Question about Seiko Smart 440 Thermal Label Printer
SLP Print manager synchronization failed - Seiko Smart 440 Thermal Label Printer
Hp 2420 offline error
Upgraded all jetdirects to their latest firmware, DOWNgraded any jetdirect J7949E on firmware v33.15 to v33.14 (.15 is horribly broken and crashes after a couple of minutes usually).
I have enabled SLP protocol on all the print servers, I have then telneted into the jetdirect to set slp-keep-alive (available with the firmware updates) to a value of 2 (2 minutes between slp anouncments).
I have changed the MAC age time on all the switches to 900 seconds from the default 300.
Jetdirects now announce themselves every 2 minutes stopping the switch forgetting that they exist. I have added a logoff-period of 1800 seconds to a single port with a Xerox printer on it which stops it reauthenticating every 10 minutes (unable to change slp interval on it).
This may or may not help, but I've had the printers on line for the last week now and when I ping, they are still there!
Jul 22, 2012 | HP LaserJet 2420 Printer
Hi there I just got a new computer and try to copy the old smart label printer over, but when I try to print the label out, I got a message says.." SLP print manager can not start" What I...
when you say uyou copied the old printer over I assume you actually reinstalled the Printing Application from scratch?
You cannot just copy the seiko directry over, t doesnt load the .dll files
reinstall the application
biffo
Sep 08, 2011 | Seiko Smart 440 Thermal Label Printer
How do I load and coordinate my MS Outlook address book and calendar with my Blackberry Curve 8330?
Here is how you do it:
1Install Blackberry Desktop Manager Softwarewhich included in your Blackberry Installation CD. If you don’t haveone, you may download software from Here
2Make sure you set an Outlook profile that the Desktop Manager can use.3Start the BlackBerry Desktop Manager.4Connect your Blackberry with your computer via USB cable and allow Blackberry device driver install.5Click on Synchronize in BlackBerry Desktop Manager.6Activate the Synchronize organizer data checkbox: BlackBerry Synchronize.7Click on the Configuration tab. Then, click on the Configure synch: BlackBerry Synchronize Configuration.8Check the data you want your BlackBerry being synchronized to. Choose CONTACTS, TASKS, CALENDAR, and NOTES databases.9Afteryou check each item, the software will ask which application you wouldlike to sync it with, you will choose OUTLOOK for all.10Nowgo back to the Desktop Manager. Make sure that the SYCHRONIZE ORGANIZERDATA check box is checked. And select the Synchronize now button at thesynchronize dialog to begin synchronization.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Dec 30, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Uncaught exception: java.lang.nullpo inter exception note keeps coming up
Hi, you get this error message when attempting to access a corrupt contact list database on the BlackBerry smartphone, BlackBerry Device Software or software application component has failed, or there is corrupt data from a wired or wireless synchronization.
Isolate the corrupt data by turning on advanced logging for Intellisync
1) Turn on advanced logging for Intellisync.
2) Once the corrupt data entry has been isolated, delete it from the desktop email client and the BlackBerry smartphone.
3) Synchronize again.
Clear the contact list database on the BlackBerry smartphone.
1) Open BlackBerry Desktop Manager.
2) Click Backup and Restore, and then select Advanced.
3) From the Device Databases list, select Address Book, and then click Clear.
4) Return to the BlackBerry Desktop Manager window.
5) Synchronize the contact list with the correct translator in Intellisync.
I hope this information will help you
Nov 17, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
I get an intellisync error 0x8004fd28 when trying to Sync my blackberry
Hi, When attempting to synchronize between the computer and the BlackBerry smartphone, the Error 0x8004fd28 message appears on the BlackBerry Desktop Manager. This is due to the intellisync folder is corrupted. To resolve this issue, you need to complete the following steps: 1. Close BlackBerry Desktop Manager. 2. On the computer, navigate to the appropriate folder listed below: · If you are using Windows® XP, go to C:\Documents and Settings\\Application Data\Research In Motion\BlackBerry\Intellisync · If you are using Windows Vista?, go to C:\Users\\AppData\Roaming\Research In Motion\BlackBerry\Intellisync Note: If you are unable to view the above folder refer to additional information section on instruction on how to view hidden files 3. Delete the Intellisync folder. 4. Open the BlackBerry Desktop Manager. Note: If the BlackBerry Desktop Manager attempts to synchronize at this stage, synchronization will fail. 5. Configure the BlackBerry Desktop Manager for synchronization by completing the following steps: a. Click Synchronize. b. Click Configuration. c. Click Synchronization. 6. Synchronize calendar appointments. OR If there are one or more corrupt entries on the BlackBerry smartphone . Take back up and clear the database on the BlackBerry smartphone. I Hope it helped you. Thank you for using ' Fixya ' and have a nice day!!
Nov 16, 2009 | RIM BlackBerry Curve 8310 Smartphone
Try to backup my blackberry using desktop manager but will not and says backup data failed. i have done this several times but this time it won't and am trying to upgrade os so now i can't because i would...
Try to take backup,while taking the backup you will find when the backup stops backing the files,delete that particular database and then backup the data.Upgrade the OS and perform the hard reboot.Steps to perform how to clear the corrupted database. Connect the BlackBerry smartphone to the computer. Open BlackBerry Desktop Manager.
Click Backup and Restore. Click Advanced.
Select the database that failed (for example, the Calendar database).
Click Clear. In the BlackBerry Desktop Manager Main Menu and click Synchronize. Click Synchronize Now to perform a synchronization.
Jul 17, 2009 | RIM BlackBerry Bold 9000 Smartphone
Receiving Intellisync message
for this you need to reconfigure the synchronization settings for your destop organizer proram
please follow the same.
1. connect Blackberry to the computer.
2. open desktop manager and click on SYNCHRONIZE.
3. click on the CONFIGURATION tab
4. click RESET CONFIGURATION
5. click CONFIGURE SYNCH
6. Select a BlackBerry device application (Address Book, Calendar, MemoPad, or Tasks), then click Choose.
7. click BROWSE
8. add the folders you want to synchronize and then click OK
9. click OK to close the chose application window
10. click OK to close the device cinfiguration window
11. synchronize the organizer data on your black berry device.
Jul 10, 2009 | RIM BlackBerry Storm 9530 Smartphone
VCR SLP playback problem
I would first have it cleaned.
Jan 29, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Just bought Zire 31 and won't hot sync Outlook Calendar, Contacts, Notes with the following log:
Generally this error means that HotSync manager (via the 4 Outlook conduits) is having a hard time connecting to your Outlook or, in some cases, specifically to your Oultook profile.
Sep 12, 2005 | Palm Zire 31 Handheld
Seiko Smart 440 Thermal Label Printer Logo
95 people viewed this question
Top Seiko Office Equipment & Supplies Experts
Oloyede Monsuru
Andrew Taylor
Andrew Taylor
Are you a Seiko Office Equipment and Supply Expert? Answer questions, earn points and help others
