Question about Kyocera Copystar CS-1820 Black and White Copier
My kyocera km-1820 error occured in the monitor c4000
  • 43 Answers
SOURCE: error code C-6 for kyocera km 1500
Fuser error,
may have either a blown lamp, blown thermo fuse or faulty thermistors, but more then likely a combination of at least two.
Posted on Mar 02, 2008
SOURCE: KYOCERA KM-1820 COPIER
follw these steps, it should work
turn off copier.
open top toner cover.
turn copier back on.
when you see message "close top cover" press "system menu" button.
scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time.
then scroll down to "maint mode"
press "enter"
then enter 163
press" enter "
turn off copier then turn back on
close toner cover
you should be back in business
Posted on Jun 12, 2008
KyoDoc
  • 38 Answers
SOURCE: KYOCERA CS-1820 ERROR CODE C7990
Apologies for the late reply. This is a waste toner full problem. Pull out the process unit (in case you don't know, it's the big black unit where you fit your toner into, also the one that you need to remove to check for paper jams. Turn it around so that the side where the toner fits is furthest away from you. Now on the side closest to you, on both the left and right hand side are two small covers, each fastened with 1 screw, hidden in deep holes. Remove these screws and covers, and empty the toner inside.
Be advised that this is a very messy job. Also, after you've removed these covers and you turn the unit on its side, the toner may not fall out. in this case stick a screwdriver or something in there to loosen the toner.
When done, refit the covers, place the unit back into the machine, restart the machine, and thats it. If the code still appears, you've got toner on the waste toner full sensor, which sits just above where the waste toner part of the process unit is, inside the machine. you can take a cloth and wipe this. although this is highly unlikely, nothing in this industry surprises me anymore.
if this still fails, you could have a faulty sensor or circuit board, but again, highly unlikely
have fun (nothin like gettin your hands dirty) ;)
Posted on Sep 18, 2008
  • 40 Answers
SOURCE: KM-1820 scanner setup
The KM-1820 to scan to PC is using SMB, FTP or e-mail.
for SMB:
I am assuming you have the KM-1820 connected within the network and a static IP address for it.
open any Internet browser and go to KM-1820's IP address.
You should see the Command Centre web page.
Go to Basic page and add/register a contact within the Address Book.
Give a name and at the SMB section field, fill up with your computer hostname or the ip address of your computer where you want to scan. Fill up the user name with the local user name - the one what you are using to get into your computer - or create a new LOCAL user for your PC lets say "kyocera". So for SMB will be your computer and username: kyocera. (You will need a password for that computer user (kyocera) ). Then create a folder "scan" where you want ot receive the scanned files and add "scan" at the path field (SMB section of that webpage - command center).
Now share the folder "scan" as "scan".
if you want you can always use the scan to e-mail !! but you need a smtp server. All the settings can be done using that command center webpage.
Posted on Jan 10, 2009
fsantello
  • 4 Answers
SOURCE: Error Code 2102
Change the SMTP port from 25 to 587
Posted on Aug 20, 2009
How to solve error c4000 for Kyocera KM-2035 copier? it has stopped
c4000
The Problem:
inside the laser unit Polygon motor synchronization problem
The polygon motor does not reach the
stable speed within 15 s of the START
signal turning on
Causes:
1-Poor contact in the
polygon motor connector
terminals.
Reinsert the connector. Also check for continuity
within the connector cable. If none,
remedy or replace the cable
2-Defective polygon
motor.
Replace the polygon moter or LSU.
May 29, 2014 | Kyocera KM-1505 Copier
How to change email addfress for fax
Instructions for registering and editing the address book (fax, email, scanning destinations) can be found on page 5-21 of the advanced operations guide wich can be down loaded from the following link; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=14173&rid=14774. THe KM-1820 and CS-1820 are the same machines and this link is for the KM-1820.
Jan 17, 2011 | Kyocera Copystar CS-1820 Black and White...
Se produjo un error llamar al tecnico C7980
On the screen of my KM 1820 copier Kyosera get the message "An error occurred calling a technician" and C 7980
how I can fix this error?
Sep 03, 2010 | Kyocera Copystar CS-1820 Black and White...
I have a kyocera km 1820 copier at work and cannot figure out how to navigate it to make 2-sided copies???
The Kyocera KM-1820 does not have an automatic 2-sided option. This is why it cannot be found in the settings.
May 20, 2010 | Kyocera Copystar CS-1820 Black and White...
Error Code 2102
Oct 21, 2008 | Kyocera Copystar CS-1820 Black and White...
Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Oct 20, 2008 | Kyocera Mita KM-1815 All-In-One Laser...
Kyocera Copystar CS-1820 Black and White Copier Logo
113 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
