Question about Systemax AOL Optimized PC (100607) PC Desktop
Power I HAVE A SYSTEMAX COMPUTER,I'M HAVING TROUBLE GETTING IT TO TURN ON.IS THERE ANY WHERE I CAN A GET DIAGRAM OF CORRECT PLACEMENT ONTO THE MOTHERBOARD?
  • roy_philip73 Jan 28, 2009
    The power is coming on, but turning off right away? the fans turn on but then right back off again
  • Dreamornaut
    Dreamornaut May 11, 2010
    Is there no sign of power at all? Fans not running or no lights coming on on the case.
    Is the power coming on, but turning off right away?
    Scholar:
  • 164 Answers
That brand has had so many complaints about it. make sure this has not happened.
Check the CPU fan. It may not be running like it should or not turning at all.
Check that there is not cable that is obstructing the fan blades. When the CPU over heats the machine will shutdown to save it from any damage. I would check to see if you think the power switch is sticking. Make sure that it is not sticky or stuck in.
Posted on Feb 23, 2009
    Scholar:
  • 55 Answers
You should try looking for a short, and reseat your connections. Make sure your power supply voltage is set correctly. If that doesn't help, test your power supply and if it fails, replace it.
If that does not help you there's still quite a bit that could be wrong. You could try restarting with only the essential hardware and if it turns on you'll have to check each componant one by one for the cause. Maybe you might need to reseat the CPU. If you still don't find the cause, you may try a POST card. If you don't have a POST card or do not want to buy one you can try swapping parts from an older machine if avaliable and compatible.
If none of the above helps, then I would suggest taking it into a shop. Otherwise your only option is to begin replacing all the parts which can be expensive. I hope this helps and that it turns out to be nothing serious.
P.S., You should be able to find the manual for your motherboard from Systemax support at http://www.supportforyourpc.com/ .
Posted on Jan 28, 2009
System reboots with no warning
Plug a desklamp into the same power point and note whether it flickers at the same time as the reset. If so, you have a power problem. I had a similar problem a while back, discovered the fuse in my household power box was faulty. Replacing the ceramic fuseholder fixed my problem.
This may sound silly, but check the power cord is plugged in hard to the socket at each end. I once made a service call to a computer which wasn't plugged in correctly, and was resetting.
Next most likely cause is the power supply box in the PC itself.
Mar 25, 2010 | Systemax Venture PC Desktop
Need to know the placement of the altenator belt for a ford range
CLick on the link below, insert the year and make of the truck and click on the belt you're replacing and you'll get a diagram. Best of luck!
Greg
http://www.mvreader.com/multiview/dayco/index.php?bgInterchange=1&l=n
May 14, 2009 | 1986 Volkswagen GTI
I have a Systemax Venture computer that is 3 years old. Just developed a problem. Turn the computer on and after 20 to 30 seconds the computer shut down. What is wrong???
Hi there.
Remove all power to the desktop, remove the side panel, power the machine up and check that CPU fan is working, if it is turn the computer back off, get a clean, dry paintbrush and gently clean the fan blades and the metal heat sync behind the fan of dust, then restart the PC to see how long it stays on for. If this time it stays on it was overheating.
Good luck and thanks for using Fixya!!!
Feb 23, 2009 | Systemax Venture PC Desktop
I need a diagram showing placement for the case power switches
The manual for your MB is available at the ASUS website, as a PDF file. This is a direct link to the manual:
http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4p800-vm/e1338_p4p800-vm.pdf
The info you need is located on page 1-28 and 1-29 of the manual.
Cheers
Nick
Dec 01, 2008 | ASUS 865G (MBAS-P4P800VM) Motherboard
Hd power problem systemax cpu
If you would provide more information about your Systemax system... model/serial number I can look the specs up. I can tell you the only way that it could be the hard drive would be if you had a bad power supply, not that your system can't handle the "power" of the hard drive. If you end up getting a new power supply, you could opt for one with a little higher wattage if you'd like. A 160gb hard drive isn't going to pull any more meaningful amount of current than a 40gb. What I would look at would be wither you had the jumpers on the hard drive configured correctly. For info on jumpers, see...
http://en.wikipedia.org/wiki/Jumper_(computing)
Individual drive manufactures and drive models have different method for setting the jumpers and it will also very on what other IDE connected devices you have in your computer (optical drives, hard drives, Zip drives, and etc.).
Nov 25, 2008 | Dell Inspiron 2200 Notebook
SYSTEMAX COMPUTER POWER FAILURE
whenever u r connecting a harddrive to a computer, u have to make sure the jumper settings are correct.
Nov 14, 2008 | Dell Inspiron 2200 Notebook
Systemax POS
does your system display anything at all if yes it might be from the hard drive or your operating system but if is not displaying at all is the ram am very sure
May 09, 2008 | Systemax Venture PC Desktop
Computer booting problem
FIRST OF ALL TIGHTEN THE WIRINGS
this is what happened to me 2 times
first change ur hard disk drive (HDD) with any other of your may be friend if the problem fixes then it is okay if not t hen may be ur mother board or processor is bad
NOTE:BEFORE U DO ANY THING CONSULT ANY EXPERT PHYSICALLY OR UR PARENTS IF UR A CHILD
Dec 01, 2007 | Systemax Venture S519J (988868) PC Desktop
New Computer Wont Boot!
when you say "the fan makes a noise like its getting ready to spin", which fan...power supply's or cpu? if you answer power supply, then the POWER OK signal is not returning to power supply and it then quickly shuts down to prevent further damage. double check a firm connection to mother board. If you answer CPU, then it becomes far more complicated. Try re-seating the memory chips.
Jun 05, 2007 | Systemax Venture PC Desktop
Systemax AOL Optimized PC (100607) PC Desktop Logo
108 people viewed this question
Top Systemax Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Abhinandan  Patil
Abhinandan Patil
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
