Question about Casio Watches
How to adjust the (Auto Light) function for casio ft 620
How to adjust world time? How to turn on auto light? How to adjust date?
it is a complicated issue and you need to look at the user manual.
just write the code on the back side and click searched on the URL below which you can also
download a soft version of the user manual .
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives
http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
Jul 19, 2011 | Casio EFA119BK1AV Watch
Daylight savings time change casio atomic watch has not changed is there a way to change it manually
An example for G-shock: I searched for casio g-shock manual and got this: http://world.casio.com/wat/download/en/manual/
You enter model from back of watch and it gives you a searchable PDF manual.
For mine, model 2638 (and likely most G-shocks), you press and hold the upper left (Adjust) button until the City Code flashes. You then press the lower left (Mode) to enter DST mode then press the lower right (Receive) as it cycles through On, Off and Auto.
On moves 1 hour forward, Off moves 1 hour back. After you select, you press the upper left button (Adjust) twice and it's set. I would not pick Auto anymore as my watch is still set to the original DST days which were changed in the US years ago and no longer match, I don't believe the DST days used can be changed by the user and I don't believe Auto receive adjusts for DST.
Mar 13, 2011 | Casio Watches
Casio g-shock gw-330a watch. I saw the utube
There are so many aplications use of the manual will be manditory.
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
Mar 20, 2010 | Casio GW330A G Shock Solar Atomic Watch
HANDBOOK FOR CASIO WAVECEPTOR TOUGH SOLAR 4719 WV0-620
Go to the Casio web site "casio.com", select "support" and the "manuals", then "watches", accept their terms and conditions,
Insert the module number and download instructions.
Jan 18, 2010 | Watches
How do I turn off the auto light on a Riseman GW9200
please help! i bought casio str 300, and can not turn on auto light, i press buttom light for 2 - 10 seconds, and nothing....
Jun 04, 2009 | Casio Watches
Adjusting the world time??
If your watch is Casio:
If not, give ALL the details.
Rate, please.
Mar 30, 2009 | Casio G-Shock 800D 7V watch
How do you set the time on a casio g shock watch????????
I had the same problem following recent daylight savings time (DST) change. The watch has three DST mode settings (ON, OFF, and AUTO). You get to the setting mode by pressing and holding the "adjust' button until the city time zone indicator starts to flash. Then press the "mode" button. This should give you the DST setting. Now press the "receive" button to cycle through the ON, OFF, and AUTO modes for DST. I set it for AUTO. I then existed the setting mode by pressing "adjust" again.
Now you can initiate a manual update of the time by pressing and holding the receive button. Put your watch by a window and make sure the signal strength indication is showing level 4 (full picture of satellite dish on my version). Give it a few minutes to down load new time.
After doing this the watch corrected itself and now shows correct time. Other wise I assume you could set the DST function to ON or OFF as well depending on whether you need to add or subtract the hour from the time.
Oct 26, 2008 | Casio G-Shock GW500A-1V Wrist Watch
LIGHT CASIO PROTREK PRG60 TRIPLE SENSOR
Enter Altimeter Mode
Press and hold Adjust Button
Now press Baro Button
(It will off Auto Light Function)
Oct 25, 2008 | Casio Triple Sensor Pathfinder PRG60-1AV...
I can't get my light to come on on my Casio model 2608
To turn the auto light switch on and off--
In any mode, hold down (L) (light switch at 6o'clock/bottom)for about two seconds to goggle the auto light swithch on(auto light swithch on indicator displayyed) or off (auto light swotch on indicator not displayed)
Sep 26, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Need too set time on my g shock casio watch
Press Adjust and hold until blinking city appears.
Press Mode until DST appears flashing.
Press Recieve until mode that you want appears ON OFF AUTO
Press Adjust until not blinking city code.
Mar 10, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Watches Logo
55 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
