Question about Dual Electronics CECT P168 Cellular Phone
It says no GPRS connection when trying to get on the internet
Its A
CECT P168+ PDA Cell Phone
Hello, I called at&t and they walked me through the steps, they also sent them to me via email. Here are the steps. I hope this is helpful.
if (typeof YAHOO == "undefined") { var YAHOO = {}; } YAHOO.Shortcuts = YAHOO.Shortcuts || {}; YAHOO.Shortcuts.hasSensitiveText = true; YAHOO.Shortcuts.sensitivityType = ["adult"]; YAHOO.Shortcuts.doUlt = false; YAHOO.Shortcuts.location = "us"; YAHOO.Shortcuts.document_id = 0; YAHOO.Shortcuts.document_type = ""; YAHOO.Shortcuts.document_title = "Iphone"; YAHOO.Shortcuts.document_publish_date = ""; YAHOO.Shortcuts.document_author = "sb341w@att.com"; YAHOO.Shortcuts.document_url = ""; YAHOO.Shortcuts.document_tags = ""; YAHOO.Shortcuts.document_language = "english"; YAHOO.Shortcuts.annotationSet = { "lw_1233181266_0": { "text": "WAP@CINGULARGPRS.COM", "extended": 0, "startchar": 1332, "endchar": 1351, "start": 1332, "end": 1351, "extendedFrom": "", "predictedCategory": "", "predictionProbability": "0", "weight": 1, "relScore": 0, "type": ["shortcuts:/us/instance/identifier/email_address"], "category": ["IDENTIFIER"], "wikiId": "", "relatedWikiIds": [], "relatedEntities": [], "showOnClick": [], "context": "7. Edit APN to wap.cingular (lowercase) 8. Edit Username to WAP@CINGULARGPRS.COM (UPPERCASE) 9. Edit Password to CINGULAR1 (UPPERCASE) 10. Edit Auth", "metaData": { "visible": "true" } }, "lw_1233181266_1": { "text": "First Step", "extended": 0, "startchar": 1888, "endchar": 1897, "start": 1888, "end": 1897, "extendedFrom": "", "predictedCategory": "ORGANIZATION", "predictionProbability": "0.641147", "weight": 0.313473, "relScore": 0.965878, "type": ["shortcuts:/us/tag/other/wiki"], "category": ["WIKI"], "wikiId": "First_Step_%28album%29", "relatedWikiIds": [], "relatedEntities": [], "showOnClick": [], "context": "Edit Data Account to the Name you established in the First Step 8. Edit Connection type to HTTP 9. The IP address", "metaData": { "ambiguous": "true", "movieID": "1800324718", "moviePosterHeight": "150", "moviePosterURL": "http://shopping.yahoo.com/video/images/muze/vhs/sm/80/134380.jpg", "moviePosterWidth": "83", "movieRating": "Unrated", "movieYear": "1996", "notrailer": "true", "visible": "false" } }, "lw_1233181266_2": { "text": "IP address", "extended": 0, "startchar": 1946, "endchar": 1955, "start": 1946, "end": 1955, "extendedFrom": "", "predictedCategory": "", "predictionProbability": "0", "weight": 0.274638, "relScore": 4.14089, "type": ["shortcuts:/us/tag/other/wiki"], "category": ["WIKI"], "wikiId": "IP_address", "relatedWikiIds": ["Address_book", "Change_of_Address", "French_Open_%28tennis%29", "Google", "Jos%c3%a9_Canseco", "Kevin_McKidd", "Memory_address", "Spain", "WHOIS", "YouTube"], "relatedEntities": [], "showOnClick": [], "context": "First Step 8. Edit Connection type to HTTP 9. The IP address is 066.209.011.032 and the port number is 8080 10. Edit", "metaData": { "visible": "true" } }, "lw_1233181266_3": { "text": "http://mmsc.cingular.com", "extended": 0, "startchar": 2803, "endchar": 2826, "start": 2803, "end": 2826, "extendedFrom": "", "predictedCategory": "", "predictionProbability": "0", "weight": 1, "relScore": 0, "type": ["shortcuts:/us/instance/identifier/URL"], "category": ["IDENTIFIER"], "wikiId": "", "relatedWikiIds": [], "relatedEntities": [], "showOnClick": [], "context": "to whatever name you would like Edit Home Page to http://mmsc.cingular.com Edit Data Account to the same data account you created", "metaData": { "visible": "true" } }, "lw_1233181266_4": { "text": "Technical Support Rep", "extended": 0, "startchar": 4166, "endchar": 4186, "start": 4166, "end": 4186, "extendedFrom": "", "predictedCategory": "", "predictionProbability": "0", "weight": 0.361181, "relScore": 5.29169, "type": ["shortcuts:/concept"], "category": ["CONCEPT"], "wikiId": "", "relatedWikiIds": [], "relatedEntities": [], "showOnClick": [], "context": "devices and keep these points in mind: Stephanie R. Bledsoe Technical Support Rep. E-mail srb341w@att.com Wireless : 717-503-1187", "metaData": { "visible": "false" } }, "lw_1233181266_5": { "text": "717-503-1187", "extended": 0, "startchar": 4809, "endchar": 4820, "start": 4809, "end": 4820, "extendedFrom": "", "predictedCategory": "", "predictionProbability": "0", "weight": 1, "relScore": 0, "type": ["shortcuts:/us/instance/identifier/phone_number/us"], "category": ["IDENTIFIER"], "wikiId": "", "relatedWikiIds": [], "relatedEntities": [], "showOnClick": [], "context": "mind: Stephanie R. Bledsoe Technical Support Rep. E-mail srb341w@att.com Wireless : 717-503-1187", "metaData": { "visible": "true" } } }; YAHOO.Shortcuts.headerID = "bfe400b526b49210ec3af2ace861a2e9"; 1. Main menu --> Select Services
3. Select Data Account --> Select GPRS
5. Select the first entry
6. Edit the account name to whatever you would like
10. Edit Auth Type. to Secure
11. Save
Select Back --> Select Back
Select WAP
1. Select Settings --> Edit Profile
3. Select the first entry --> Edit Profile
5. edit the name to whatever you would like
6. Edit Homepage to http://device.home
7. Edit Data Account to the Name you established in the First Step
10. Edit Username to WAP@CINGULARGPRS.COM
11. Edit Password to CINGULAR1
Select back or done
Select Activate Account
You should now see a Black [G] in the upper left of your screen.
To access the net select Services --> WAP --> Homepage.
If it connects the Black [G] should turn Green
MMS
Select Messages --> MMS --> Message Settings
Select Server Profile
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080
Edit the Username to WAP@CINGULARGPRS.COM (UPPERCASE)
Edit the Password to CINGULAR1 (UPPERCASE)
Select Done or Save
Make sure to activate the profile and you are good.
Be advised that we cannot guarantee that these settings will work for sure in these devices and keep these points in mind
Posted on Jan 28, 2009
Electronics CECT P168 Cellular Phone: i carnt access the internet it keeps on saying GPR...
do want the full internet Google, Facebook (where as you must subscribe)
or do wish to access CNN news, Yahoo, Myspace, Sports scores, Weather & what time that Movie starts?
here follow the info on this link http://www.youtube.com/watch?v=og0bgJCeC1k
May 17, 2010 | Dual Electronics CECT P168 Cellular Phone
Gprs is still unsubscribed, help?I'm trying to setup the internet n mms on my sons sciohone +i68 and my i9? please help.
everytime I try to access the internet using my sciphone 19+++, but I get a message saying GPRS unsubscribed
Mar 26, 2010 | Dual Electronics CECT P168 Cellular Phone
No internet connection
i bought a ACE mobile phone model SYDNEY, carry out Standard: GB/T18287-2000 and product date:2009.09. could not connect to internet it says GPRS not subscribed. please help me
Feb 15, 2010 | Dual Electronics CECT P168 Cellular Phone
Gsm or gprs internet with f003
All unlock phones, specially these CECT and Sciphone, are ready to be use with data from Chinas, you need to get the require information about your service provider GPRS set up and set up your phone manually.
Oct 12, 2009 | Dual Electronics CECT P168 Cellular Phone
Mini ka08 gprs not subscribed!!
http://www.youtube.com/watch?v=vSA-CtQeMlk&feature=related
Aug 30, 2009 | Dual Electronics CECT P168 Cellular Phone
I68+ cellphone
1: WAP
Setting
Select SIM 1 or 2 depend where you place your sim
Edit Profile
T-mobile internet
Homepage...http://wap.myvoicestream.com
Data account: GPRS
connection type. Select http
proxy address216.155.165.050
proxy port: 8080
2. Data Account.
Select GPRS
edit GPRS
Account name GPRS
Edit APN: WAP.VOICESTREAM.COM
Auth. Type
Select: SECURE
Apr 08, 2009 | Dual Electronics CECT P168 Cellular Phone
Internet trouble
Since CECT P168 is china mobile you have to get the internet settings done from your near service provider centre(vodafone mobile store if vodafone).
'gprs not subscribed':   it specifies that you have gprs actviated on your sim but you dont have right internet settings on your mobile or china mobile.
so in order to get internet setting take your mobile to the nearest service provide centre(for eg; vodafone mobile store) they will make some internet settings on your mobile and from then you can use your internet, but make sure that you min balance in mobile to surf internet.....
in the case of branded mobiles(like nokia, samsung,......) it is just enough to send a msg from ur mobile  and get internet settings on our mobiles but this is not in case of china mobile(you have to go the nearest centre and get it done.........)
Dec 25, 2008 | Dual Electronics CECT P168 Cellular Phone
Dual Electronics CECT P168 Cellular Phone Logo
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
