Question about Pioneer AVH-P1400DVD
I have a 2002 acura rsx, i connected the wires like shown it gets power just not sound, the unit itself makes little beeps but thats it
Clutch replaced on my 2002 Acura RSX type S. Engine light . codes::Left front wheel speed sensor; Rear right outlet Solenoid sensor mlf:;Low Voltage Knock Sensor.Engine turnover probs afterrefueling
left front wheel speed sensor is more then likely due, to a malfunction sensor for the abs sensor, badly connected sensor, or wiring, or contacts corroded or damaged, the knock sensor is usualy do to a fault sensor at the crank shaft where the timing belt is due, this is also more then likely to your engine turnover problems and is just coincidence when refueiling
Jan 28, 2017 | 2002 Acura RSX
Starter engages slightly on my 2002 acura rsx but wont start car. battery is fully charged
Get a long shank screw driver and place it on the starter. While a friend attempts to start the car, tap the handle of the screw driver with a ball pin hammer. Sounds like the pin is catching upon deployment. Eventually your going to need to replace the solenoid and the starter.
Sep 03, 2013 | 2002 Acura RSX
Rsx wont start
starter moter jammed,give it a knock.
Aug 17, 2012 | 2002 Acura RSX
I cannot find the radio code for my 2002 acura rsx type s. the serial# is L1000 U2802
First have a look at this video which shows the common places where you may find the code tag hidden in the vehicle itself.
If the code is not found inside the car at any of the locations mentioned in the video, there is a site here that says it can provide the code from the cars VIN number, as long as your details tally with the ownership database.
Hope this helps. Thanks for using FixYa.
Aug 16, 2010 | 2002 Acura RSX
Back Hatch/Window of 2002 Acura RSX
It sounds like they didn't get all of the glass out of the hatch. There are "pockets" of space inside the hatch frame area. They may not have removed or cleared all the glass out from the inside. This may involve removing the hatch from the car and dumping it out. Not impossible, but very impractical.
Jul 28, 2010 | 2002 Acura RSX
2002 Acura RSX low beam headlights dont work. All fuses are good. High beams work.
The same thing happended to my Acura RSX and now they are saying that it is an electrical problem. I put new bulbs and both of them are fused
Jan 15, 2010 | 2002 Acura RSX
2002 rsx hatchback wont open
Didn't know the hatchback has key hole. mine don't. Anyways. climb in it from the inside and see if you can manually unlock the hatch. It's a little white knob at the latch that moves from side to side...lock/unlock. good luck
Apr 03, 2009 | 2002 Acura RSX
Location of impact sensors RSX 2002
This is Going to be a Small Square Box Looking unie Located In the Grill
Feb 04, 2009 | 2002 Acura RSX
How to install kenwood kac-9102d in 2006 acura rsx
My recommendation is to get a line level converter. Go to a car audio shop or even best buy and specifically ask for a line level converter. It will have speaker wires in and RCAs out. Connect the speaker wires to the sub woofer speaker wires and then you will have the RCAs to run to your amp. I hope this helped.
-Andrew Hawkins
Aug 24, 2008 | Kenwood Car Audio & Video
Pioneer AVH-P1400DVD Logo
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
