Question about Xerox FUJI DOCUPRINT CP105 B COLOR LASER PRINTER BLACK
Xerox CP105b I broke the sensor toner home, I open the cover but I have trouble to remove broken and is there a sensor conector conector sensor OTC market
3 Suggested Answers
  • 10406 Answers
SOURCE: Xerox Phaser 8400 Front Cover Open
Yes, there is an OPEN/CLOSE sensor that is sending wrong "status" information to the printer.
Posted on Jun 01, 2010
SOURCE: When trying to print I
pleas try to use a plower to clean the paper way from paper tray to toner .
Posted on Dec 05, 2010
HOW DO I CLEAR REGISTRATION JAM
Open the top cover, remove toner cartridge, jam should be below there. There's a common issue where the grey transport belt break underneath the toner cartridge, inspect those belts to make sure both are intact and not broken. A picture of the belt is at link below
http://www.iteminconline.com/023n01310_023n01310-xerox-4600-belt-flat-rubber.htm
Oct 12, 2015 | Xerox Phaser Office Equipment & Supplies
How to reset waste toner
Open the compartiment on the right side of the Xerox 6600 or Xerox 6605. Rotate the orange lock and carefully take out the waste box. Now empty the excess toner in a bag by shaking the unit with the "holes" down. Do this for 10 minutes till all toner is out of the box. Do this outside, it will be messy.
Blow off any residue tonerdust and take a little screwdriver to remove the plastic seethrough cover. Remove the toner behind this cover and clean it with a cloth. Glue the cover back in place and re-insert the wastebox.
You will save you some money, but it is an unavoidable messy solution.
Aug 11, 2014 | Xerox Phaser 6600dn Color Laser Printer
What's your problem?Minolta EP3050 CSPRO Copier printed copies, then display read ''malfunction detected'' code C0070
Main hopper toner replenishing motor M8 failure to turn.The output from toner bottle home position sensor does not go high within 5 seconds after M8 motor has been energized.Verify the conectors,sensor and motor.Open the front door,turn the toner bottle 1/4 turn clockwise manually with the bottle holder closed.Under the above condition does the toner bottle turn when the front door inter lock switch is turned on?NO - change the toner replenishing M8 motor.Does the toner bottle stop at home position after turning?NO- change PC35 toner bottle home position sensor.Recomanded use vacuum cleaner.
Aug 14, 2012 | Konica Minolta Copier Toner EP6001 CS Pro...
Error e527 have manually removed all cartridges and replaced them and the PCU but the error code persists
Error E527: home position sensor error
Solution:
  1. open the left cover
  2. remove the home position sensor
  3. clean it ( remove the toner)
the home position sensor is shown at this picture: mabroukmedal_32.jpg
Dec 09, 2010 | Epson Aculaser C1100 Printer
How do i replace toner cart
hello my friend, If you want to change or remove then you can remove the toner cart from your printer by opening the printer cover once the printer cover is open then remove the toner cart. Thanks
Jun 18, 2009 | Xerox Phaser 6120/YN Laser Printer
Xerox WCP 416 , it showed message replace drum cartridge
It sounds like you are replacing the toner cartidges NOT the Drum Unit. Drum is located behind the toner cartidge and you will see it after removing toner. Pretty common mistake :)
May 12, 2009 | Xerox WorkCentre Pro 416 All-In-One Laser...
Phaser 7300 error message...
The problem is a crazy design in the printer itself! I've now found a reliable fix for this problem which is relatively easy to carry out. You will find the details of how to do it here :
www.michelsplace
Jan 24, 2008 | Xerox Phaser 7300DN Laser Printer
Tranfer Unit
  1. Open the Top Cover on the printer.
    CAUTION: Do not leave the Top Cover open for more than 10 minutes without covering the Imaging Units as damage could result. Use the dark bag that came with the Imaging Unit or opaque paper as a cover.
  2. Remove all four Imaging Units (which includes removing the Toner (Dry Ink) Cartridges attached to the Imaging Units). To avoid Toner spills, hold the Imaging Unit in an upright position.
    CAUTION: Do not use warm water or cleaning solvents to remove Toner (Dry Ink) from your skin or clothing. This will set the Toner and make it difficult to remove. If any Toner gets on your skin or clothing, use a brush to remove the Toner, blow it off, or wash it off with cold water and mild soap. Do not attempt to use a standard shop vacuum or home vacuum to clean Toner spills in or near the machine. Shop and home vacuums are not equipped with correct filtration and will contaminate your environment.
  3. Raise the two gold colored latches (front and rear of printer) to unlock the Transfer Unit.
  4. Grasp both gold colored handles (center and right) to lift the Transfer Unit out of printer.
To install a new Transfer Unit:
  1. Remove the new Transfer Unit from its packaging or shipping materials.
  2. Grasp the two handles on the new Transfer Unit and place the left end into the frame alignment sockets.
  3. Lower the right end of the Transfer Unit down until it lays flat in the printer.
  4. Press down on both latches to secure the Transfer Unit into position.
  5. Make sure the Transfer Unit is latched into position. Lift up on the right handle to see if the Transfer Unit lifts up. If the unit does not lift it is latched correctly.
  6. Re-install the Imaging Units and Toner (Dry Ink) Cartridges.
  7. Lower the Top Cover.
  8. Dispose of the old Transfer Unit as normal office
Nov 20, 2007 | Xerox Phaser 7400DN Laser Printer
Xerox FUJI DOCUPRINT CP105 B COLOR LASER PRINTER BLACK Logo
29 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
