your problem isn't the dvd is stuck, since it seems to be spinning up, it sounds more like your ejection system has stopped working for some reason.
To fix either you are going to have to remove the outside case of the dvd player and expose the internal chassis. There are anywhere from 4 to 8 screws holding it on on the bottom and back of the unit, Make sure the dvd player is unplugged before you remove the cover.
Once you have the cover off, if the dvd is simply stuck, you should be able to see what the issue is; is it misaligned in the housing was it inserted incorrectly, are there in fact 2 dvds in the player, etc, etc. Gently remove the dvd and replace the case and enjoy.
If you can't see any reason for it to be stuck it may be the ejection system. The eject system will have a belt and sprocket system to move the tray or push out the dvd depending on the player. Make sure the belt is on the wheels correctly and that the sprockets mesh properly. If you can't see anything wrong try testing the ejection system with the case off.
Make sure you don't have any objects in or touching the dvd player, you don't want to short out any of the components if a screw fell into the dvd player onto the mother board, etc. Plug the dvd player back in, make sure you don't touch the inside and try to eject the dvd. Watch the ejection system and you should be able to figure out what is going wrong. Once you have figured it out unplug the unit and put the items back together. If you can see that something is broken then you will have to determine if you can have it fixed or if it wouldn't be cheaper to simply ditch that unit and purchase a new one.
Hope this helps.
Oct 12, 2015 | Televison & Video
19 in. Coby TFT LCD TV with side-loading DVD player. How do I remove a stuck DVD?
Hi Joanne, The eject button ( micro switch ) on the TV is defective. Please get it changed and the stuck DVD will come out.
May 28, 2015 | Coby Televison & Video
How to remove a dvd stuck in the dvd player in a gmc 2004 envoy
Most DVD players have a tiny hole on the front to mechanically push the internals to eject stuck DVDs. If the player does light up, sometime a thump with your fist is enough to jolt the mechanism. Failing that, you have to remove the player to get the DVD out.
Mar 01, 2014 | Cars & Trucks
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
Dvd player not working in honda odyssey
a cd player in a car takes some hammering(use wise)so when they go wrong replace it(cost of repair more than unit cost....)easy to remove/replace.
Jul 12, 2010 | 2004 Honda Odyssey
In the rear of the player is a small hole to eject the CD. Straighten a paer clip and push it in the hole to eject the CD.
Dec 22, 2009 | 2006 GMC Yukon Denali
We've got a DVD stuck in our DVD player in our Nissan Quest. The eject button won't work and the player is showing "No disk" on the display. The player is situated under the passenger seat facing the...
Page 4-62 of the Owners Manual for my 2006 Quest has this procedure for a stuck DVD:
1. Record the radio presets
2. Disconnect the negative terminal from the battery for five minutes
3. Reconnect the negative battery terminal
4. Check to see if the jammed DVD has been ejected. If it has not, try to eject the DVD by pushing the eject button.
5. If the disc cannot be ejected see your Nissan dealer for further assistance
6. Re-program the radio presets
I have used this procedure on two occasions, and it works.
The Owners Manual also says that playing DVD-R and -RW disk might cause the player to player to malfunction.
Good Luck!
Sep 22, 2009 | Car Audio & Video
DVD will not Eject
answer - had the same issue turned out to be 3 dvds in it, Remove the 4 screws holding the dvd player to the roof. wire harness will hold it up. There is an fm transmitter on top held on by three screws. remove the little screws and push the transmitter to the side. you winn now see the stuck dvds. push the extras out with a small screw driver. once they are out the eject button will eject the last dvd.
just worked for me hope this helps.
Jul 04, 2009 | Jensen 8.5'' Overhead DVD Player Package...
Akai CFTD2011 20 in. EDTV-Ready LCD Television Logo
472 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
