Question about KitchenAid REFRIGERATOR DRAWER
My refrigator drawers stopped working so I replaced the harness and had the control board refurbished. Now the top drawer still won't cool but bottom works fine. What should I try next?
aborcass
  • 2651 Answers
SOURCE: kitchenaid ksrj25cnst refrig does not cool but freezer is fine
sounds like you have a defrosting iss\ue here, ther is aduct on the left sideof refig wall perhaps 3/4 the way down usually behind one of the crispers its frozen over with ice not allpwing fresh food air to properly circulate, l;ook to the bottom of your freezer on the back wall is there ice on the panel?? if so your not deforsting properly there satech sheet underthe kickplate showing basic wiring and trouble shoooting guide as well
Posted on Apr 06, 2008
peyton32034
  • 410 Answers
SOURCE: Superba fridge 1992 occasonal water under bottom freezer drawer
you have a frozen defrost drain. in order to fix this you will need to remove all shelves and basket out of the freezer. then remove rear evap cover. one youve gained access to this area you will see at the bottom of the coil an aluminum pan that most likely wil be iced over. clear away this ice then try to flush out the drain line with warm water. sometimes its neccessary to force water into drain line with a large syringe or turkey baster. this should fix ya up.
good luck and thx for using fixya Peyton
Posted on Jan 28, 2009
  • 52 Answers
SOURCE: water in top drawer
I am not a repairman but have installed several duel drawer dishwashers. Most dishwashers have a check valve preventing backflow. Water under pressure will always follow the path of least resistance and in your case it is going into the upper drawer. Be sure the drain is open and flowing easily under your sink whether that be the disposal or a TEE. It may help if the drain line is elevated as high as it can go under the sink just before it reaches the drain. How often do you use the top drawer? Perhaps run a cycle on the hottest cycle without dishes to attemt to clean or force through any contaminants in the check valve through into the drain. Hope this helps, Ken
Posted on May 08, 2009
  • 52 Answers
SOURCE: Freezer works fine fridge doesn't cool properly
Probably the defrost timer is bad. It can be replaced.
Posted on Jul 14, 2009
  • 13 Answers
SOURCE: wheels on drawer broke off and I need to replace
This is the manufacturer's link to their parts list for your model:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208198977.pdf
Original link with manuals, customer service numbers, etc:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KSCS25INSS&siteCd=KAD
Hope this helps!
WizardRepair
Posted on Jul 17, 2009
I replaced the control board and display, but it appears the touch pad is the problem. Can I buy it separately?
Hello. The part number you need for the control panel/switch assembly is 74011491. The actual oven control unit is 74011494. The following list shows some(but not all) of the error codes you might encounter. I hope this helps you!
1c1c shorted key
1c2c membrane keyboard disconnected
1c4c board to board communication failure...." "
1c6c EEprom hardware fault..........................." "
1c7c control not calibrated............................... replace main board
1c8c eeprom crc error--user options..............." "
1c81 eeprom crc error--cook profile................." "
4d21 no cooling fan rotation
4d31 cooling fan on when de-energized
4d41 cooling fan overspeed
4d51 door switch circuit fault
In the service manual, there was no "warming drawer" error code listed in the code chart.
Aug 29, 2015 | Jenn-Air JES9750BAS Stainless Steel...
Top dishdrawer won't open no power
The most logical explanation is the controller in top drawer has packed up or the power board located at the base of dishwasher housing (under bottom drawer) has partially packed up and stopped supplying power to the top drawer controller. But another explanation is that the thermal relay in the top drawer (located inside the heater element assembly has cut off. This stops power to the controller. This is the most expensive to fix as the entire heater element assembly has to be replaced as the thermal relay is not separately accessible. How you want to isolate the problem and fix it depends on how comfortable you are with fixing electrical and electronic systems. This is a very sofisticated dishwasher and a small mistake is irreversible. By the way you can open the drawer by forcing it open but keep in mind not to try to shut it firmly again until you restore the controller power. Otherwise the lid seal or actuator motors will be damaged. Whatever you do, make sure the mains power is turned off if you work on the dishwasher circuits.
Feb 16, 2014 | Dishwashers
Fisher Paykal 602 dishwasher - top drawer won't power on
Most likely the thermal fuse (inside heater assembly) is blown.
Not easy to repair. Need to replace the whole heater at the base of drawer.
Mar 28, 2013 | Fisher and Paykel Dishwashers
Sharp CD-BA2100 cd drawer won't turn or close.
Take the 4 screws out of the top, lift the CD drawer out, disconnect the two wire harnesses, take the top off, lift the 3 disc tray out, then force the drawer open and closed a few times until it slides freely. Put it back together and it may or may not work. Worked for me.
Mar 28, 2013 | Sharp CD-BA2100 CD Shelf System
Top drawer on F&P dish drawer stuck on cycle & continuously beeping
You could isolate the top drawer by taking the controller power cable out. DIsconnect mains power to dishwasher, open top drawer and remove front cover carefull after removing 2 plastic pins on each side with plier. Controller box is on left top side, remove bottom connector and cover with insulation tape. Put things back and turn power back on.
But if you want to find the fault with top drawer then that is very trick if there is no fault code on panel except beeping First clean the top panel inside door with a clean damp cloth. If this does not change the situation, then it is very likely the controller is detecting some faulty sensor - and will need to find one by one. Are you ready for it?
Dec 17, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
Gaggia Digital Syncrony dredge drawer error won't
Hi
Do you still have the tab on the left side of the dredge drawer? If you do, you can loosen the 2 screw just above the slot wherer you put the credit card. Push down on the plastic ramp in the slot as far as you can, then holding the ramp down tighten the 2 screws. If you don't have the tab you will need a new dredge drawer. Also on some machines the drip tray will lift the dredge drawer and it will give this message. There is a extra piece of plastic in the 90 deg. notch that can be trimed out to stop it from lifting the dredge drawer.
May 14, 2011 | Gaggia Syncrony Compact Digital Espresso...
Meat and vegetables placed in the produce drawers turn to ice. fridge temp set at 39. freezer set at 0. as you face the fridge, the drawer on your left is the worst. fruit is okay in right drawer.
check the damper door vent assembly located between the freezer and refrige compartments and make sure its not frozen open so as to let cold air in all the time,adjust the temp in the refrige and the door should open and close with adjustments,if not then damper door motor assy or the electronic control board is defective that supplies power to this door
May 13, 2010 | GE PDS22MCR Bottom Freezer Refrigerator
M# 596.72219200 Kenmore with bottom drawer refrig keeps freezing
That is a broken thermostat control part number 67003000 when they stop they can break while on or off. Sea Breeze
PART NUMBER AND MODEL SEARCH FEATURE
Jul 23, 2009 | LG LSC26905TT Side by Side Refrigerator
F&P DD 603
Same thing just happened to me. There was a slight leak from the top drawer and it wet the tray on the bottom which caused a short and the circut board and the plug to the top drawer melted. I need to replace the board and wiring harness and am looking for a manual to find out how to remove the faceplate on the top drawer. What you should do first is remove the bottom drawer and check dry the bottom tray if it is wet. There are two circles on the side of the drawer on either side. Turn these with pliers and release the plastic clips on the ends of the drawer slides. you will then be able to pull out the drawer and inspect. Good luck
Jul 14, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
KitchenAid REFRIGERATOR DRAWER Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
