Question about Maytag Dryers
DRYER WON'T START
Press the button and makes a humming noise. When I release the start button, it stops.  Removed service panel in back, to check to see if motor is locked up.  I pulled on the belt and the motor turned easily.
  • Maytag Master
  • 1,525 Answers
Check the door switch/ check wires make sure not loose / check capacitor at the bottom next to the motor it will have 2 wire coming of it this can stop the dryer working i hope this works
shaun
Posted on Jan 30, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Drum not turning
That is a bad sign. If the buzzing starts when you press the start button and stops when you release its almost safe to say that the motor has a dead short or grounded out and causing that to happen. You can check the start switch by getting a multimeter and with the dryer unplugged take the wires off the switch, place a lead on each pin and press the start with meter set for continuity. If it shows continuity when presed and stops when released your motor is shot and needs to be replaced.
Now if you press the start button and the machine starts to hum and continues to hum its possible that something has gotten caught in the blower wheel and binding the motor up. Depending on the make and model the location and access to it vaaries.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
Jun 06, 2012 | Kenmore Dryers
My dryer will only run if i hold in the door switch button and turn the drum while i hit the start button.
Jun 04, 2012 | Maytag Dryers
I have i kitchen aid gas dryer,when i press the start button it makes noise for about 3-4 second s then it stops and it won't start
Feb 27, 2012 | KitchenAid Dryers
Kitchen Aid dryer hums when start button pushed. I can get it to run if I physically spin the tumbler and if there is a very light load inside.
Dec 19, 2011 | KitchenAid Dryers
Dryer makes a loud buzzing, drum starts turning then stops. If i wait it will repeat
Mar 28, 2010 | KitchenAid Dryers
When you push start button, it makes noise but won't start.
This is a A.C. hum that you are hearing. this is a warning sign. You are experiencing motor failure. the actual windings inside of the motor are losing their potential to hold an even current due to breakage. the shutdown is a safety feature built in the control panel to prevent electrical spark/fire.
Feb 14, 2009 | Kenmore 659 Electric Dryer
Whirlpool gas dryer won't start
you most likely have a bad motor. Motors run around 100 dollars since the machine is 20 years old it would be a good idea to replace it with a new dryer. if i were you i would stick with a whirlpool product.
Oct 13, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
66 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
