Question about Sony DAV-TZ130 DVD Home Theatre System - 5.1 Channel Surround Sound, 3
Didgi-pad remote control RM-SFLX9
Manual
Why can't i Access changing Chanel up or down on my sony rm- yd028 remote control?
if u can take your remote apart on the circuit board take an eraser from a pencil and clean the pads they will be dark in color then put back together try it
Sep 21, 2014 | Sony RM-YD024 REMOTE CONTROL PART...
Chunghop RM-88e Thomson code
Click here to download the user manual to your remote control. It has all details.
Nov 07, 2012 | none CHUNGHOP RM-139EX Universal Remote...
I need to separate the covers on a Sony TV Remote Control but there are no screws holding the covers together. Model no. RM-ED005 (R) Can you help?
At the bottom of your Sony RM--ED005 Remote control you'll see 2 small rectangular holes. I used two small screwdrivers, one to create a gap the other to prise the unit apart, when u are able to get your fingers in gently separate both parts from bottom to top.
You'll notice where the rubber pads meet the contacts there is 'condensation' this is what causes some of your remote buttons to fail.
Simply wipe away with a clean damp cloth, dry off, clip the remote together again and you basically have a new remote control.
May 31, 2011 | Sony RM-V310 Remote Control
I have a sony rm-v310a and i dont know how to work it
GO TO THIS LINK TO DOWNLOAD MANUAL FOR THIS REMOTE CONTROL ,
click:
http://www.retrevo.com/support/Sony-RM-V310-Universal-Remotes-manual/id/752ag225/t/2/
Nov 09, 2009 | Sony RM-V310 Remote Control
Program sony remote to operate dish vip722
The Sony RM-YD029 Remote control will work with the Dish Network VIP722 DVR HD Satellite Receiver, but the Dish Network VIP722's Primary remote address must be set to 1.
The procedure below will allow Sony RM-YD029 remote control to operate Dish VIP722.
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system info page the primary remote address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates you the channel your remote control one is configured. The Sony RM-YD029 will work when this primary remote address number (in the white box) is set to 1.
If the Primary Remote Address of your VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your Sony remote control per the instructions in the manual or Sony's web site. My 722 works with Sony IR code - 01775.
Sep 08, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Rm-1 Olympus remote. I have 2 of them and can not get them to work with my Olympus E510. New Batteries, tried to set frequency. No luck. Any advise?
Starting on page 45 of the user manual explains how to use your RM-1 remote control. You have to set up the camera in remote control mode in order to fire the RM-1.
May 10, 2009 | Olympus RM-1 Remote Control
Sony RM-V202 control and Emerson DVD Player
the codes are 051     060      069
1 turn on dvd
2 press and hold s button
3 whilst holding s button press and release power button
4release set button
5 press dvd on controll
6 using key pad key in the 3 digit code
7 press enter button
8 point remote at dvd and try power button
9 if nothing work enter next code
if this still dont solve your problem post back and i will tell you how to do this manually hope this is some help
Oct 20, 2007 | Sony RMT-V202 Remote Control
Sony DAV-TZ130 DVD Home Theatre System - 5.1 Channel Surround Sound, 3 Logo
63 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
