Logik 2.4ghz wireless keyboard
Model.:lm-wk1
Logik customer service
First, locate the battery compartment and change the battery. This solves most problems of this type. Does it have a USB dongle? to plug into a usb port? try changing the port
Sep 09, 2014 | Case Logic Wireless Multimedia Keyboard
I dont know how to connect my LOGIK LDSMWL11 mouse and keyboard, how do i do it?
Do you have an installation CD for that? Usually, it comes with the devices. You probably have a device that is connected to the computer, receiving the signal of the mouse or of the keyboard. That thing is connected directly by a USB Port or PS/2 port. Look carefully if you have that kind of thing (or device). And it is better if you connect that device when the computer is not ON. Then, turn ON the computer, see if it detects.
Nov 06, 2013 | Acer Wireless WIL-152 91.84R07.152...
Logik LKBWS10 driver
check for some cd in the box keyboard come. If you find some insert it and install the drivers from it
else you have to download the latest drivers from Logik website
you can google this " Logik LKBWS10 keyboard drivers " if having trouble finding the drivers
your keyboard might be working without the drivers but to get 100% of it you have to install the drivers
Jul 04, 2013 | Computers & Internet
Cannot open battery cover on logik wireless keyboard LK212R
Brute force I'm afraid. There is a hairline gap which makers say you might need a paperclip to open. I found fine bladed kitchen knife used carefully the only way to open mine.
Apr 12, 2013 | Logitech Cordless Mouse
Logik ldsmwl11 wireless keyboard wont connect
My LOGIKLDSMLW11 Wireless keyboard wont connect to my PC where as my mouse does connect. the light for the keyboard in the top right corner turns red and flashs but then goes off, but still it wont connect. I am running windows vista operating system, 32bits.ezeonusonny@aol.co.uk
Mar 05, 2012 | Logitech Computers & Internet
I have a logik wireless keyboard and mouse and the keyboard will not connect to the reciever, it worked yesterday but doesnt now, what can i do
1. Gr8. remove the wireless connector from what ever system you are using
2. ensure the dry cells or battery are in good shape and well inserted behind the keyboard
3. re-plug the wireless cable back in either the usb slot or mouse port which ever that applies in your case.
4. wait till the device is recognised and ensure the lights on the wireless connector is litted
5. now press the button behind your keyboard to connect with your receiver
6. vois la there you go all set and done.
7. in short go through the procedure for installing your wireless keyboard
hope this works for you
Aug 10, 2011 | Computers & Internet
When I turn on my Philips lx8500w dvd player my wireless internet stops working, what may be the problem?
the lx8500w uses the same frequency as the wireless (2,4Ghz). I bought the same system, it's ********. Just problems and after 2 years it doesn't work anymore (goes to standby after 1 hour or so). Try to change the wireless channel. Or buy another home cinema...
Mar 19, 2010 | Philips Home Cinema system DivX LX8500...
Panasonic KXTG2344 Phone 2,4ghz malfunction with microwave
You can change the channel used by the phone in the settings, but the better option is to make sure the charger base is nowhere near the microware.
Also, make sure that the microwave and the charger base are NOT plugged into the same outlet. I would even try a different outlet than you are using now as interference would definitely pass through the line.
Dec 02, 2009 | Panasonic KXTG2344 Cordless Phone
Driver lost
You can go to the store (like best buy or even shopo-ko maybe) and go to their computer section of the store then look in the computer gameing area and it should be in there... :)
Dec 27, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
