Question about Dell Inspiron Computers & Internet
Reinstall windows root system 32 hal.dll
Startup reads missing or corrupt fill reinstall windows root system 32 hal.dll
    Guru:
  • 571 Answers
Do a start up repair.
Insert your Windows Operating System disc in the DVD. Reboot your computer and press any key when you see the phrase "Press Any Key to Boot in CD".
Select the start up repair and it should work after the loading process.
I hope this helps.
Carlo
Posted on Jan 23, 2013
acdr
  • 1913 Answers
SOURCE: my asus eee pc 900 wont work
open the cpu cover then refix RAM then checl if problem still remains
then u have to reinstall reapir win xp
Posted on Dec 31, 2008
SOURCE: im missing a windows system root 32 hal.dll. file
HAL.DLL error seems to be caused by corruption of the MFT and root directory. This usually results from a blue screen crash when playing flash video from the web.
The easy fix: Press ALT+F10 at boot-up and run the factory restore. This will lose all of your installed programs and data and restore the machine to its original state.
The 'get your data back' fix: You will need a second (working) XP PC with a CD ROM drive and a standard Windows XP CD (a manufacturer's 'factory restore' disc will not work.)
Follow the instructions here http://komku.blogspot.com/2008/11/install-windows-xp-using-usb-flash-disk.html to create a bootable XP USB memory stick. Also copy C:\WINDOWS\SYSTEM32\AUTOCHK.EXE onto the memory stick, You may need that later. DO NOT follow the part about booting off the stick and deleting partitions. Instead...
Boot off the memory stick and select the TXT option. Follow the options to get to the recovery console. Run CHKDSK C: at the recovery console. Once CHKDSK has finished, reboot and everything should be fine. You may find the console asking for the location of AUTOCHK.EXE. It is on the flash drive, which (I think) is mapped as drive U:
Keep the memory stick with your Aspire One at all times, because you never know when you'll need it. Mine has done this about four times in six months.
Posted on Feb 07, 2010
EngineerGR
  • 119 Answers
SOURCE: windows>\system32\hal.dll. corrupt
HAL.DLL Missing or Corrupt
If you get an error regarding a missing or corrupt hal.dll file, it might simply be the BOOT.INI file on the root of the C: drive that is misconfigured
Insert and boot from your WindowsXP CD.
At the first R=Repair option, press the R key
Press the number that corresponds to the correct location for the installation of Windows you want to repair.
Typically this will be #1
Type bootcfg /list to show the current entries in the BOOT.INI file
Type bootcfg /rebuild to repair it
Take out the CD ROM and type exit
Regards
Posted on Mar 28, 2008
  • 58 Answers
SOURCE: Can't start up Windows says I need to reinstall
That file can be found on the XP installation CD.
You will need to boot up on that CD and select recovery console. Try this:
http://pcsupport.about.com/od/fixtheproblem/ht/restorehaldll.htm
You may also be able to boot up to Safe Mode Command Prompt and run system restore:
    1. Restart your system
    2. When the system first boots, type F8 to bring up the boot menu
    3. Select the Safe Mode with Command Prompt option
    4. Log-on as administrator if needed
    5. At your command prompt type %systemroot%\system32\restore\rstrui.exe
    6. Hit Enter
    6. This will open the system restore wizard
Posted on Mar 14, 2009
rtrahan
  • 741 Answers
SOURCE: windows could not start because the following file is missing .
Yes the hal.dll is one of the files it needs to boot up, It gets all of the hardware together..I own and ASUS and they pretty good about sending disk. Pull the disk out that came with the system. Just put it your CD and then go into Windows Explorer and look for that file. Its probably under i386 folder or Win32 folder. Once you find it then just drag it over to the c: drive and you are ready..I didn't get a cd player in mine, so you probably didn't either. I ended up buying one from Best Buy, it works really good, it's an HP.But anyway if you can copy that file over to the C: drive of your computer then you will be ok...it didn't way anything else did it> Let me know how it turn out..
Posted on Mar 25, 2009
Notebook says that windows could not start because the following file is missing or corrupt <windows root>/system32/hal.dll.
Causes of the missing or corrupt hal.dll error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
To fix it:
1) Restart your PC, sometimes the hall.dll error could be an error itself and your PC should boot up fine.
2) Go into the BIOS by pressing the Delete key as the laptop boots. Then navigate to disk boot priority and make sure this is set to your main hard drive (the one that has Windows installed on it). Save and exit the BIOS. Sometimes if you have a USB flash drive/Pen drive or external hard drive it may automatically switch the boot priority to that.
If these two quick steps don't fix the problem then head over to here and continue reading up about repairing the boot.ini file.
Mar 10, 2011 | NEC PKM35-4A33 Buzzer (802870018009A) PC...
Have acer aspire one, when started got screen saying file missing or corrupt window root system 32 hal.dll, nothing else cannot bring up safe mode do not have windows xp cd, in nursing home cannot afford...
I am going to start with the assumption you have already tried to reboot, then next choices from there go kinda like this...
Run windows XP restore from command prompt. (From safe ,mode type C:\windows\system32\restore\rstrui.exe and press Enter. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
Replace the boot.ini file (run msconfig) This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Right click on c: drive, click on properties, then tools, click on the error checking button, the put a checkmark in each box, Click start and it may say it needs to run on next reboot click OK the reboot. The physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Run a repair install of the operating system. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Nov 29, 2010 | Computers & Internet
My PC wont to start .its says to reinstall windows root system 32 hall.dll
go here to download it on another computer>> http://www.dll-files.com/dllindex/dll-files.shtml?hal
unzip the file onto a USB zip drive than go plug that into your computer and install it. should be pretty simple if it doesn't work try going here and reading up for other possible solutions >> http://social.microsoft.com/forums/en-US/tabspace/thread/b82154ee-6dfd-4ed6-8450-cb22cce444f5
Nov 14, 2010 | Computers & Internet
Unable bootup & error prompt that HAL.dll file missing or corrupt
CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
Resolution
  1. Restart the PC. The hal.dll error could be a fluke.
  2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
    Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
  3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
  4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Nov 09, 2010 | Acer Aspire 4720 Notebook
Hal.dll file missing or corrupted
Follow the steps given in the link below to troubleshoot the hal.dll missing issue:
http://support.microsoft.com/kb/945380
Aug 26, 2009 | Microsoft Windows XP Home Edition with...
I DID A FORMATT FOR MY LAPTOP , BUT THERE IS A
The CD you are using to install the operating system had corrupted .try using another recovery disk.this will fix the issue....
May 10, 2009 | Toshiba Qosmio G35-AV600 Notebook
Windows system 32 hal.dll error after restoring e-machine
There's actually a number of reasons why these annoying little DLL errors happen, but the most common, is caused when new programs are installed over all old ones and the old ones are not completely uninstalled 100%, causing registry pile ups and of course, getting a .DLL error messages.
Another reason, is damage that's been done by malware/spyware/adware programs, attaching themselves to your PC and wrecking havoc, deleting crucial DLL files from your PC.
The hal.dll file is created during install from 5 other dlls. HAL is the Hardware Abstraction Layer and it's the interface between the system drivers and the actual hardware.
Copying hal.dll will not resolve the problem.
A lot of times the file will be reported missing due to corruption of the boot sector or of the file system
Causes of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll file or a hal.dll file that has been deleted or moved from its intended location.
Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged HDD.
Suggested remodies-
5. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
6. Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
7. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
8. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Important: If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
9. Replace the hard drive. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
10. Perform a new installation of Windows XP after installing the new hard drive.
I have not tried it - but HERE is a free program purporting to fix the error.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Apr 10, 2009 | E-Machines eMachines Desktop PC
My asus eee pc 900 wont work
Dec 31, 2008 | ASUS Eee 900 Notebook
Windows>\system32\hal.dll. corrupt
Regards
Mar 26, 2008 | HP OmniBook XE3 Notebook
Computers & Internet Logo
272 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
