My memorex dvd player won't turn off manually and is stuck on "hello."
Whenever I turn the power on, my dvd recorder just says hello. Nothing else works-remote, buttons on machine, etc. Unit has not even 3 months of use (but was purchased over a year ago-needed a "kid" to set it up.) How can I remedy this? Thanks... I have a JVC DVD/VCR player. It does the same thing. The only way I've been able to solve this is by unplugging the unit, then when I replug it, I go in, reset the time and then I can turn the unit off or set it to timer. But this happens again and again and I must do the procedure I just described each time it freezes.
Does anyone know of a better way or another more permanent solution?
SOURCE: Unit totally locked up
I called the secondary 800# as the number in the manual has a recording for "if you are calling about the drc8335 call 877-805-0519" how bout it? A separate number just for this unit?
The guy said to unplug the unit for at least 30 MINUTES & that I would have to rescan in all the channels I have spent alot of time scanning in by rotation of the antenna. Geezzz I wish I had returned it to the store before the 90days were up... (price has dropped below $150 was 219 last year?)
Posted on Mar 19, 2008
SOURCE: Panasonic dvd/vcr DMR-EZ47V model.Code OOOOOO keeps going across.
You must manually hold in the on/off button on the machine itself (NOT on the remote) for approximately 30 seconds. This will shut the unit off. Then you can restart it.
Posted on Feb 26, 2009
SOURCE: Have the JVC HR-XVC26U. I installed this vhs/dvd
Posted on Jun 24, 2009
  • 188 Answers
SOURCE: remote control to Panasonic DVD/VCR recorder not working
In the setup you can change the remote for DVD1 or 2 .Your handset must be one the same adres as the set.
Posted on Jul 24, 2009
SOURCE: Can't get my new DVD/VCR to work.
I read the instruction manual one more time. It said to tune my TV to Video and voila, the VCR worked. All JVC VCR's seem to need the tv tuned to Video to play back. I had an older JVC VCR and I had to do the same thing with it.
Thanks anyway.
Posted on Jan 21, 2010
Memorex cd/dvd player won't open. I can't get my dvd out
It may be necessary to disassemble your player to get access to the drive for removal of the stuck DVD.
Jun 18, 2016 | Memorex Mvd2047blk 1080p Hdmi Progressive...
Tray won't open on my MRX-530L CD/DVD recorder
leave the unit plugged off from power for one night and try to open.
else you will have to open the unit and force the tray outside.
Aug 10, 2008 | Memorex Televison & Video
MVD2050 will not turn on. We have a DVD stuck in it. We turned the power off and back on after 60 minutes but nothing happens.
Hello K4, hi you can manually get the disk out, but you need to remove the cover. As for the power thing, you have a power supply problem, would you like to service it yourself or call a technician, If you will service it yourself, this are the things you should check:
  1. fuse
  2. open wirings
  3. shorted or over heating rectifier diodes and voltage regulator
  4. bulging filter capacitors
  5. Switching regulator IC, check for the output pulse using a scope.
  6. replace the bad parts, then test.
Apr 28, 2010 | Memorex MVD2050-BLK DVD Player
I've had the Memorex DVD Player MVD 2023 for several years now and really haven't used it very often. A couple of weeks ago I inserted a DVD and it only operatied for about 10 minutes and became stuck on a...
sounds like the power supply isnide your DVD player is your problem. if its really old then may be worth upgrading as the cost of repair may well be more than a replacement player.
You will need to continue using your Modulator with the new DVD player but DO NOT ATTEMPT TO RETUNE YOUR TELEVISION - IT IS NOT NECESSARY. Just plug the new DVD player in place of your old one
Mar 17, 2010 | Memorex Progressive Scan DVD Player...
DVD recorder wont record
The instruction manual says it strongly recommends for good quality recording : Sony Maxell and TDK and has been been tested for Verbaitim as well.
Nov 11, 2008 | Funai TruTech DVDVCR Dual Recorder
Split screen with pscan warning on
I had the exact same problem and I consulted the manual. All you have to do is turn the PSCAN swtich off. It is located on the back of the dvd player. Then turn the dvd player back on and your problem should be fixed.
Jun 07, 2008 | Memorex MVD2022 DVD Player
Memorex DVD Player
hello...please contact her dealer and try to replace the recorder if ther's a warranty...if not refere to the user manual.,and carefully read it regarding first useage...please tell me how it went...good luck...Ron
Mar 07, 2008 | Memorex MVDR2102
My Memorex DVD player will not open or come on
I just fixed a Memorex 2042 DVD player. Before the fix, the standby light was lit, nothing else works (with remote or buttons on the player panel). Opened up the machine, saw a capacitor bulged (1000uf/10v). Did some soldering work and replaced it. All is fine now.
Jan 29, 2008 | Memorex MVD2040 DVD Player
MEMOREX MVD2040 UNLOCK CODE
This is all I could find ..... Memorex DVD-2000 C/P / MVD-2020 / MVD-2022 / MVD-2027 / MVD-2027 A / MVD-2028 / MVD-2029 / MVD-2030 / MVD-2037 / MVD-2051
  1. Open the disc tray
  2. Press CLEAR
  3. Press 1, 3, 6, 9
  4. Enter region (0 = multi-region)
  5. Close the disc tray
  6. Turn the player off
Memorex MVD-2042
  1. Press OPEN/CLOSE
  2. Press 9, 7, 3, 5 (or 1, 3, 6, 9 for the "suffix B, C, D" model)
  3. The setup menu will appear
  4. Press RIGHT to move the cursor to highlight the regions
  5. Select region using UP/DOWN (0 = multi-region)
  6. Press ENTER
    (or try the instruction for MVD-2020 above)
Memorex MVD-P1072
  1. Turn on the player (without a disc inserted)
  2. Press SETUP
  3. Press 9, 2, 1, 0
  4. Select region (0 = multi-region)
Jan 16, 2008 | Memorex MVD2040 DVD Player
Interface error! Trun off the power
Okay...sounds like you have a lot of signal splitting as well as devices that may also weaken your signal. With digital cable, you won't see snow or what would be a dead give-away to a weak signal. Only analog signals do that. Digital signals give you crisp clear picture or they drop out.
Try taking the cable directly from the wall to the DVD-Recorder. If you are able to watch channels and manipulate the device, then you can start from there as the source is good and the recorder is good.
Try to place the DVD-Recorder after the first splitter and see if you still receive stable signal. You'll probably need to leave the unit in this part of your A/V chain.
It really sounds like you need a signal amplifier for all the splitting you've done, or to re-work your A/V stack into something more manageable. It is entirely possible that the built-in tuner of the new DVD-Recorder is not as sensitive as the old unit.
Oct 28, 2007 | Memorex MVDR2102
Televison & Video Logo
438 people viewed this question
Top Televison & Video Experts
