Question about Whirlpool WTW5100SQ
Noise while spinning washer wtw5100sqd
Sounds like a loose belt
    Top Expert:
  • Whirlpool Master
  • 35,601 Answers
If it's a top loader, it could be a disintegrating flex joint under the tub
Posted on Jan 23, 2013
  • 1 more comment
  • rurben ramirez Jan 23, 2013
    it is a top loader direct drive sounds like coming from lower end soon as you can pull the knob pitch does not change 5 yrs old what the life of these doen't seem to last like they used to ,
  • Tom Chichester Jan 24, 2013
    In the washer business, 10 years is a lifetime. I spend up to 50% of the cost on repairs then replace it
  • rurben ramirez Jan 24, 2013
    good rule of thumb.. i took the entire shell off jumpered the lid switch ran it noise from apears to be water pump took pump off ran it no noise looked inside pump found a water bottle cap rubbing on impeller ....thanks for the tip got 5 years left then ..
2 Suggested Answers
djz83
  • 88 Answers
SOURCE: whirlpool washer making loud noise when spinning
It sounds like you need a bearing job. The bearings in the back half of the wash tub go bad. and the washer gets loud .It's an expensive repair. I hope this helps
Posted on Jul 02, 2010
Washer not working
The spinner's belt might be loose or broken, that's why it doesn't spin... Open the back part and you'll see inside the belt and the motor that makes the noise.
post me results...
Feb 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Loose belts on Maytag Washer LAT2300AAE
It is normal for the belts on this model to be loose. Normally the noise that you are hearing is either the damper (a white plastic type material,comes in a kit) or the pump making the noise. Take the belt off the pump and put it into a spin cycle and see if you hear it. If so ck the tub bearing for rust or leaking and the damper for wear. If you don't here it, ck the pump.
Mar 04, 2013 | Maytag MAV4755A Top Load Washer
Scraping, thumping, and whining sound as the washer drum spins. sounds like something may be loose inside. sounds like a loose belt squeeling?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
May 19, 2011 | Frigidaire Washing Machines
Very loud noise during spin cycle - drum still spinning at normal speed. sounds almost like a broken belt - are there more than one belt?
only one belt on machines, ur looking at one of the following
  • loose counter weight
  • something stuck in drum, eg bra wire, sock
  • bearings failing
  • broken shaft
  • machine not level maybe?
Sep 23, 2010 | Frigidaire GLTF1670A Front Load Washer
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Washer makes clunking noises.......
You didn't give to much detail about the noise, other then clunking. Does it sound like it's metal against metal? Does it sound hollow? When does the noise take place before, during or after the spin cycle.
The easiest thing to do is check to see if the motor is loose, or if you might have too much slop or slake in the belt, if you do then replace and readjust the belt.
Nov 16, 2008 | Whirlpool LTE6234D Top Load Stacked...
Kenmore washer won't spin
ok " sounds like motor belts need replaceing, that smell is the loose belt rubbing against the motor pully.
Jan 01, 2008 | Kenmore 12502 Top Load Washer
Maytag washing machine repair
The water pump may be going bad...Yes it probably is a bearing. Take the belt loose and try turning each pully until you find one that makes noise or is hard to turn. Pump and motor should both spin very easily with out noise.
Nov 27, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool WTW5100SQ Logo
178 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
