Question about Epson Stylus NX400 InkJet Printer
USB for epson NX400
I've got one...im not good with electronics... i went to plug it in the printer and it doesn't seem to fit? is there a particular way to do it or do i need to use another one or was my printer supposed to come with it?
pleaseeee help! thanks
    Genius:
  • 2,120 Answers
You need a USB A to B cable. They don't come with new printers.
Posted on Jan 28, 2009
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
Hi-My Epson NX400 inkjet printer does not
Hi there
You can download this from my website.
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Mar 18, 2010 | Epson Stylus NX400 InkJet Printer
Where do i get the right usb cable for my epson stylus nx415 to connect to my windows xp computer? they didn't include one and the two that i have do not fit. now what
You will need a usb cable that at the one end will look like a square. This cable can be found at any pc electronics store.
Please see the following link that provides the photo of the usb for your printer:
Printer Cable
Jan 29, 2010 | Epson Stylus NX400 InkJet Printer
Epson Printer NX400 series problem
Found this on the web. You can download the
manual, reference guide, troubleshooting guide and more. Hope this helps. If you find this helpful, pls rate. me.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=106004&infoType=Overview
According to the error codes :
Make sure there's no jammed paper or other obstruction inside your Epson Stylus.
The print head may not be able to move because of some obstruction. Follow these steps to remove jammed paper or other obstructions from the Epson Stylus:
Turn off the Epson Stylus.
Open the scanner.
Remove any jammed paper or other obstructions from the paper path.
Carefully lower the scanner.
Turn the Epson Stylus back on.
Note: If you can't remove the paper or foreign object yourself, do not use force and do not disassemble the Epson Stylus.
Good Luck............
Jan 22, 2010 | Epson Stylus NX400 InkJet Printer
I cannot get my epson stylus nx410 CD to load my driver. Went to epson centre no listing for printer
Epson does not make a NX410, They only make a NX400 and NX415.
Check the back of the printer for the exact model number. If when you check you it is for some strange reason it is a NX410. I would try one of the drivers from the NX4000 or NX415 as drivers for printers typically don't vary too much between similar models and may provide a good temporary fix to your problem.
You can also call epson US (562) 276-4382 6am to 6pm PST mon-fri
Driver link to NX400
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Overview&oid=106004&prodoid=63075469
Driver link to NX415
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Overview&oid=128287&prodoid=63083741
Jan 08, 2010 | Epson Stylus NX400 InkJet Printer
I can install my epson nx400
Im sorry if you can install it why are you posting!
If you cant Install the printer what error are you getting and have you downloaded new software from
Aug 13, 2009 | Epson Stylus NX400 InkJet Printer
For Epson NX400 printer. I need to change cartridges. How?
Turn on printer, imediately unplug power when carriage moving. Unplug usb. Move carriage by hand to replacement position.
Jun 24, 2009 | Epson Office Equipment & Supplies
Cant find usb cord to fit my Epson NX400 inkjet printer
HI!
There are universal cords to buy, the important is that you know the Voltage and the Ampere so you get the right one. To get the right Voltage and Amphre look in your manual.
You can find and order a universal cord from the ner or find one in a good electrinic shop
Good luck
Nic
Mar 04, 2009 | Epson Stylus NX400 InkJet Printer
Epson Stylus NX400 InkJet Printer Logo
76 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
