What countries have code +68 - Computers & Internet
Job Error Code:68 (VinPower DIgital Unit)
Error Code 68
System error code 68 means "The name limit for the local computer network adapter card was exceeded." This error code may also display as "ERROR_TOO_MANY_NAMES" or as the value 0x44.
I don't know what this has to do with using lightscribe and burning the CD's but perhaps your running this over a network?
Good information here and his solution near the end of the article:
Fix Windows error The name limit for the local computer network adapter...
Hope this helps good luck!
Mar 11, 2014 | Vinpower Digital SharkCopier 1 to 12...
Turn signal relay
what year car,? what country. lighting varies by year, and country.
you need noise?
if your car has totally electronic blinker module, it can in fact
be silent. the Miracle of transistors.
is some countries, (unstated) this is illegal, soundless.
those are governed by DOT rules and regs.
btw all my cars are silent , except my VW 68 bug.
my old 91 Suzuki made noise but it was only 1/2 electronic.
Aug 10, 2013 | Suzuki Grand Vitara Cars & Trucks
I want a country code of pakistan
Pakistan country code: 92
International City Codes for calling Pakistan
Bannu 928 Barkhan 829 Hangu 925 Hyderabad 22 Islamabad 51 Jaffarabad 838 Jhelum 544 K. Abdullah 826 Karachi 21 Kohat 922 Lahore 42 Mansehra 997 Peshawar 91 Sibi 833 Tank 963 Abottabad 992 Attock 57 Awaran 856 Badin 297 Bahawalnagar 63 Bahawalpur 62 Bajaur Agency 942 Bhakkar 453 Bolan 832 Buner 939 Chagai 825 Chakwal 543 Chitral 943 D.I.Khan 966 Dadu 25 Dera Bugti 835 Dera Ghazi Khan 64 Dir (lower) 945 Dir (upper) 944 F.R. Lakki Marwat 969 Faisalabad 41 Ghotki 723 Gujranwala 55 Gujrat 53 Gwadar 86 Hafizabad 547 Haripur 995 Jacobabad 722 Jhal Magsi 837 Jhang 47 Kalat 844 Karak 927 Kasur 49 Kech 852 Khairpur 243 Khanewal 65 Kharan 847 Khushab 454 Khuzdar 848 Khyber Agency 924 Killa Saifullah 823 Kohistan 998 Kurram Agency 926 Larkana 74 Lasbela 853 Layyah 606 Lodhran 608 Loralai 824 Malakand 932 Mandi Bahauddin 546 Mardan 937 Mastung 843 Mianwali 459 Mirpur Khas 233 Multan 61 Musakhel 828 Muzaffargarh 66 Narowal 542 Naushero Feroze 242 Nawabshah 244 Nowshera 923 Okara 44 Pakpattan 457 Panjgur 855 Quetta 81 Rahim Yar Khan 68 Rajanpur 604 Sahiwal 40 Sanghar 235 Sargodha 48 Shangla 996 Sheikhupura 56 Shikarpur 726 Sialkot 52 South Waziristan 965 Sukkur 71 Swabi 938 Swat 946 Tharparkar 232 Thatta 298 Toba Tek Singh 46 Umerkot 238 Vehari 67 Zhob 822
May 22, 2012 | Cell Phones
Attachments for 140 activa
Do you mean a presser foot to sew rolled hem or shell hem edges?
If so, the Bernina website lists the accessories here:http://www.bernina.com.au/product_detail-n25-i61-sEN.html
Bernina feet 68 and 69 are rolled hem/shell, just different widths. However, I think the feet for the Activa are the new 3 digit numbered feet? I know there is the old style and new style attachment system for Bernina feet, if you look at the presser feet you got with the machine, they will have a code on the front of the foot; buy any new feet with same code format.
As to where to buy, I always start with the manufacturer/distributor in my country first. So start with www.bernina.com, go to your country, then "contact us" page and give the local office a call. They should be able to confirm the exact foot code you need and sell it to you or direct you to a local dealer who can.
Nov 14, 2011 | Bernina Activa 140
My 1993 Chevy came up with a code 68 O/D gear ratio errer after a hunting trip in some rough country.
Clear the code. Hopefully it wont come back on/ Inspect the connectors at trans for water intrusion or loose connection. Maybe a big bump wiggled something. It happens
Nov 12, 2009 | 1993 Chevrolet C3500
Links to schematic? and What does this solid capacitor equate to in value.. First line...68, second line ..35K? How do you read this? Is K tolerace? is 68pf or uf? or is it a code?
Hello:
The 68 represents the capacitance of the capacitor, if it says 68 uf this is microfarads if it says pf then its means 68 picofarads. The K represents the DC working voltage limit, Then K means thousands so the working voltage limit for this capacitor is 35 thousand Volts.
Please leave comment THX
Oct 08, 2009 | Televison & Video
I nees to setup Quintum A800 for termination can anyone help me
Command line for termination A800 (Quantum)
Config unit 1# online 1
Config sys# mindn 10
Config sys# maxdn 20
Config pstntg 1# pass 0
Config pstntg 1# cassig 6
Config pstntg 1# super 3
Config pstntg 1# lamp 1 country code (91)
Config pstntg 1# Answerdel 120
Config pstntg 1# lamp 1 9101 01
Config pstntg 1# dis 1 a (ALL - ports)
Config pstntg 1# ena 1 a (ALL – ports)
Config gkadmin allow 1# ip xxx.xxx.xxx.xxx (GW ip + switch-ip)
Config dsp# voice 81 (for g723) voice 68 for (G729)
Config# submit
Local information
Name of this zone Hello
Country selection Canada
Local country code country code (91)
International prefix country code (91)
Hop-off PBX Numbers
91 public
9101 01 public
This configuration for termenation
Nov 20, 2008 | Quintum Tenor A800 (501-0026-00)
System error 1 light code E 68
error 68 means that the xbox has insufficient power to operate. make sure it is directly plugged into the wall. try removing accessories on your xbox like intercoolers and USB devices.
Aug 24, 2008 | Microsoft Xbox 360 Console
Unlocking code for nokia 6300
Try to insert one of this codes:
#pw+ 19 51 54 51 13 33 15 2 +1#
#pw+ 72 52 70 04 53 74 07 7 +2#
#pw+ 71 68 60 53 64 60 76 3 +3#
#pw+ 10 58 54 62 43 50 35 7 +4#
#pw+ 94 33 42 16 41 75 14 4 +5#
#pw+ 40 55 57 72 03 37 15 4 +6#
#pw+ 14 39 34 46 01 21 63 0 +7#
REMEMBER YOU DO NOT ENTER WRONG CODE MORE THEN 5 TIMES.
PLEASE DO IT ON YOUR OWN RISK,
OR GO YOUR NEAREST NOKIA SERVICE CENTER.
ALL the best
May 27, 2008 | Nokia 6300 Cellular Phone
ERROR CODE 68 ON AFFINITY ATF7000EE
check tech sheet located inside washer cabinet at bottom. remove lower kick panel to access.
May 04, 2008 | Frigidaire Affinity ATF7000E Front Load...
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
