Question about Canon PIXMA MX310 All-In-One Printer
Scan is too light
When I scan documents, the scan is not dark enough. I've looked for adjustment features and have not found them.
  • Anonymous Feb 08, 2009
    Ssame problem, scans outputs are too light...
  • Anonymous Mar 01, 2009
    when I scan docs they are to lite to read/print.
5 Suggested Answers
Roshan89
  • 271 Answers
SOURCE: Scanner
Check the power and the data (USB) cables in the printer...check both ends...
Check :-
# The printer powers on properly
# There also can be problems with the printer driver
# and also internal printers....
Try reinstalling the printer driver...
<PLEASE RATE ME AS FIXYA>for my help......................
Posted on Jul 31, 2008
SOURCE: MX310 Scanning feature
Hi have you tried selecting print through file menu as this gives you the option of changing the resolution by going to properties and selecting best photo. Hope this helps,
Posted on Sep 28, 2008
TomSolomon
  • 50 Answers
SOURCE: My scanner scans, but the scanned document looks
It's a probably a setting that's adjusted way too high. Look for the brightness setting.
Hope I helped,
Tom
Posted on Jun 21, 2009
Sovi
  • 218 Answers
SOURCE: Does not print dark enough to read. Changed toner
Steps . The first troubleshooting step an owner can take is to make sure that the plastic protective tape on the new black cartridge is off.
Next,calibrate the HP printer. One thing to remember is that every time there is a need for a new printer cartridge, calibration is one of the steps to perform right after loading. You can run "Self Test Diagnostic," as well as, "Print Cartridge Alignment" in order to get the black ink to work.
You can also try cleaning the black ink cartridge. Remove the blank ink cartridge from the HP printer; use a cotton swab to clean the laser or scanner block. Wipe away dirt, grime or any dried ink that may prevent ink from flowing. You can also try cleaning the printer heads.
  • If you are having issues on an HP Laserjet printer, go to the menu, click "Diagnostics," then print the "PQ Troubleshooting Pages." If black ink does not print, go to "Disable the Cartridge" and switch the magenta and black cartridges on the menu. Then, print the pages again. If black ink does not print, then the problem may be the toner cartridge.
    At times, when black ink does not print, it can signify a problem with a printer's laser. The owner of a HP printer may see an error on the LCD screen, indicating that there is a problem with the laser assembly.
    Another problem could be the wiring connection at the laser or scanner; check if the plugs are loose. Contact HP Support for further assistance.
  • Posted on Feb 15, 2011
    Screen dims when lights in room are off
    Look in the owner manual or call LG (brand listed here) as I suspect the set has a light sensor that tries to adjust brightness as light in the room changes----this feature has been on many sets for nearly 50 years---on a lot of the very old ones we would remove that part as it just created issues.
    May 01, 2012 | LG Televison & Video
    Scanned documents appear too light (faint). is there an adjustable feature to darken the tone of a scanned document?
    The scanner reader is probably bad. Canon calls it a Contact Image Sensor FK2-1377-00
    This is moderately hard to install because it is under the glass.
    Whit www.iteminconline.com
    Sep 15, 2011 | Canon imageCLASS MF6550 All-In-One Laser...
    HP Deskjet f4435 will print, but won't scan. Orange light blinks
    When I press the scanner button the top power button starts blinking but the machine does not scan. I have not used the scanning function on this machine before. Please help...you may need to reinstall your ..
    Aug 16, 2011 | HP DeskJet F380 All-In-One Printer
    Need instructions on how to send fax, it seem as though we are not following the correct steps
    Solution: Sending faxes on an MX310
    Sending Faxes
    The operation flow of sending faxes is as follows.
    1. Load the original on the platen glass or on the Automatic Document Feeder (ADF).
      Platen Glass
      1. Lift the document cover (1).
      2. Place the original in landscape orientation and align the upper corner of it with the alignment mark (2) as shown in the figure below.
      3. Gently close the document cover.
    ADF
    1. Remove any documents from the Platen Glass.
    2. Open the Document Tray.
    3. Load the document in the ADF.
      Load the document with the side you want to copy, scan, or fax facing up in the ADF.
    4. Adjust the Document Guides to match the document width.
    1. Press the button.
    2. Adjust fax settings as necessary.
    3. Start faxing.
      1. Dial the recipient's number using the numeric buttons or coded speed dialing.
      2. Press the button for color sending, or the button for black & white sending.
        Note: Color sending is available only when the recipient's fax machine supports color faxing.
      3. If the document was loaded on the Platen Glass, the following message will appear. Load the next page on the Platen Glass.
      4. If you have only one page of document to scan, go to step 5.
      5. Press the same button as you pressed in step 4b.
      6. Repeat steps 4c through 4e until all pages of the document have been scanned in and then go to step 5.
    4. Press the button.
    5. To cancel sending a fax, press the button. To cancel sending a fax while it is being sent, press the button, then follow the instructions on the LCD.
    Adjusting the Scan Contrast or the Image Quality (Fax Resolution)
    Contrast is the degree of difference between light and dark. Increasing the scan contrast setting further blackens dark areas and whitens bright areas, whereas decreasing the contrast setting reduces the difference between bright and dark areas. You can adjust the contrast among three contrast levels.
    2. Press the button.
    3. Press the (left) or (right) button to select the contrast.
    4. Pressing the l_mark.jpg (left) button decreases the contrast, and pressing the r_mark.jpg (right) button increases the contrast.
    5. Press the button.
    Adjusting the Image Quality (Fax Resolution)
    You can adjust the image quality (fax resolution) of the document you send. The higher you set the image quality setting, the better the output quality will be at the other end, but the longer it will take for the transmission. Adjust the image quality according to the type of document you are sending.
    2. Press the button two times.
    3. Press the l_mark.jpg (left) or r_mark.jpg (right) button to select the resolution.
    STANDARD:
    Suitable for text-only documents.
    FINE:
    Suitable for fine-print documents.
    PHOTO:
    Suitable for photographs.
    Return to Start Faxing
    Back to the Top of the document
    Dialing the Coded Speed Dial
    2. Press the numeric buttons to enter the two-digit code (00 - 19) assigned to the number you want to dial.
    3. Press the button for color sending, or the button for black & white sending.
      Note:
      * To cancel sending a fax, press the Stop/Reset button. To cancel sending a fax while it is being sent, press the Stop/Reset button, then follow the instructions on the LCD.
    Feb 04, 2011 | Canon PIXMA MX310 All-In-One Printer
    Zebra Z4MPlus not printing dark enough
    In your label software there should be a setting option for print darkness (I assume it adjusts the head temperature) In ours (bartender) you can get to it when you select 'print' and a window appears with a 'documents properties' button. Click on this and select options and a darkness bar appears which you can adjust. You may also need to slow the label print speed if the darkness adjustment is not enough. I suspect it isn't in the printers best interest to run the print head at maximum darkness/heat so a sensible balance of darkness and print speed is best.
    Another, less likely, possibility is an incompatability between the label material or surface finish, and the ribbon type. We did have a problem once whem Homebase changed their price label design and we had to test a load of other ribbon types until we got one that did the job. A chat with the label or ribbon supplier is always usefull, they sent us several sample bits to test.
    Sep 30, 2009 | Zebra Z4Mplus Label Printer
    Our hp 9250c scanner suddenly scans very light
    Reset the Darkness and use the setting to adjust the lightness or darkness of the output. Check the setting on the scan application as well as the 9250C.
    Also check the document type and resolution settings.
    If there is nothing strange about any of the settings then run the Calibrate Scanner function. If that does not cure the problem then you may have an issue with the quality of the lamp output or the scan detector and will need a service engineer to visit and rectify.
    Sep 25, 2009 | HP Digital Sender 9250c scanner Printer
    Ink tone
    Hi Pam -
    This is a common problem with the CX 5000 - there is no contrast control (i.e., light/dark) like you would have on a photocopier. But if you use the scanning mode (EpsonScan) instead of the copying mode, there are a couple of alternative options that might help:
    1) Brightness - in the EpsonScan program, in Home Mode, under Image Adjustments, there is a button labelled "Brightness." Depending on the colors and contrast of what you're copying, adjusting the brightness may help.
    2) Color Restoration - In both Home Mode and Professional Mode, this feature is meant to restore the color to a faded photo - depending on the colors of your document, it may make the copy lighter or darker, but it's an option.
    Hope this helps!
    Dec 11, 2008 | Epson Stylus CX5000 InkJet Photo Printer
    I HAVE A PANASONIC FAX kx-FPG376 IT WONT SEND FAX MAKES COPIES AND RECIEVES FAXES
    I dont know how we got disconnected but here is the instructions
    Adjust the width of the document guides (1)
    to fit the actual size of the document.
    2 Insert the document (up to 10 pages) FACE
    DOWN (2) until a single beep is heard and
    the unit grasps the document.
    L If the document guides are not adjusted
    to fit the document, re-adjust them.
    3 If necessary, press {A} or {B} repeatedly to
    select the desired resolution.
    4 Press {DIGITAL SP-PHONE}.
    5 Dial the fax number.
    6 When a fax tone is heard:
    Press {FAX/START}.
    When the other party answers your call:
    Ask them to press their start button. When
    the fax tone is heard, press {FAX/START
    To redial the last number
    1. Press {REDIAL/PAUSE}.
    2. Press {SET}.
    L If the line is busy, the unit will automatically
    redial the number up to 2 times.
    L To cancel redialing, press {STOP}.
    To send more than 10 pages at a time
    Insert the first 10 pages of the document. Add
    the other pages (up to 10 at a time) before the
    last page feeds into the unit.
    Pre-dialing a fax number
    You can dial the fax number first before inserting
    the document. This is convenient if you need to
    refer to the document for the other party’s fax
    number.
    1. Enter the fax number.
    2. Insert the document.
    3. Press {FAX/START}.
    Sending from memory (Quick scan feature)
    You can scan the document into memory before
    sending it. To use this feature, activate feature
    #34 (page 62).
    1. Insert the document.
    2. Enter the fax number.
    L The document will be fed into the unit and
    scanned into memory. The unit will then
    transmit the data. If the document exceeds
    the memory capacity, transmission will be
    canceled and this feature will be turned OFF
    automatically. You must transmit the entire
    document manually.
    L This feature cannot be used if {DIGITAL SPPHONE},
    {TALK} or {SP-PHONE} is
    pressed.
    To stop transmission
    Press {STOP}.
    Aug 27, 2008 | Panasonic Office Equipment & Supplies
    Faint image on scans
    REPLACE IN THIS ORDER.
    CABEL(CHEAPEST)
    IF THAT DOES NOT WORK
    IT NEEDS A FORMATTER BOARD.
    Jun 11, 2008 | HP LaserJet 3055 All-In-One Printer
    V-scan voltage adjustment
    If you adjust v-scan make sure you adjust it for the setting that is marked on the panel when you take the back off. Why do you want to adjust v-scan? are you noticing red pixels firing or green ones? This is a diffusion problem and i am familiar with the fix for that. Let me know and we can go from there. Also what is the version of the HP-R5052? Talk to you soon . Thank you Jay
    Jan 11, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
    Canon PIXMA MX310 All-In-One Printer Logo
    561 people viewed this question
    old marine
    old marine
