Question about LG BD390 Blu-Ray Player
Bd390 no disc - LG BD390 Blu-Ray Player
Get free view on my lg smart tv
if you are referring to the EPG Freeview, this can be easily accessed by Menu, system, settings and look for EPG settings, you can switch from the LG look or the Freeview look, but i can only summise this is what you are after as your question is a title statement and not a direct question
Aug 08, 2014 | LG BD390 Wireless Network Bray Disc Player...
Will the lg bd-390 play burned dvd-or+r,s or rw-dvd's?
The LG BD390 should read DVD+/-r if they are finalized. he same is true of DVD-rw discs. However, a lot depends on the burner and software you use for the burn. This unit will only support video mode, VR mode and AVHCD formats. It will also support DVD+R DL discs.
A lot depends on the movie and audio file codecs that you use to burn the disc. For a complete list of discs that are supported, see the manual. It's available here: http://www.lg.com/us/support-product/lg-BD390# .
I hope this helps. Please add a comment with the software and hardware that you are using to convert and burn your video for additional help.
Mar 28, 2013 | Televison & Video
After firmwareupdate, my LG BD390 player cant browse my PC:s shared folders anymore. Now I have to use some sort of media server software on my PC with win7 to be able to watch anything on my LG. Before...
I had a similar issue, but not due to a firmware update. It was the Windows Live Essentials update that caused my problems.
Try uninstalling the Windows Live ID Sign-In Assistant - Worked for me !
Dec 11, 2010 | LG BD390 Blu-Ray Player
We switched from cox Cable to Direct TV. The BD390 works normally through an Apple Airport Express with an Ethernet connection to a Motorola SB 6120 modem. The system does everything it is supposed to...
So practically you want to use the BR390 as an access point, to route the data from the Apple to the DVR. No, this isn't possible since the player doesn't have routing capabilities.
But you can do something else: instead of the Apple (which is just a very simple router with some minor extra capabilities sold ad an outrageous price) you could get a way better normal router for a lot less than $100 and connect all devices thru LAN cables in an local network.
Aug 17, 2010 | LG BD390 Blu-Ray Player
Hi there , I am trying to watch Planet Earth blue ray disc on lg bd 390 and for some reason any of the discs does not load (there is 6 of them).i thought it was a bad product and I asked for an exchange...
Try disabling BD-Live.
On the LG BD390 go to the Home screen then select the following:
Settings-->Network-->BD-Live Connection
You have three options: Permitted, Partially Permitted (default), and Prohibited.
Change the setting to Prohibited.
Now reload the disk and try again.
If that doesn't work try clearing the BD Storage (memory about the disks you play).
Again from the Home screen:
Settings-->Others-->BD Storage Clear
I think changing the BD-Live setting will stop the problem you're experiencing. If that works, you could also try changing the setting to Permitted.
I am experiencing issues with some of the very latest Blu-Ray disks, such as Avatar and Date Night. I don't have enough experience to be sure yet, but so far the evidence points to a new setting or standard in the disk industry that does not play well with the Partially Permitted default setting on the LG BD390 and a few other Blu-Ray players.
I hope this helps. Good luck.
May 22, 2010 | LG BD390 Blu-Ray Player
Ice Age blu ray sound is bad
i have the same exact problem - help!
Jan 05, 2010 | LG BD390 Blu-Ray Player
Connecting Linksys router with BD390 blueray player
I had a similiar problem with my BD390...Saw the SSID but not able to log on. I ended up performing a downgrade of firmware from LG's support page and corrected it. Afterwards upgraded firmware to current levels and works still ok.
Jan 01, 2010 | LG BD390 Blu-Ray Player
LG BD390 Disk Tray does not open. Pressing the button on the player or using the remote does not help.
PLAYER POWERS UP FINE BUT DVD DOOR WILL NOT OPEN AND KEEPS DISPLAYING PLEASE WAIT
Nov 26, 2009 | LG BD390 Blu-Ray Player
LG BD390 Blu-Ray Player Logo
21 people viewed this question
Computer Repairing
Computer Repairing
