Question about Dewalt Heavy Duty XRP 1/2" 14.4v cordless hammerdrill/drill/driver kit - DC984KA
Dc984ka broken switch transistor/(trystor) N527AB where I can found or to replace with another possible number to use?Thanks
2 Suggested Answers
  • 313 Answers
SOURCE: speed control transistor
if ur drill is DW988 use switch # 152274-19
if ur drill is DC925 use switch # 152274-25
see www.ereplacementparts.com for parts & diagram
Posted on Jul 26, 2008
RCA MOD# 20-f-514-TD Chassis#ATC-116 SER#1054e6j09 c231 Will not power-on. There is a led red light blinks and makes a audio noise every time the light blinks
Hello
Either your RCA tvs LOT [Line Output Transformer] or its drive transistor [horizontal output transistor is faulty. First replace the Horizontal Output Transistor. It can be located very near to the LOT said above, be screwed onto a metal heat sink to radiate heat away from it while it works. It is a three terminal device, black in colour. Unscrew and desolder it out of the printed circuit board and check whether it has caloctor to emitter or collector to base leak . If it found leaky there is a possiblity of LOT damage. Anyway replace the said transitor first. After replacing, switch on the set for a short period of time, say 3 or 4 seconds only, unplug it from the power socket, and feel the heat effect of the replaced transistor. It may get warm, but not too hot. If it heats up abnormally, surely the LOT said about is faulty, and should be replaced with same type and number.
When selecting LOT, insist on orginal replacement, as substitutions will detereate the picture quality and its life time. If you wants further assistance, feel free to get me through Fixya. OK.
Dec 30, 2010 | RCA Televison & Video
I have an RCA TV 35 Inch Model # 35V432T, the fly-back and high voltage transistor went out. I need the part #'s for them and where I can go on line to buy the parts. Thanks in advance for your help.
G'day mate,
I have the exact information that you need. You do not need a service manual to find the part number.
Horizontal output transistor is an S2055n....RCA P/N #230760 found here
Flyback assly RCA P/N #262342 found here Make sure you work safe with electricity... be sure to disconnect from the supply,and discharge the tube before removing the HV cap. If you have any problems,just let me know. Please rate the advice I have given to you here. Cheers. Good luck with the repairs. regards robotek
Jun 23, 2010 | RCA 35V432T 35" TV
SONY KP-61V90 tv will not power on, red light in front,
Its 2 times blink error code that shows +B volt supply (+135 volts) is shorted, most probably horizontal output transistor is shorted, replace it.
If you are good in soldering parts in circuit board then take out horizontal transistor, check it, found shorted then replace it with same number.
Horizontal output Transistor Q502 number is 2SD2578 and available in Part Store for $10
Let me know for further query, if any.
Thanks.
Nov 18, 2009 | Sony Televison & Video
Switch problem
The switch number you have is correct, unfortuatly you will have to replace the whole switch. There are no individual parts.
Apr 29, 2009 | Drills
Denon AVC-A1SE in protection mode
The numbers of the transistors thay you need to replaced are on the transistor themselfs. Just take out the bad transistors and get the numbers that you need. I ALWAYS replace the output, driver and bias control transistor myself. One thing to keep in mind, if the number on the transistor starts with "A or B or C or D or K" you need to add "2S" in front of that number when you order it. Now that this problem has repeated itself, double check your wire and speaker. They can cause this problem.
Nov 09, 2008 | Audio Players & Recorders
Power acoustik gothic ov2-1600
What are the circuit board designations (Q111, Q112, Q211, Q212...) for the parts you replaced?
Did you replace the defective parts with identical transistors?
Which transistors are heating up?
Nov 07, 2008 | Power Acoustik GOTHIC OV2-1200 Car Audio...
Sharp TV 21" screen with a switch mode power supply.
i have a tv receiver with a problem of no power going to the whole system thiis transistor c3807 and connected to bigger transistor c4458 are gone together with connecting diodes.any solution please?
Sep 19, 2008 | Televison & Video
Speed control transistor
Jul 22, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
BROKEN LCD... BURNED TRANSISTOR
better bring it to the toshiba service center
Apr 10, 2008 | Toshiba Satellite M105 Notebook
Need part #
Can you read the letters and numbers on the transistor your needing to replace? If so post the numbers and I will post a link where you can order them or their substitue.
Nov 14, 2007 | Samsung HCL4715W 47" Rear Projection...
Dewalt Heavy Duty XRP 1/2"  14.4v cordless hammerdrill/drill/driver kit - DC984KA Logo
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
