Question about Canon imageRUNNER 2000 Copier
Canon ir 2000 copier displaying ROM ERROR - Canon imageRUNNER 2000 Copier
  • 18 Answers
SOURCE: ir 2000, system error E000
The main thermistor reading does not reach 40°C 14 sec after the fixing
heater goes ON. (fixing low temperature error)
If E000 is indicated, the RAM on the image processor will
retain the error memory of the fixing assembly after the power switch has
been turned off an then on. Execute the following in service mode, and
turn off and then on the power switch to clear the memory: #7
PRINTER>#4 PRINTER RESET>YES=(*).
Entering service mode: press "aditional function" and after "#(ID)"
Posted on Jul 16, 2008
  • 11 Answers
SOURCE: CANON IR 400 COPIER - ERROR - E677
677 error is printer board error.u check conection( lpt port or usb cable loose conection.printer board loose conection.remove all conection and conect all conection i mean reinsert conection ) then this error come u will service u r printer board(re insolve printer softwere).803 error is expouser lamp end side blocked change u r lamp u r 803 problem is ok
Posted on Sep 18, 2008
SOURCE: Canon iR-2016 System erro E007
hi how do solve this problem system error E007
Posted on Apr 09, 2009
  • 118 Answers
SOURCE: canon iR C3200 E00020 02d0
check or change the magenta drum unit
Posted on Jul 30, 2009
Adi_Taticu
  • 71 Answers
SOURCE: i have an error in canon photocopier IR 1210 E 245
errors are not described in service manual
trying to put out the power and put it back
if not resolve, you should reset the memory
stop the copier, get out the back cover and looking for jumper JP1, him out, wait 1 min, put in place jumper, start the device. I hope to help information
JP1: jumper plug for power used by battery to back up memory (control data; user data, service
mode data).
Posted on Oct 25, 2009
Rom error in canon ir-1600 copier
Try this as a temporary work around, power on the iR while holding down the STOP key.
This may boot the iR to a ready state and copies can be made.
Dec 17, 2014 | Canon Office Equipment & Supplies
Hoo.comi want to solve the problem in my copier canon ir 2016, error code e354
this is error code that isn't stated in service manual and doesn't have description. When this error occures the procedure is to report to Canon service center. The same errors were on ir1600/2000 series, but without some good explanations.
So, call authorised CANON service partner!
Sep 13, 2011 | Canon iR 2016i Black and White Copier
DEAR I AM FACING PROBLEM IN IR2000 ROM ERROR SO I NEED FIRMWARE FOR THIS MODEL OR GIVE ME A SOLUTION. THANKS
When the ROM Error message is displayed on the control panel, this will indicate an issue with the Flash DIMM on the Image Processor PCB.
re-flash the system software/or replace the DIMM Assembly.
When replacing the DIMM, you may be required to flash the system software to it's latest version.
iR 1600/2000 FG6-9978-000, Dimm assembly.
As a temporary work around, power on the iR while holding down the STOP key. This may boot the iR to a ready state and copies can be made.
Service Mode=Additional Functions #
Aug 05, 2010 | Canon iR 1600 Laser Photo Printer
My canon IR 8500 has no display on LCD and can't work again after I was replace the RAM... What's going on...?? Help me please...
Did you clean the contact of the boot rom? Are you sure you have the right boot rom? Why did you replace the boot rom? Good Luck..
Dec 18, 2009 | Canon imageRUNNER 8500 Copier
Error message: ROM ERROR, what does this mean?
Error :
ROM Error message
Workaround :
In attempting to resolve the issue, reflash the system software for that specific model. If system software does not resolve the error, replace the DIMM Assembly. When replacing the DIMM, you may be required to flash the system software toit's latest version.
Jun 05, 2009 | Canon imageRUNNER 2000 Copier
Please, i don t know to much about copier i have a canon ir 1600 when i powor it after sometime is displaying system error E000 sos please. zakaria
i dont know more abotu copier when the copier on the paper jam error wil displayed how to solve the problem the jam Error Code :0360-0-367596
Jan 06, 2009 | Canon imageRUNNER 2000 Copier
Canon ir 2016 copier on display says ( Download Standby) thanks
We have a Canon IR 2016 J and in a beginning in the dispaly appears the message "Download Stanby" then after we replaced the PCB board appeared the message "System Error E354" what should we do to solve this problem, and if it is possible to send us the Service Manual with error codes for Canon IR 2016
Apr 18, 2008 | Panasonic KX-FB421 Plain Paper Film Fax
ROM Error for Canon Image Runner 2010F
re-flash the system software for that specific model. If system software does not resolve the error, replace the DIMM Assembly. When replacing the DIMM, you may be required to flash the system software to it's latest version.
iR 2010F FG6-9454-000, Dimm assembly.
Mar 12, 2008 | Canon USA - COPIERS - ImageRUNNER 2010F...
Canon imageRUNNER 2000 Copier Logo
46 people viewed this question
old marine
old marine
