Question about Konica Minolta Bizhub C280 Color Copier / Printer / Scanner
Bizhub c280 paper jam
The manual scan tray on the top keeps jamming the very first paper and then won't scan.
3 Suggested Answers
  • 1294 Answers
SOURCE: konica Minolta bizhub 250 jammed but no paper
Please check the sensors and actuators ,open & close front door to reset nisfeed.Clarification Top feed = Automatic Document Feeder?If YES,please verify misfeed paper beetween coverplaten and feedbelt(Yellow).Is necessary disassembly the ADF.Good luck.You will find a little paper.
Posted on Jul 31, 2009
  • 10 Answers
SOURCE: help!!! I am trying
check the paper pick up sensor
Posted on Mar 26, 2011
Adf konica minolta bizhub 350. theres adf working good but no printout. a few minute machine says jam paper at adf. actualy original it was throw out.. help me please...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - Am working on a Magicolor 2300 DL that sometimes fails to lift the paper tray ... good afternoon I have a konica minolta bizhub c550 when I open the ... I'm no printer tech, but in most other lasers (HPs, etc) the paper tray lifts, .... It seemsthere is a "waste toner sensor" which only lets the printer print out a few ...
Konica Minolta paper jam adf scanner Questions & Answers ...
www.fixya.com > Forum > Tags > paper jam adf scanner
Question about bizhub 350 All-In-One Laser Printer ... Konica Minolta bizhub 250 jammed but no paper ... Good luck. ... ...paper is there if the switch is working the adfboard is fualty or the cable between the machine and adf broke from all the ...
Konica Minolta bizhub document feeder not working ...
Jan 23, 2016 | Konica Minolta Office Equipment & Supplies
I need help with paper tray removal
Pull the draw out upper left is a screw and latch
Jun 09, 2014 | Konica Minolta Bizhub C280 Color Copier /...
11X 17 jams
replace the roller or move the paper
Jan 09, 2014 | Konica Minolta Bizhub C353 Color Copier...
Misfeed detected. I have opened everything I know how and cannot see a paper jam. The 0 indicator is near the manual 'feed' at the top of the unit.
there is a piece of paper in the area between the tray 1 and the door. sometimes you can use cardstock to push the paper out. try it
Sep 04, 2011 | Konica Minolta Bizhub c203 Copier
I don't have the manual and the red light is on. Is that the toner needing replacing and how do I do it?
Here are the things that a steady red light may indicate (from the Owner's Manual):
led-erroron17.jpg A paper jam has occurred. To solve the problem, see "Clearing Jams in the Paper Tray". The front cover is open. Close the front cover. The top cover is open. Close the top cover. The paper tray is empty. Load paper in the tray. See "Loading Paper". A toner cartridge is not installed. Install a toner cartridge. See "Installing the Starter Toner Cartridge".
• A paper jam has occurred. Check the paper tray area.
• The front cover is open. Close the front cover.
• The top cover is open. Close the top cover.
• The paper tray is empty. Load paper in the tray.
• A toner cartridge is not installed. Install a toner cartridge.
Jul 26, 2011 | Dell 1110 Laser Printer
My CLX 3175FN printer continues to have a paper jam. Right now I cannot print any paper size without it jamming. What can I do to correct this problem?
Paper jams
85% of paper jams are caused by worn rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
Metal Tab Separation- Pull out your paper tray and examine either end where the paper sits in. If any of the corners are held down by metal tabs, this is your paper feed system. Chances are, you only have one rubber roller or one set of rollers arranged along side of each other. Reach in where the tray goes and feel up. You should feel some rollers. They might be completely round, or they might be shaped like a half moon. Clean whichever part of them you can with the solution, and this should stop your paper jams. It might be necessary to turn them, but don't force them if they don't move freely.
Pickup Roller and Separation Pad-
If your printer uses this paper feed system, you should see a small piece of flat or slightly curved rubber or cork. It would be towards the end of the paper tray, or deep inside the paper loading cavity on top loaders. This 'separation pad' rubs against the paper feed roller, so if you find the pad, you've found the roller. Clean it and your jams should stop.
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away
Also:
Start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at the drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. If not then it is in the fuser area.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 21, 2011 | Samsung CLX-3175FN Printer
Error 241.1 Paper Jam. I have reseated the tray
Brand New T652n lexmark printer get a paper jam every time! just opened and haven't been able to print one paper. Doesn't matter if you print from tray one or tray two. It gets stuck right after the rollers pick it up and try to send it to the toner. Any suggestions? I've tried to reseat the toner, plain paper, sized the paper correctly, I've tried just about everything I can think of! I can feed paper manually through the top tray, and it will print. But, just using the manual tray defeats the purpose of the other two trays. Anyone else having this issue?
May 26, 2010 | Dell 5310n Laser Printer
Jul 31, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Paper jam in tray 1 is so deep I can't reach it. Can I remove the tray to get to the jam?
Yes you can remove the tray. Just make sure you put everything back in its place.
Jun 10, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta Bizhub C280 Color Copier / Printer / Scanner Logo
48 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
