Question about Freezers
Scandilux Freezer spare parts
Seal for lid
Looking for a replacement seal measures 1040mm x 600mm
probably the best idea is to contact a local fridge/ freezer person that replaces seals on the doors of fridges and freezers (yellow pages for a start-fridge repairers)
they have an assortment of seal profiles on board and they make the seal to suit the door on site
The cost is about 75% of new price
ask the service agent spares for a seal, because although the freezer may be old , seals didn't change all that much and you may still get a seal from them
From the size I am guessing that it is a chest freezer probably an electrolux/email product and you may be lucky if it is
Mar 31, 2016 | Freezers
Ice on the inside walls of chest freezer
Check the seal around the lid sits firmly on the rim, give it a good defrost before restocking. Make sure all else is working and clean, particularly any condenser grilles / fans.
Mar 23, 2014 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Kenmore upright freezer
order a new seal at the link I provided or ebay or your choice
also check the lid or door adjustmens and obtain specific help instructions at the link I provided
Appliance Repair Help Troubleshooting and Appliance Parts
Apr 08, 2017 | Kenmore Freezers
HOW TO FIX FREEZER SEAL
Check spares at www.TalkAppliance.co.uk the old one should just pull of and new one replace easy.
ThanksTalkAppliance.co.uk
Apr 15, 2012 | GE 16.7 cu. ft. General Electric Upright...
We just bought a chest freezer and the suction is so tight can't open the lid .What do we need to do.
Most likely it isn't the suction but moisture on your seal freezing to the frame. Suggest a putty knife with a hair dryer blowing hot air on the blade and working it around the seal.
Aug 03, 2011 | Frigidaire 5 cu. ft. / 142 liter Chest...
Our freezer lid doesn't seal tightly in the front right corner. Is there a fix?
CALL Chas&Son,s at 570-379-0993 and they will come out the same day no less okay
Jun 24, 2011 | Whirlpool 10 cu. ft. Chest Freezer...
Water coming out of the lid of a Kenmore 5 cu. Freezer
Funny. We just spent an hour trying to figure out the same problem with our Kenmore. It is the third or fourth time that we've noticed water on the floor under the freezer, but the first time that we've been able to track it to the lid.
The only thing that makes sens to me is that this problem may be happening when our freezer has a frost buildup around the top of the unit which doesn't allow the lid to close perfectly snug. I'm thinking that this causes a bit of melt in whatever frost may be inside the lid from regular air circulation around the unit. It runs out the back of the lid when it opens.
Check that there is no frost around the rim of the freezer that may be causing a slight (it only takes a very small opening to allow warmer air to circulate under the lid) irregularity in the lid seal.
Jul 06, 2010 | Freezers
Condensation forms around the freezer opening, between the rim and the seal.
The lid is warped or the seal is bad and leaking air.
Determine which it is and replace the seal or the lid.
Jun 27, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
Ice crystals forming on inside front freezer panel
Very possible the door seal is not properly sealed. Warm inflowing air onto a cold coil will cause ice build up at the lid.
Oct 08, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Chest freezer ices up quicker than it should
if the box has mold between the seal and liner the the seal isn't the main problem, the main problem is the liner is bad and by time you got both parts if you can it would cost more than to replace the freezer.
Larry
Nov 25, 2008 | GE 5 cu. ft. / 142 liter Chest Freezer...
Freezers Logo
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
