Question about Sport & Outdoor - Others
Loss of spark on 2001 srx lost all three coils
What is the diagnostic procedure for ohming out the stator? already ruled out kill,key switches
1. Disconnect AC Magneto Coupler. (Located on right side of sled under the black 2" cooling line)
2. Connect meter. OHM x 1
White/Red - White/Green
189 - 231 OHM at 20 degree C (68 degrees F)
Charge Coil Resistance
White - White
.36 - .44 OHM 20 degree C (68 degrees F)
If out of spec replace.
Posted on Feb 07, 2009
2001 ktm 300 mxc not getting a spark what would cause not to get a spark
A few things,start simple disconnect the kill switch,remove the spark plug cap from the wire,check all your coneections from the stator to the cdi box to the coil.Still no spark your going to need a multi meter to check the stator and coil.If all this checks out to be good then it is your cdi box.A word of caution test these parts before replacing as they are not returnable and could get costly.A good shop could diagnose your problem in hour time.It may be money well spent if you do not understand your bikes ignition system.
May 29, 2014 | 2001 KTM MXC 300
I have a 1975 Harley SX 250 with a very intermittent spark.
If your points are sparking as it is running, replace your condenser. I would do that first anyway. You can put any condenser in it., A condenser is a condenser. Make sure your new plugs, points and condenser are all operating correctly. You have probably already done all that but it is all I can think of.
Mar 31, 2014 | 2005 Harley Davidson FLHRSI Road King...
Mx360 cdi circuit
Hi, Anonymous all this electronic brain surgery is above my pay grade Good luck and have a wonderful day.
Jun 24, 2017 | Yamaha Motorcycles
Changed the CDI, Magneto, and pick up coil, on Kazuma Falcon 90 ATV. Still no spark.please help.
I'm having the same problem with my Kazuma falcon 250. No spark, the stator shows good ohms and I just replaced the CDI box and still nothing. I'll check the kill switch and reverse override.
Apr 29, 2011 | Sport & Outdoor - Others
What would cause my car to not send spark to the spark plugs
The first thing is do you know when the last time was that the distributor cap, ignition rotor, and spark plug wires were changed?
There is the possibility that the ignition coil is faulty and first check to see if full battery voltage is getting to the "Pos" (+) positive side of the ignition coil when the key is in the "Run" position, and also that full battery voltage is getting through the "Pos" (+) or positive side of the ignition coil and over to the distributor ignition module, dis-connect the wire connector from the ignition module and if battery voltage is not present at the connector to the ignition module with the key in the "Run" position but it is present at the "Pos" side of the ignition coil, then the ignition coil is faulty. If battery voltage is present then check the ohms between the high tension terminal (where the coil wire goes on the ignition coil) and the "Pos" terminal on the ignition coil by first dis-connecting the wires from the ignition coil and then test with the "Neg" lead from the ohm meter in the high tension terminal on the ignition coil, and the "Pos" lead from the ohm meter to the the "Pos" terminal on the ignition coil, and the ohm reading should be between 6,000 and 30,000 ohms and if not replace the ignition coil. A faulty ignition coil can also damage the ignition module.
The ignition module and the pick-up coil/stator located inside of the distributor is what generates the signal that the ECM (Engine Control Module) uses to time and fire the fuel injectors, as well as the signal to run the fuel pump and the dwell signal timing to fire the ignition coil, and a faulty ignition module can cause any one of these systems to malfunction.
That could be a malfunction with the ignition module inside of the distributor, and you can remove the ignition module and have it tested for free at most auto part stores. If the ignition module does test out alright then the problem could still be in the pick-up coil/stator, (it can be tested using an ohm meter by dis-connecting the wire connector from the pick-up coil/stator and the ohm reading between the two wires from the pick-up coil/stator should be between 500 and 1500 ohm's, and both of the wires from the pick-up coil/stator should show an open loop or an infinite reading between each wire and ground) and if the pick-up coil/stator is found to be faulty then replace the entire distributor, or the distributor will have to be dis-assembled to install a new pick-up coil/stator.
If you do purchase a new ignition module be sure that it does come with a silicone grease or a die-electric compound because it is a heat sink and the ignition module will burn up without it.
To install the new ignition module first clean out the mounting surface inside of the distributor. Then completely coat the metal contact surface under the ignition module with a thick coat the silicone grease or die-electric compound and do not leave any of the metal contact surface of the ignition module un-coated with the silicone grease or die-electric compound, and be very careful not to over-tighten the ignition module or it will be damaged.
Let me know if you require a firing order diagram any further assistance with testing or diagnostic procedures.
Jul 29, 2010 | 1995 Chevrolet Blazer
2005 cbr 1000rr won't fire, just turns and turns, installed new battery, just bled and fixed my clutch line, HESS light does go out, help me out please
check fuel pump fuse if that's o.k. turn key on and feel the pump or listen to see if its priming. if the pump is doing its job then you have a spark issue...pull out one of your plugs and hang it so it touches a bolt or part of the frame and see when you start it that it has a nice big blue spark.if this doesn't work then check the kill switch circuitry.. the tilt switch could have been tripped when fixing you clutch line. i heard that you can reset it by cycling the kill switch, turn key on cycle switch, then try again. The tilt sensor im not sure exactly but may be located between your headlites or under the front fairing. The tilt switch kills power to the injector banks. Hope this info helps.
Apr 02, 2010 | 2005 Honda CBR 1000 RR Fireblade
Hi,i have a sunl slu-6k,its not getting any fire.I have changed the coil,stator,cdi,key switch,voltage regulator and the wiring harness.Can you give me some help with this because im lost. thanks steve
Chances are it is a grounded kill switch on the handlebars or a side-stand / center-stand kill switch that has gone bad or is out of position.
Stick in a new spark plug also.
Sep 13, 2009 | 2005 Kymco Xciting 250
95 Kawasaki 900 zxi, no spark
magneto stator can also be a solution check for AC power from stator while cranking the motor use sta-bil winterizing fluid to insure piston where during cranking process spray directly into spak plug holes with spark plus out 4 sprays into each cylinder should be enough crank motor without plugs for reduced compression and more cranking amps
Jul 21, 2009 | Boating
LOSE OF SPARK
Pull the plug back out of the cylinder and ground it against one of the head bolts, kick the engine over to see if you are getting a spark.
Nov 12, 2008 | 2008 KTM 105 XC
Sport & Outdoor - Others Logo
100 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
