Question about Sta Rite Pool & Spa
Pack rats making nest in the heater - Sta Rite Pool & Spa
    Top Expert:
  • Sta Rite Master
  • 5,743 Answers
Moth balls or dryer sheets to keep them out steel wool in holes and WD 40 for wires
Posted on Oct 01, 2017
  • 61 Answers
SOURCE: Rat Nest in oven insulation
No the insulation must be replaced . the insulation makes the oven cycle on and off less frequently and also keeps the exposed metal surfaces cooler.
Posted on Dec 22, 2008
  • 5 Answers
SOURCE: I have a mega quilter and keep getting rat's nest on bottom.
The rats nests that you are describing I assume are on the bottom of your work. If this is the case, it tends to generally be caused by incorrect tension from the upper thread, or incorrect theading of the upper thread.
Occasionally the tension of the bobbin could also be out.
As a rough guide the tension of the thread as it leaves the bobbin should be that it needs a gentle pull to release it. If you were to hold the thread only & let the bobbin hang, it should only release if you were to like shake the bobbin toward the ground. Anything other tension would mean adjustment of the bobbin screw.
A lot of upper tension problems are often caused by the tension settings being incorrect, the wrong mix of threads/fabric, blunted needles, threading of machine whilst pressure foot is lowered (very common), and sometimes by dirty machines that are not thread and lint free or infrequently oiled.
If all that fails, you need professional service help as it could be a timing issue possibly.
I hope this gives you a few things to try that may help before you need to spend money on your machine being fixed, however remember that a regular service will ensure continued happiness from your machine
Posted on Oct 04, 2009
SOURCE: rats nest on back of fabric
make sure the machine is threaded according to the operations manual & the tension adjustment is according to the operations manual says
make sure the needle is not bent, and also the correct needle for the machine & fabric
if none of these work it needs to be taken in to be check
Posted on Jul 29, 2010
  • 228 Answers
SOURCE: heater blower not working after
There is a fuse for most cars. What do you have and what year is it.
Posted on Jul 03, 2011
SOURCE: pack rats have built nests and plugged up heater
remove dash
Posted on Oct 02, 2013
I have a Samsung top loader he and it looks like there are dead leaves after every load. Any idea what is going on?
do you live where there are lots of mice ,ground squirrels or even pack rats .they might be nesting in it .
Oct 02, 2016 | Samsung WA400PJHDWR 4.0 Cu. Ft. HE Top...
Rats nest on back of fabric
Jul 18, 2010 | Kenmore Drop-In Bobbin 16231 Mechanical...
My raypak versa spa heater was making a loud sound when igniting (combustion) and now it wont do anything it seems like there is not any power to the unit but I know there is power and spa controller is...
You may have spider web's in your gas orfaces or rat nest's on your heater tray. The rat nest will be easy to see. But with the spider web's you will have to remove the orfaces from the gas manifold. Then clear with a wire as they are very small. You will need to shut all the power off to the heater to reset so it will start. Their may also be a fuse link or wax switch that guards against roll out of flame. This melts the wax if the heat gets to be enough hurt controls, and will be found on the bottom front of the heater. For your heater uou will need to check your book on the heater.
Dec 16, 2009 | Raypak BURNER TRAY ASSEMBLY
When plugged in the heater makes a noise like it may be trying to start but shuts off after about 5 sec. Heater has not run in several years
If it were mine- and the heater has been inactive for several years, I'd check for a rat's nest inside. If clear, it's time for some serious troubleshooting. Remove the top cover. Is the fan turning?
Oct 05, 2009 | Reddy R60A Utility Heater
No start only buzz 40,000 btu kerosene
Rat's nest inside? If not, starter cap is probably bad.
Oct 01, 2009 | Reddy Heater-30-55,000 BTU Variable
Dec 19, 2008 | Tappan TGF320 Gas Kitchen Range
Heater fan is SLOW....
check to be sure that nothing has made a nest in your blower motor.. I have found mouse nests, rats nests, and even dead snakes inside the blower motor on these trucks..with all the extra weight inside the blower, the low speeds turn slow and will burn the resistor out quicker.
Oct 12, 2008 | 1994 Toyota Pickup
Pool & Spa Logo
105 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Jim Goldsmith
Jim Goldsmith
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
