Question about Acer X193W LCD Monitor
There are buttons on the front of the monitor. Why
My manual doesn't say anything about what these buttons are for. e , auto and menu , <> ,circle with a line. There is no description in the manual. I don't even know how to turn this off so the light on circle with light goes off. Help. Thanks
  • nomilynne Jan 28, 2009
    You are using all these letters which are greek to me. What is OSD? What is HPos, VPos, clock and focus . I just want a picture and to know what each button does. Help. Why are they there.
  • nomilynne Jan 29, 2009
    No I'm not kidding. What is OSD?. Can you give the words these letters stand for? I can get it a lot faster if I know what the letter abreviations mean. I can do pretty well if people don't throw a lot of letters at me. I was not raised in the computer age but am struggling manfully.
  • 102 Answers
The first button is the E-power button for the Auto preset function.With it you can select presets like text, standard, graphics etc. depending on your use.
When you select any button the options are displayed at the bottom of the window. These tell you what button to press to select the next option.
For example press --menu-- > -- > -- menu , to adjust the horizontal and vertical position.
To turn off the monitor you must press and hold the --circle with the line -- button for a couple of seconds.
Posted on Jan 27, 2009
  • rjwharris
    rjwharris Jan 29, 2009
    I work with the technologically challenged all the time!!
    OSD means On Screen Display
    HPos and Vpos are Horizontal and Vertical Position
    With this monitor unless something goes seriously wrong you should not have to make any focusing adjustments as the auto adjust will do that for you in most every instance.
    If you have any other questions click on my name (rjwharris) to ask me directly.
  • 115 Answers
Front Panel Controls
1. Power Switch:
To turn ON or OFF the power.
2. Power LED:
Lights up to indicate the power is turned ON.
3. Empowering / Exit:
1) When OSD menu is in active status, this button will act as EXIT-KEY (EXIT OSD menu).
2) When OSD menu is in off status, press this button to select scenario mode.
4. Auto Adjust button / Exit:
2) When OSD menu is in off status, press this button for 2 seconds to activate the Auto Adjustment function. The Auto Adjustment function is used to set the HPos, VPos, Clock and Focus.
5. < / >
Press < or > to select the desired function. Press < or > to change the settings of the current function.
6. MENU / ENTER:
Ac
tivate OSD menu when OSD is OFF or activate/de-activate adjustment function when OSD is ON.
EN
  • Russ Andrews
    Russ Andrews Jan 29, 2009
    Ya kidding right?
Auto adjust in progress
1. Push the menu button at the front side of your Dell monitor. The icon looks look like a miniature version of your monitor.
2. Push the menu button again. This will exit the monitor menu and launch the OSD (On-Screen Display) menu.
3. Use the down arrow button on your monitor to select "Factory Reset."
4. Push the menu button.
5. Use the down arrow button to select "All Settings." Press the menu button to save changes.
6. Push the menu button twice to exit from the menu. Your Dell monitor will go back to its factory settings default, and its auto-detect feature will be disabled.
Oct 10, 2014 | Dell E171FPb 17" TFT LCD Flat Panel...
Need the operation manuel for my 22inch Gateway monitor can't change operating language
I have a smaller sized Gateway monitor than yours, but I'm sure the monitor buttons (on the front) perform the same functions on all sizes.
You should have eight control buttons on the front of the bezel (as listed from left to right): source, menu, down arrow, up arrow, left arrow, right arrow, auto/set, and on/off buttons.
Press the menu button, the first dialog screen that appears (at least on mine) is the brightness/contrast function. The screen will show the function to be changed, and a very small picture of what screen you have in view.
Once the first function is listed on the screen, press the down arrow to access the other screens (color, tracking and set-up), each having their own little picture indicating what screen you are looking at.
Brightness/contrast - picture of half light, half dark circle
color - RGB picture
tracking - two squares on top on one another slightly off center
set-up- hand pointing left
You want the set-up screen which shows a picture (I think) of a little hand pointing to the left. Once you are in the set-up screen, press the auto/set button and the first line will be highlighted (usually it is the language choice).
Once highlighted, press the right arrow button until your language name appears (i.e., English, Duetsch, Francais, Espanol Italiano, -there is no choice on mine for Japanese, etc.).
Press the menu button again and that should do it.
Feb 10, 2013 | Gateway HD2201 22" LCD Monitor
I need to reset my margins for Windows XP
Your monitor should have a button on it that says "Auto". Press that. If it doesn't have a button like that, then find one that says "Menu" and look through the Menu to find something like "Auto-config". Alternatively, you could use your monitor's menu to manually adjust the horizontal position of your screen.
Oct 18, 2012 | Dell Microsoft Windows XP Home Edition
HOW DO YOU MOVE THE ARROW KEY ONCE YOU ARE IN THE MENU?
You use the button with the <> arrows to move through the menu selections. Use the menu key to select the function you want to change.
Below is an excerpt from the Acer manual. The manual can be found at http://www.retrevo.com/support/Acer-X203H-Monitors-manual/id/23224bh549/t/2/
1.Power Switch:
2.Power LED:
3.Empowering / Exit:
1) When OSD menu is in active status, this button will act as EXIT-KEY(EXIT
OSD menu).
mode.
4.Auto Adjust button / Exit:
1)When OSD menu is in active status, this button will act as EXIT-KEY (EXIT
OSD menu).
2)When OSD menu is in off status, press this button for 2 seconds to
activate the AutoAdjustment function.The Auto Adjustment function is
5.< / >
Press < or > to select the desired function.Press < or > to change the
6.MENU / ENTER:
Activate OSD menu when OSD is OFF or activate/de-activate adjustment
Jul 02, 2011 | Acer X203H bd Monitor
Cant get my monitor back in english its on *** i think
restore your settings to "Factory Settings" by
use the front panel buttons
Power Turns the monitor on and to standby or sleep mode.
? NOTE: The power button is located on the top or front of the monitor depending on the model.
- Menu Opens, selects, or exits the OSD menu.
-Adjusts the volume level.
-Opens the Quick View menu to quickly adjust settings for gaming, video, photo, and text.
? Navigates backward through the OSD menu and decreases adjustment levels.
+ Navigates forward through the OSD menu and increases adjustment levels.
Auto Auto-adjusts the display
Select Enters the selected option.
Jan 06, 2011 | HP w1907 LCD Monitor
I cannot adjust the color on the screen. Too Blue
mcdevito75 here, On the monitor itself press the auto button for factory settings, if this doesn"t work, press the menu button for adjusting contrast, color etc. if this doesn"t work your monitor may be going bad.
Jul 17, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
Color is off,i have a blue tint to screen cy
mcdevito75 here, You should have an AUTO button on your monitor that when pressed or pushed it"ll automatically adjust your monitor picture. If this doesn"t help you can try the menu button to adjust manually.
Jul 07, 2010 | LG 22" FLATRON LCD Monitor
Picture is far too large, exceeds screen, colour cannot be adjusted to anything but very bright. Screen now flashes while on line.
on your crt's manual menu you can resize the screen hit the menu button on your screen to begin or you can try the auto button
May 09, 2009 | Sony CPD G420 19" CRT Monitor
NEED HELP WITH AUTO CONFIGURATION
You can download a copy of the manual from hp by going here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=324216&os=228&lang=en&
and picking the "monitor user's guide" link.
The auto configuration is just a choice from the main menu. If your monitor OSD is locked so you can't select anything (you get a message when you press any button), you can follow the manual procedure to unlock it. But unless there is some electronic problem with the monitor, you should not be having trouble with autoconfiguration.
Nov 21, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Acer X193W LCD Monitor Logo
661 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
