Question about Samsung Televison & Video
What is the sky remote code for Samsung 3d plasma PS51E490
SOURCE: tuning the sky remote.
Phone LG service in Slough, they have the info
Posted on Oct 13, 2007
  • 44 Answers
SOURCE: samsung plasma tv
Samsung codes for sky reomte 0060 065, 584, 037, 245, 476, 398, 516, 292, 318,
037
Click here for the link
Posted on Jan 21, 2008
geordie rob
  • 7 Answers
SOURCE: Struggling with Sky remote codes for new Samsung TV LE32A457
0060, 065, 584, 037, 245, 476, 398, 516, 292, 318,037
these are samsung codes for sky remote
good luck
Posted on Dec 29, 2008
  • 37 Answers
SOURCE: what is the sky remote code?
These codes are for Samsung, one of them will work: 065, 584, 037, 245, 476, 398, 516, 292, 318, 037
Hope this helps
Posted on Mar 22, 2010
nainamainaka
  • 380 Answers
SOURCE: virgin remote control code for volume on my 50" samsung plasma tv
To set up the volume control on your Telewest remote control, to be able to change the TV volume, please follow the instructions below.
1. Using the table below find your make of TV and the code which matches it.
2. Press and hold down Volume + and mute on your remote control at the same time for at least three seconds, until the green light in the top right-hand corner of your remote control flashes twice.
3. Release the buttons and enter the first four digit code from the table below. (You must do this within ten seconds).
4. As you enter the first three digits the green light on your remote control will give a short blink.
5. As you enter the fourth digit, the green light will flash twice to confirm that the volume is set.
If setting the volume is not successful, please repeat the above steps with the second or third codes from the table below.
Samsung 0065, 0584, 0037
Posted on Nov 18, 2011
Need remote code for universal remote for d490
my sony RM-VLZ620 programmable remote lists the following codes:
00037, 00156, 00178, 00208, 00226, 00556, 00618, 00650, 00702, 00812, 00821, 01312, 01458, 01619, 02051, 02103
Oct 11, 2013 | Samsung Electronics Samsung 43" D490...
Need code for sky remote control for samsung model ps51d450 51inch plasma tv
Hello
Sky remote codes for Samsung TV are:
065 584 615 037 245 476 516 292 318 236 398 244 100 118 060 088
646
672
642
Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Aug 30, 2011 | Samsung Televison & Video
Sky remote code needed
Hello
Sky remote codes to check with LG TV are:
065/244/405/318/037/398/191/459/245/389/060275/742/743/726/508 & 584
OK.
Aug 29, 2011 | LG 50 50PZ550 50 3D Plasma TV
Samsung Remote Control not working
any samsung remote will work any samsung television. Samsung use the same code for all television's as do Sony
Samsung remotes are quite expensive you could always buy a Sky digibox remote and tune that in to work you tv that would be a cheaper option.
how to tune in the sky remote to work your samsung tv
TV,
RED + SELECT ( blinks twice)
TV,
0060
TV,
SELECT.
Job done
Hope this helps you out.
Cheers
Little Dish Fitter
Sep 02, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Volume button doesnt work on my sky remote
please follow the steps below:
TV
RED + SELECT
TV
0060
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
May 25, 2009 | Samsung HL-S5086W 50" HDTV
Sky remote control tv code
TV
RED + SELECT (flashes twice)
TV
0060
cheers
Little Dish Fitter
Apr 11, 2009 | Samsung PS42E7HD 42 in. HD-Ready Plasma...
Sky remote code fo LCD LE40A456 TV
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Jan 26, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung plasma tv
037
Jan 21, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Televison & Video Logo
Henry  Thomas
Henry Thomas
