Question about Philips 60P8341 60" Rear Projection Television
No picture or sound
When I turn on my projection tv there is no picture or sound also the power light will start to blink and there is a faint beeping noise coming from the back of the tv. The modual no. is 50P8342
  • 1 more comment
  • lucite1 Nov 06, 2007
    no pitcher or sound when i turn on tv a quick glimps of pitcher when you tunr off set still no sound whats wrong and how do you fix this
  • kick77 Jan 29, 2009
    the power button jusr blinks and there is no picture or sound and also there is a faint sound comming from the back of the tv
  • sandra_gordy May 11, 2010
    Philips rear projection 50P8342, sound comes in and out. Sound will play sometimes for a few hours without any problems.
    New Friend:
No picture no sound
Posted on Jan 23, 2010
Sounds like the PTV Small Signal Board.
Posted on Aug 02, 2007
SOURCE:
I have a rear projection Mitsubishi VS-70803 and fixed it with the help of eagle338 it was working fine for a year and a half. So new issue is I was watching TV and all the sudden i hear a faint spark
The set MAY have the self check feature.
If the set is plugged in and you turn it on and a few seconds later the power light goes off:
On front of set press and hold both the menu and input (device on some) buttons at same time for at least 5 seconds and release both.
Power light should then blink a two digit error code like 2 blinks, 2 blinks a pause and repeat the error for a total of 5 times.
If you get an error code let me know what it is.
May 22, 2012 | Televison & Video
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
When TV is turned on, there is no picture but a very, very faint verticle haze in the middle of the screen. At first, the power switch lamp is green and blinks slowly, then at a faster pace. At the same...
Yes,it will resolved ur tv picture issues.This tv the projection lamp has not been replaced at least 1 1/2 or 2 years right?The tv on an in used at 4 or 5 hours a day right? The projection lamp life span are over.Sometimes the Ballast board have to be replaced too.This Ballat board it to help to ignite the projection lamp.
Jun 26, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Panasonic pt53wx42f
WHEN POWER IS FIRST TURNED ON I HAVE A SOLID RED LIGHT BUT NO PICTURE. THEN YOU HEAR THE TV CLICK OFF. THEN RED LIGHT STARTS TO BLINK IN SET OF (3) TIMES.
Jun 25, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
544 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
