Question about Philips HTS3357/05 Theater System
After a power cut my hts 3357 unit wont switch on
I have changed the fuse in the plug and there is power going into the unit but it wont switch on. is there a reset button or resetting proceedure to go through ? cheers.
WHERE IS THE FUSE ON MY hts-20 SUBWOOFER
take the back panel off the control unit(monitor speaker)look on the board for the fuse/or look on the back of the unit sometimes its in a little round jacket on the back of the unit.
Jan 31, 2015 | Infinity HTS-20 System
Monster hts 1000
If half the plugs are not providing power, the most likely explanation is that the ON/OFF switch is in the OFF position.
In this position, the Unswitched outlets will stil be powered, but the Switched outlets will be OFF.
Jan 01, 2014 | Computers & Internet
ModelAOT24RNEL Fujitsu Wont start. The fuse
Look at the fuse board in the indoor unit and then check the transformer is over the motor's internal fan.
Aug 18, 2011 | Fujitsu 24C1 Air Conditioner
HTS-20 power subwoofer - was changing fuse and my daughter kneeled on the power board that holds the fuse and the power cord connects. She snapped it in two and I can not find the part to repair. Do you...
Out of production. Contact parts@harman.com to see if replacements are still available. If not, Ebay is your best bet to source either the replacement part or an entire sub assembly.
Jan 18, 2011 | Infinity HTS-20 System
Ps3 blows fuse at plug
Cocodinaro,
It sounds like you're using a damaged power strip; however, this issue can be caused by a bad outlet.
Replace the fuse and plug the unit into a different outlet. If the fuse blows, you need to go to a video game store an purchase a new power strip.
Regards,
Reddwolf25
Apr 11, 2009 | Sony Playstation 3 (PS3) Console
No Power
Hai,
Yes, you have checked the fuse but there is no defect right.....!!!!!!!
Please check the power section some time if there is any problem means it will not turn on, i mean to say that inside the dvd player power section.
Jan 28, 2009 | Philips HTS-3555 System
Monster power hts 2000 mkII
Usually the clicking sound is when the unit switches from powering the devices attached and charging the batteries, do the devices attached to the ups still function?
Feb 18, 2007 | Monster Cable PowerCenter HT 1000 (109091)...
Philips HTS3357/05 Theater System Logo
21 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
