Question about Cuisinart CBK-200 Bread Maker
The Cuisinart CBK-200C stopped in the middle of a dough cycle
The bread machine won't do anything now all that is coming up is HHH this is my third time using it.....
Please check your shaft and bushing on the bottom of your bread pan . What is happening is the bushing is dirty and binding , your drive motor is heating and resetting or stopping , I just fixed this by pulling out the shaft and lubricating it with loive oil . It works so good now , better than new !
Posted on Aug 16, 2008
I have had this item since Oct. 2006. It has worked ok. Then suddenly, Sept. 1, the baking pan would fit down in the baking area securely with a "click." It is not secure, wobbles and falls off the element during kneading.
Posted on Sep 01, 2007
    Problem Solver:
  • 3 Answers
If you read the user's manual, it says HHH is an error code and your machine needs immediate maintenance.
Posted on Feb 19, 2009
Can I use Cuisinart convection breadmaker to mix ingredients and knead the dough only?
First, I'm not a Cuisinart representative.
* Check with Cuisinart support; https://www.cuisinart.com/
*** following is for information only.***
* Yes, most bread makers will allow you to pause or stop in mid cycle. You can then remove the dough.
* Leaving it in prior to the heating cycl will allow you to let it rise before removing it.
* Review (and using different settings) ; https://www.youtube.com/watch?v=WDf7g_zS7ZM
* Mixing issues; https://www.youtube.com/watch?v=OvgVkd1fHa8
* Unboxing; https://www.youtube.com/watch?v=dBYNEf-h3RI
* CBK-200 Review; https://www.youtube.com/watch?v=UPmAOIjb9oU
* CBK-200 Review; https://www.youtube.com/watch?v=L4WRfIVl3QE
* 1st attempt (fail); https://www.youtube.com/watch?v=2AfT48D6ez4
* other issues; https://www.youtube.com/watch?v=E8UaoHcZt5Y
Aloha, ukeboy57
Jul 21, 2018 | Cuisinart Kitchen Appliances - Others
I have lost my manual can I get a replacement
The Instruction and Recipe Booklet for the Cuisinart CBK-200C is available here:
http://www.cuisinart.ca/pdf/ibs/en/CBK-200C_en.pdf
Thank you for using FixYa!
Sep 19, 2011 | Cuisinart CBK-200 Bread Maker
Bread maker won't mix, it just clicks. I removed two screws on the bottom to see if the belt had slipped off. it was fine so I called Cuisinart to see if they could help. They said removing even one...
Some bread machines warm up before the kneading process begins especially on whole wheat cycles. If your machine hasn't started kneading after about 1/2 hour then you do have a problem but, give it time before you give up on it....
Aug 24, 2011 | Cuisinart CBK-200 Bread Maker
When the bread is finished baking, after I take the bread out, the machine starts to beep with HHH error, I pull the plug, then when I put the plug back in it shows the time, or menu. It won't shut...
Before you take the bread out push the "stop" button until it beeps in a couple of seconds. Then unplug the machine, then take the bread out last.
Apr 28, 2011 | Cuisinart CBK-200 Bread Maker
I bought my Cuisinart Bread Maker in February 2007 and it worked well until now. Yesterday I started to make Dough cycle. First 2 minutes machine kneaded the dough correctly as usual but suddenly...
check the underside of the basket. I have had problems with the lock washer, causing the wing nut to slip and not providing any turn to the shaft and paddle.
Sep 22, 2010 | Cuisinart CBK-200 Bread Maker
What does code HHH mean?
That's a troubleshooting code listed in the manual. It means something is broken and you should take it to a service center for repair.
Dec 06, 2009 | Cuisinart CBK-200 Bread Maker
Cuisinart cbk-200
In the troubleshooting section of the manual it says that HHH indicates the unit needs to be serviced. It's got a 3 year limited warranty, so they should be able to repair it under warranty.
Jan 19, 2008 | Cuisinart CBK-200 Bread Maker
Cuisinart CBK-200 Bread Maker Logo
1,250 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
