A have a box on my sharp aquos tv that says k 46le600e(a)tvcrw 11111 on my screen how do i get rid of it
  • 71 Answers
SOURCE: Sharp Aquos LC-42D62U VOlume Control
OK guys I'll save you. The tv is in hotel mode. To get it out from there you have to go in service menu but DO NOT CHANGE ANY OTHER THING IN THERE, only what i tell you. With the tv on and the K letter on the screen press in the same time vol- and ch- on the tv set. Now you'll be in service mode. On the remote press down arrow (not -channel) and you'll see up industry init. go there with ch- and press vol+ and enter. let the tv like that for few seconds and the tv will go green and hopefully industry init succsesfull will be on the screen. After that unplug the tv and replug it. Done!
Posted on Dec 06, 2007
SOURCE: Clean screen
I used the Monster "Screenclean" kit, which left a film on my screen. I am not happy with it. Any suggestions on a different product which will remove the film?
Posted on Jun 06, 2008
SOURCE: Programming the Acquos Remote
I got a a sharp LC-32D43U and for my motorola cable box i use hte code 31 from jerrold, i take it from the manual and i got it tryin every single code unti i get one that works.
Hope it works for you
Posted on Oct 21, 2008
SOURCE: Sharp aquos lcd screen goes blank
i was having these same problems with the screen going black, and i found that when i hit the back of my tv it would work sometimes. so, i improvised on some of the advice on this page and so far no problems. here is what i did (its very easy):
1. lay the tv on the floor and take off the back panel. (i think 12 screws)
2. on the right side of the tv (as you are looking at the back) you will notice a large metal covering that is held in place by 6 screws. unscrew these and remove the metal cover.
3. you will notice that the three screw holes on the left side of the board have some sort of metal or solder around them, in sort of a star pattern. when i looked closely i noticed that most of the metal (solder) was tarnished, or kind of blackened. (this must mean that the ground screws werent getting a good connection and this would explain why it would work sometimes when i hit it because it would vibrate the screws enough to get a good connection! )
so, take a pencil eraser and erase all the black or tarnish off the metal surrounding the screw holes. thats it! (to be safe i took some sandpaper and cleaned up the screw holes on the back of the metal covering, but i dont know if that was necessary)
at this point i followed another gentleman's advice to do a hard reset. this involved unplugging the 8 connections although i dont know if this was really necessary because i believe my problem was a ground issue. i did it just to be safe. his advice is on this site if you want to do this step.
4. i put everything back together and it worked! i performed a soft reset at this point which puts your tv back to factory settings. just go to menu>setup>reset>return to factory settings? yes
this will turn your tv off and back on. that's it. so far so good for me.
Posted on Dec 18, 2008
  • 6 Answers
SOURCE: My Sharpe Aquos TV screen stays black even when switched on!
Call up Sharp, if you are part of the AQUOS Advantage Program, you get FREE in home service along with the repairs for it.
They'll give you a case number, set you up with a technician and BAM!
I called on a Wednesday and got an appt for that Saturday for the technician to come to my house.
I doubted Sharp alot less after that.
Posted on Sep 03, 2009
I have a Sharp Aquos LCD TV Model LC-32BX6M , when I try to connect a new generation Android TV Box HDMI Out to TV's HDMI input the Android Logo appears and after sometime the screen goes blank t
im not sure but could it be a comparability issue with the device and the wake up signal from the device to the tv? android systems use a Linux based file system, so the problem may be in the tv's input settings. hdmi input from the device to the tv. and then go to tv input mode and see if putting the device in another hdmi port doesn't work.
Oct 15, 2012 | Sharp Aquos Televison & Video
My sharp aquos tv screen color gone and the colour settings is blocked and cant be used..what will I do to return its tv screen color
If the adjustments you need are blocked out either it is that something that is connected to the set for signal (cable box, sat box, receiver etc) is now in control or in some fashion you have locked out the option yourself--I would have a good look at the owner manual first and if that fails call sharp with the model number----if you recently hooked something new up to the set or moved set from one location to another it may have happened then.
May 19, 2012 | Sharp AQUOS LC-32D44U 32 in. LCD TV
We have a Sharp Aquos TV with an annoying black box in the upper left hand corner of the screen. How do we get rid of it?
You may have PIP or picture in picture turned on and set to a input that has nothing connected to it. That's why the box is black. There should be a button on the remote for PIP. Try to turn it off. Or turnit off in the menu.
Jan 24, 2010 | Sharp Televison & Video
Can I use the AVC system of a Sharp LC 30HV4U on a LC 37HV4U TV
i have the sharp lc-30hv4u but i dont have tha avc box i need buy the box if do you have i can buy call me 702 3280184 thanks
Oct 15, 2009 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Two little yellow boxes on my screen
How small are the boxes? If they're extremely tiny chances are what you're looking at are called pixels and they're stuck. There are several ways to fix stuck pixels, try the ways listed here- http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
or
http://www.jscreenfix.com/
If it's not a stuck pixel(s) try resetting your tv to default settings by selecting ' restore factory default ' or ' restore default settings ' in the tv's menu.
May 30, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos LC-42D43U LCD TV
Well, the good thing you got a new TV out of it.
The best and easiest thing to do is sell it on your local Craigslist.
The parts inside the TV can be used to repair other TVs that have no damage to the screens. I would say $100 for the whole thing would be fair price for all the parts inside.
If nobody wants to buy it on Craigslist, go to Shopjimmy.com and contact them if they want to buy the TV from you. They're all about recycling parts.
Apr 23, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Can't retune sharp aquos lcd tv
This is the best place that's near the manual you need.
They have the LC32D44E manuals, but not the "BK" at the end. I think the "BK" just means BLACK.
But, I think it will work for your TV.
Here's the link:
http://www.sharp.co.uk/page/downloaddrivermanuals#
Click on the "Sharp Europe - Manuals and Download "
Then, Operation Manuals
Then, LCD-TV
Then, put your TV model# for the search.
Apr 21, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Turn off closed caption on input(component) on Sharp Aquos 42"
I have a Sharp Aquos 46" and go a Comcast HD receiver as well, and had the same problem turning off the Closed Captioning. I order to turn it off you need to go into the box user setting by (starting w/ the cable box and tv on) pressing the power button for the cable box then the menu button for the cable box. This will open up the user settings menu. Just toggle CLOSED CAPTION to DISABLED.
Jan 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
