Question about Kenwood KAC-7202 Car Audio Amplifier
Blown amp the light wont come on the amp. I think I blew it. Is there anything that might be wrong that I can check before I just go out an buy a new amp?
    Problem Solver:
  • 11 Answers
Hi, try connecting the power b+ and gnd and remote turn on cables only (dont connect rca input or any spks), if amp doesnt turn on you will have to take in for repair. no need to buy new amp, coz problem could be a burnt pcb track or even a faulty remote or FET circuit.if amp turns on then connect other cables slowly and monitor the power lite as you do connections. you may have a faulty spk load that will cause amp to stay off or in protection mode. cheers
Posted on Aug 05, 2007
SOURCE:
240sx wont start only thing that works is the left headlight
Check earth strap from engine to frame and battery to frame.
Apr 28, 2017 | 1990 Nissan 240SX
47 inch vizio blown fuse
i am having the same problem and my power light wont even turn on so i think it might be tht power fuse. Is tht what was wrong with urs?
Dec 18, 2011 | Vizio VO47LF 47" TV
Hi Both my dipped headlight beams on my Sprinter van are not working, all other lights are ok. Could both bulbs have blown?
Definitely. Typically one bulb goes first, but the vehicle operator fails to notice anything wrong until the other bulb follows suit. It's then easy to make the mistake of thinking that both bulbs blew at the same time and that there's a more complicated fault.
You'll only find out what's wrong by removing the bulbs and checking, but note that a visual check is often misleading. Either use a continuity tester on the bulb or substitute a new one although it's not uncommon to find faulty new bulbs, so don't automatically assume a new one will definitely be OK. Continuity testing is definitely the best method.
Hope you get a quick fix and please take a moment to rate my answer.
Sep 24, 2010 | Mercedes-Benz ML-Class Cars & Trucks
Amp not working
It sounds like you either blew a fuse, or you cooked your amp. The fuse on the P200.2 amp is a 30A fuse, and it sits right next to the power, ground, and remote wire connections on the end. Pull the fuse out and see if it's blown. You should also check any other fuses that you have in the car before the amp.
Mar 03, 2010 | Rockford Fosgate Punch P2002 Car Audio...
97 Acura 3.5 RL-dome lights, bose stereo won't turn on
Are you sure no fuse was blown? there are more than 1 fuse box (in engine and under dashboard).
Jan 30, 2010 | 1997 Acura RL
Dash & rear lights wont come on..fuse blew? HELP!
It is loctated in the underhood fuse box and it is call the park fuse it is a 10 amp fuse
Sep 05, 2009 | 1997 Saturn SL
My blower blew a 3 amp fuse..i replaced it....the blower is running...but the ac wont kick back on
why did fuse blow thats what i would figure out? check for power at compressor it maybe locked up(you haft to reverse polarity to unlock)!! :)
Jul 05, 2009 | Heating & Cooling
2000 watt american legacy amp protection ligh wont go off
Same thing happened to me so I returned it for repair turns out it was an internal 25amp fuse on the output. Got it back an it sounded very weak now it does not play at all. Nothing wrong with my setup as I have now got an 800watt amp that is running great.
Jul 01, 2009 | Lanzar MXA422 Car Audio Amplifier
Hi. I have a Kicker amp KX1200.1 that doesn't seem to be working. I think it blew a fuse. Do you know how I can get that fixed?
You should have an inline fuse (external) at the amp and one at the battery. There are not fuses on the amp.
Jun 25, 2009 | Kicker KX1200.1 Car Audio Amplifier
Kenwood KAC-7202 Car Audio Amplifier Logo
135 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
