Question about Haier HLC19R 19 in. LCD TV/DVD Combo
DVD of hlc26b-b says no signal and DVD is stuck
Very limited use, maybe 10 times at most. Was setting up for kids and hit something on remote. DVD stopped and said no signal. Will not release DVD now. TV works fine. Really want DVD back!!!
Everytime I press remote channel 3 keeps showing up
A television set usually receives a signal from a cable box, DVD player, etc., on a specific TV channel. Channel 3 is the most commonly used for this purpose. So when you press certain buttons on the remote, the TV tells you "Hey! Somebody selected TV Channel 3!" This is normal-- IF the remote you're using is a remote for the cable box, DVD, etc. If you get this and you don't have a cable box or other signal source, then something else is wrong... maybe you're using the wrong remote?
Mar 12, 2015 | Televison & Video
What should i do for no signal tv?cables are ok,,,
Just do an auto-search function after connecting the external ariel, and selecting the input to TV. The set will start auto-search for all the channels transmitting at that time, and will show the first program that it got, after the auto-search is finished.
During this search time, the set won't respond to any external commands, including the it panel buttons. Wait till the auto-search is over. It might take about 3 to 4 minutes.
There is nothing more to do. Refer its user manual for more details about how to do an auto-search function.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 31, 2014 | Skyworth SLC1519A 15.6 LED TV- DVD Combo...
Display says it is stuck on dvd 2 cannot program the dvd recorder to record
DVD recorder stuck on DVD 2 mode that means you can no longer operate it with its remote, right?
Now you need to change remote mode to DVD 2 so recorder can receive its signals.
Slide down lower cover of remote and set Command Mode switch to DVD 2 position, now your recorder will get remote signals and you can operate it properly.
Thanks.
Jan 18, 2011 | Sony RDR-VX521 DVD Recorder/VCR
TV will not respond to/recognize remote. I have
Check On the Menu Setup for On/Off Remote utility Maybe your Remote signal is off on the TV Set...
Sep 22, 2010 | Mitsubishi WS-65611 65" Rear Projection...
My DMR-EH50 is stuck in SP mode and when I hit the button on the remote it keeps displaying CHK REMOTE 3. Would you know what is causing this. I cannot get the unit to do anything at all.
Very easy fix.
Your DVD recorder can be set up to accept remote contol signals on any one of three channels. Remote 1, Remote 2 or Remote 3.
Your remote can be set up to send signals on any of these channels. You need to make sure your recorder and remote are set to the same channel.
Your recorder is telling you that it is set to receive remote control signals on channel 3. This means your remote control is currently set for a different channel.
Assuming that you have a genuine Panasonic remote, do the following,
On your remote press the "Enter" button and hold it down. Then press the "3" button at the same time for two seconds, then release both. This will change your remote so it sends signals on Channel 3 which will match your recorder.
Those clever people at Panasonic realise that you will be delighted with their products and will probably have several of their appliances in use. The different channels avoids switching all your Panasonic gadgets at the same time. Clever huh?
Best wishes
Aug 24, 2010 | Panasonic DMR-E50 DVD Recorder
I have a Spongebob tv/dvd player. When trying to
I looked through the manual and didn't see anything either. I assume that you are hitting the TV/DVD button and setting it to DVD when you want to use the DVD. Does the remote do anything besides turn the TV on (change channels, etc.)? Hope this helps and good luck!
Mar 15, 2010 | Emerson SpongeBob SquarePants TV
Display is stuck in Spanish.
on your remote for your dvd player hit your menu button then hit options it should have an option to change languages.
Nov 15, 2008 | TruTech TT320
Dv-c503 pioneer dvd player
the magic eye on the door opener in been obtruated by something .. like a small object stuck on a cd or someone might just open the door and let something in it .. stuck on the slidetrack ..and interfer with the sensor .. maybe kids???
Dec 30, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Sep 09, 2007 | RCA F25254GY 25" TV
Problem with remote
This fixes the *Set 1* problem. Set 1 means the remote cannot communicate with the Panasonic DVR. If the batteries go out on the remote replace the batteries stand in front of the Panasonic DVR, press and hold the "1" button and the *enter* button at the same time and hold for 10 seconds.
May 21, 2007 | Panasonic DMR-ES35VS
Haier HLC19R 19 in. LCD TV/DVD Combo Logo
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
