Question about Konica Minolta magicolor 2430 DL Laser Printer
KM 2430DL prints 'shady' pages
Was told from a local printer expert to fix this problem, I would need to replace the drum unit. Did so and it didn't fix the problem (returned the new drum also). Pages are coming out 'grainy' or 'shady'. HELP! Love the printer otherwise....
  • 4 Answers
If all the colors are effected by grainy look, then it could be the imaging unit like you were told or the transfer belt. Unfortunately there generally isn't a way to test which one it is but to swap and test.
If you are still having issues, check out www.killmyprinter.com
Posted on Feb 14, 2009
How to fix black copies from km4035
Check the scanning lamp maybe its blow, replace it with the new one or the drum unit,,,
Jun 06, 2014 | Kyocera Mita KM-4035 Printer
I have a 2430dl and it is leaving lines on my copies is this the drum
Send a print to the unit, open printer when paper is in drum area (guess and open a door or turn off, to stop the printer) open carefully, remove carefully and look at the paper, are the lines there, pull drum unit, flip open drum protection door if equipt, and look at the partial image on it, If the lines were imaged on the drum, replace drum unit. No marks on drum or paper yet, posible the fusing section roller is damaged and marking pages. Stop test will show where defect starts.
Dec 10, 2010 | Konica Minolta magicolor 2430 DL Laser...
Kyocera Mita 2050 there are streaks of toner appearing on the pages printed.
If you send a print job or print a report from the copier and there is no streaks then the problem is most likely the thin **** glass to the left of the large glass. It just needs to be claened.
If the streaks are happening when printing and copying then the problem is most likely your drum unit (MK-410) or possibly the fixing unit (FU-410), the fixing unit is the one that gets hot.
As the drum gets old it can cause print/copy issues and the cleaning blade that cleans the drum gets to the point it doesn't clean the drum properly causing streaks.
The heat roller has a teflon coating on it and as the roller gets older the teflon starts to come off and can effect prints/copies.
The drum unit should be replaced every 150,000 pages and the fixing unit every 300,000 pages on the KM-2050.
I hope this is helpful,
Shawn
Nov 15, 2010 | Kyocera Mita KM-2050 Printer
I get several vertical white lines in my prints.
Do you have enough ink in your printer? This can be a problem. A faulty drum/roller could also be a cause which in that case will need to be replaced. Since you have done your part i guess the rest should be handeld by an expert personally.
good luck.
Jul 04, 2010 | Konica Minolta magicolor 2430 DL Laser...
Faded printing down center of page
You may need to change your drum unit. The replacement part number is DR400
To replace the drum unit follow the instructions listed below:
Caution
    Do NOT use flammable substances or any type of spray to clean the inside or outside of the machine. Doing this may cause a fire or electrical shock.
spray.gif Caution
    Just after you have used the FAX/MFC, some internal parts of the machine are extremely HOT! When you open the top cover of the FAX/MFC, never touch the shaded parts as shown in the diagram below:
  1. Open the front cover.
  2. Remove the old drum unit. Place the drum unit on a drop cloth or large piece of disposable paper to avoid spilling and scattering the toner.
  1. Remove the toner cartridge by holding down the lock lever on the right and pull the toner cartridge out of the drum unit assembly.
  1. Wait to unpack the new drum unit until immediately before installing it. Place the old drum unit into the aluminium bag.
  2. Reinstall the toner cartridge into the new drum unit.
  3. Reinstall the new drum unit, keeping the front cover open.
  4. Press the Clear key to display drum status.
  5. Press 1 on the telephone keypad.
  1. When the display shows "ACCEPTED", close the front cover.
Note
    Discard it according to local regulations. If you are not sure of them, call your local Sanitation Department. Be sure to seal the drum unit tightly so toner powder does not spill out of the unit. When discarding used drum units, keep them separate from domestic garbage.
Jun 18, 2010 | Brother IntelliFAX 4100 Laser Fax
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
Kyocera 3035 printing all black pages
It sounds like you have a bad charge corona.
Apr 30, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Minolta Magicolor 2430dl Color smudges line on edge of paper
please check the transfer belt, it seems that the transfer belt is not cleaning very well, if you find same marks on TBU then you may try to clean the cleaning unit if no help, then replace TBP.
Aug 12, 2008 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Jul 11, 2008 | Konica Minolta magicolor 2430 DL Laser...
Minolta 2430DL ColorLaser
There is only a manual reset for the toners but I'm sure you already knew that... The drum is just a plug-n-play type consumable and should just reset automatically unless it's an old drum... ( make sure that you didnt make the mistake like so many of us a reput the old drum back in again) if your sure its the new one then it's obviously defective and depending on where you got it you should be able to defect it out for credit... hope this helps... www.bigmoneycentral.com
Mar 06, 2008 | Minolta 2430DL Color Laser Printer
Konica Minolta magicolor 2430 DL Laser Printer Logo
116 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
