Question about Dishwashers
WHIRLPOOL DISHWASHER PERMATURE CUT OFF
UNIT FILL AND RUNS FOR MAYBE 15-20MINS THEN JUST CUT OFF PREMATURLY.
  • 17,130 Answers
Check filters , clean the pump and make sure the inlet water pressure is good .
Click on Maintenance
Posted on Jan 24, 2013
4 Suggested Answers
SOURCE: I have a whirlpool dishwasher (gu2500xtpq6) wont fill up
whirlpool gold starts the soaking time but dosnt run after that the time remaing light just blinks
Posted on May 01, 2009
rylee_smith
  • 8619 Answers
SOURCE: Dishwasher turns on but does not fill.
Hi
Thanks for using FixYa. To start with check the water inlet valve which is located behind the lower access panel on the left or right side of the Dishwasher. If the water inlet valve is bad you have to replace it, also check the main water line for clogs/obstructions. If still the issue is not resolved then it’s a bad float switch and needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 20, 2010
HoweToFix
  • 49 Answers
SOURCE: du1055xtsd2 whirlpool dishwasher runs but
A few things could be wrong.
It can't cycle without water. be sure you have water at the valve under the dishwasher. You should be able to see it by dropping the front plate under the DW.
If you have water pressure, then check for voltage (120) at the valve with the timer calling for water. ( start of cycle).
If you have voltage and pressure, replace the valve.
If you don't have voltage, it could be the little switch inside the DW. It pulls up and down. The level switch could be bad.
If that doesn't do it, it may be the timer or the door lock interface.
Good luck.
Posted on Oct 13, 2010
Whirlpool Dishwasher Model Du850SWPB3 Changed out Water valve, float switch, Still doesn't fill with water. D/w runs in all cycles , just NO WATER.
What ya need to check is for power coming into the water valve from the control board by using a mulitmeter set to measure ac volts and when the dishwasher is running...during the times the unit is supposed to fill their should be power into the water valve.
If ya do not have power into the valve the control is going to be the problem,if ya do indeed have electric power into the valve during the fill times ya need to check the house water supply and make sure GOOD water pressure is available at THE VALVE
GENE
Sep 30, 2011 | Whirlpool Dishwashers
Dishwasher comes on and goes though all the cycles but no water! Is it a easy fix and inexpensive fix or do i need to think about a new one. Thanks for any help you maybe able to give me.
Two things to check, first make sure the water is on to the dishwasher itself. Second, if
the fill solenoid (12 to 28 dollars usually) has failed, the dishwasher will not fill. It is
a fairly simple fix and can be done with the dishwasher in place. Just make sure power
is off and water is off when changing out. Model and serial are usually inside the door of the
unit.
Hope this helps.
Jun 26, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Turns on and runs cycle but does not fill with water
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Oct 26, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher turns on but does not fill. Motor runs, lights are on, buttons respond to pushing them, but doesn't fill. Whirlpool 24in DU927QWD
Hi
Thanks
Rylee
Jun 20, 2010 | Whirlpool 24 in. DU927QWD Built-in...
Dishwasher still runs but there is no water getting into the dishwasher.
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Jun 06, 2010 | Whirlpool 24 in. DP840D Free-standing...
My dishwasher water will not shut off. Whether
first thing to replace is the fill valve.check to see if there is power supplied to the valve when the unit is off.if there is then replace control board
Mar 12, 2010 | Whirlpool 24 in. DU1148XTP Built-in...
Whirlpool 350xt-4 model dishwasher runs, but does not clean. What can I do?
maybe you are overloading the unit,try less you may get better results.
Jul 15, 2009 | Dishwashers
water level should be approx 1/4--1/2 inch below the heating coil.. this is normal fill level
Apr 28, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Jackson 200B Series Commercial Dishwasher Fills With Water and Drains
Could be one of two things. 1 - The cheap fix might be that the probes in the wash tank are dirty. There might be a "coating" on the probes that prevent the sensors from knowing that the water has reached the proper levels. 2- Replace part "Liquid Level Control" - $$
Apr 03, 2008 | Dishwashers
Whirlpool dishwasher Model DU9450XY-1
it may have a cracked tub does it drip out of the tub brace (a strip of metal that runs side to side on the bottom of the tub behind the wash motor) Have replaced several for this issue. Have fixed them with good epoxy also. PLEASE rate my help as solved if i answered your question!! Thankx
Oct 03, 2007 | Dishwashers
Dishwashers Logo
35 people viewed this question
Top Dishwashers Experts
