Question about Garmin nuvi 350 GPS Receiver
Garmin Nuvi 350 - Keeps looping
Unit keeps looping between "Pre booting", "Booting" and "Loading software". I confess I've never deleted the many addresses I've punched into it; I wasn't provided with detailed instructions when I bought the unit at a store that is now out of business. Please help .. !
  • Sibananda Jena
    Sibananda Jena May 11, 2010
    1. Raise the antenna.
    2. Press the reset button.
  • 177 Answers
Hello and welcome to FixYa!,
It sounds like the Software in the GPS has become Corrupted.
There should be a download for new Firmware Update on the Garmin website as this is what i did to Updat my GPS System
Hope this works for you, --P3NGYJ03
Posted on Jan 27, 2009
  • 153 Answers
Update the oftware ir will fixthe problem
then check ifit is working
    Genius:
  • 1,269 Answers
First try to reset the unit by removing the battery. If it loads fine, you need to update the firmware of the device. Download the latest firmware from garmin website. If there's no update, you can just re-flash or reload the current firmware by downloading the same firmware version.
Garmin Nuvi 360 says memory full cant reset
Connect the unit up to a PC and try deleting some of the unused text-to- speech (TTS) voices. Keep only the ones that you need. Delete any unused photos or MP3's...and also any unused vehicle icons on the unit. When the unit is booting, it loads in all of the vehicle icons allowing you to change the selected vehicle, so this too uses up valuable memory.
Apr 08, 2013 | Garmin NUVI 360 GPS Receiver
My Garmin Nuvi 1490 LMT returning to normal functionality after doing a map update.
Common problem caused by a failed map or firmware update...or both.
Corrupted map or firmware files prevents the unit from booting normally. More info on boot-up problems here:
http://www.sharc.net/gps_bootup_repair.htm
Apr 07, 2013 | Garmin Nuvi 1490LMT Nuvi 1490 w/ Lifetime...
I have Garmin nuvi 1300 GPS it keeps restarting. I've read that master reset can fix this problem. but how can I save all folders before restarting ?
a rebooting unit will most likely not be resolved by a reset. The problem is usually caused by a failed firmware or map upgrade. When the unit boots and can not find certain files or they are corrupted, the unit crashes. The unit must be flashed with a service firmware to gain access to the units flash drive so that the corrupted files can be replaced. Once access to the flash drive is obtained, the favorites can be backed up as well. Once the files are restored, then the unit can be flashed again with the factory standard firmware. More info can be found here:
Mar 29, 2013 | Garmin nuvi 350 GPS Receiver
Garmin 1340T boot loop issue. The unit
Unfortunately, there isn't an easy solution for the Nuvi owner as it requires a custom piece of firmware to flash the unit to make it at least boot. This problem is often caused during a failed firmware and/or map update.
It sounds like a file was corrupted. Sometimes it is better to connect the unit up to a PC, delete the old map and then proceed to install the new one. There are so many issues with memory space causing failed downloads and corrupted files.
If the map file is missing, the unit will boot-up OK, it will just say "Map data unavailable" but if the map file or associated map files are corrupted, it can cause the unit to crash. Your PC won't recognize the Nuvi because you have the reach the main screen before the data communication mode routines are accessed.
We've had some success in restoring some of these units by flashing a "fix" firmware in "pre-boot mode" that doesn't try to load the map or map associated files. This should then allow the unit to boot. Once the unit boots, Windows will recognize it and then you can copy a map over to it from the PC. Reboot the unit and then flash it with the standard firmware.
- Jim
Feb 23, 2012 | GPS
Garmin nuvi 660 goes into pre-boot mode, then loading, then loading software, then back to pre-boot mode and keeps looping through the 3 steps, and it won't shut down
There is a transient diode across the switch. Most likely it's shorted, casuing the symptom as if you were holding down the power switch and never letting go. I've seen and repaired this before.
- Jim
SHARCNET-USA
Sep 11, 2010 | Garmin Nuvi 660 GPS Receiver
Nuvi touchscreen dead
settings.
1. Turn the device OFF.
2. Place your fingertip or the eraser end of a pencil in the top right corner of the touchscreen.
3. Apply pressure in the top right corner of the screen.
4. While pressing down on the screen, power ON the unit and continue pressing on the screen. A message displays
to confirm if you really want to delete all user data?
5. Touch Yes.
6. The unit will now restart.
7. Follow the onscreen prompts to set up the nuvi.
Jul 31, 2009 | Garmin Nuvi 350 Car GPS Receiver
Garmin nuvi 310 sat nav
faceplate won't work
Aug 05, 2008 | Car Audio & Video
Nuvi 360 Stuck on loading maps
Have you reset the unit yet (little pusbutton behind the aerial)
Jul 30, 2008 | Garmin nuvi 350 GPS Receiver
Nuvi 350 System Software Missing
Try this: Hold the power buuton down, you will see on the lower screen the word "Pre Booting - ". Keep holding the power button for about 60 second, then you will see on the lower screen "Booting".
This time, release power button; system will reboot and loading map... again.
I got the same problem, after research on the web. Nick 99990_0 had post this solution on (his Nuvi 660) but it work for my Nuvi 350 too. Good luck.
Minh (NJ)
Nov 10, 2007 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
55 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
