Question about LG WM2487H Front Load Washer
LG Tromm Washer
I do not know where to start but I am glad I'm not the only person with this problem. I am absolutely sick over my purchase of the LG Tromm in Aug. 08. (Previously we owned Maytag set top loads for 23 years and it is still in use in our kennel for washing dog towels). I go way out on a limb and pay over $2,000 for this new LG Tromm Steam set and for the 1st 2 months it was great. Then I started noticing that smell which was absolutely horrible especially in my towels right after they finished washing. (I don't leave my laundry, when it finishes I remove it). That smell is like what comes from a sewer, in fact it smells like sewer gas. In my freshly washed clothes, I noticed colognes and perfumes didn't wash out. I had a pair of brown slacks that had been worn only once and after washing they had oil or grease spots that I have no idea where it came from. Now I'm having a wobbling in my tub that I can't get to stop. It has been going on for 2 months now. I thought it was out of balance and attempted to set it while spinning as the manual says, but my level says it's dead level. I don't know what to do other than attempt to get Sears to take it back. I've had it 5 months so I don't think they will take it back. I have read my manual from front to back and several times and have done what the manual tells you to do. I've cleaned this machine with the bleach, draining the drain hoses, leaving the door open, used the HE detergents and the exact amount they say to use, etc. I've adjusted this with the wrench provided while spinning to correct the out of balance or wobble. I still have the wobbling tub, the stinch in all my clothes, and another problem developing is where you load your detergent, it always is half full of water after the load finishes. Now I'm having to empty the detergent tray before I can put more detergent in for another wash. I am just sick over this purchase. I am sick that Consumer Products rated this machine #1 the last two years. We rely on Consumer Reports for their product rating and I think they should write an apology to their consumers for reading their garbage. With all the extra maintainence, extra cleaning time, etc. how can this product be more efficient and cost less? If anyone knows something to do please tell me at AnnieOakley19594@yahoo.com, please! I'm wondering what everyone else plans to do with this issue.
  • aoakley Jan 31, 2009
    I made a mistake in my email address. How do I change it?
I joined the class-action lawsuit against these people.
Thanks!
annieoakley
Posted on Jan 30, 2009
We also got ripped off by LG. Tell all not to buy anything LG!
Andy and Nancy from N.Y.
Posted on Nov 12, 2009
I have the same machine and wonder if your machine is level front to back, not just side to side. Ours in in a porch and there are no level floors anywhere in this old house! If the machine is tilted just a little toward the door side the soap would not be level in the dispenser and there would be residue in some nooks and crannies that would otherwise spin clean. If it is possible, check with a level front to back and see what your can do to level it. We had an extra layer of plywood screwed onto this porch floor to help keep it steady, it takes off like a 747 in the spin cycle. Now they admit it should be on a concrete floor not a wood one, but we can't do that in our house. best of luck.
Posted on Feb 08, 2009
The start button on my lg tromm washer does not work
The plastic piece that you push may be broken or the switch that it pushes may be broke. Sometimes you have to hold the start button for a few seconds before the actual start will take place.
Feb 19, 2015 | LG Tromm Front Load Washer And Dryer Set
Lg tromm washer leaks from detergent drawer
my washer also was leaking from the dispenser and I had a cap from one of the detergent bottles stuck in the inlet hose. Don't know how it got in there but glad I found it so if your washer leaks from the soap tray it could be a cap from your detergent bottle stuck in there.
Nov 04, 2012 | LG WM2688H Front Load Washer
LG washer retaining ring problem
Get a second person to help you. Just slowly start at the top. Have your hands go down each side tucking it in and have your friend prevent it from coming out. I know it's a pain but it can be down. That tool is a life saver.
Dec 12, 2009 | LG WM-1832C Front Load Washer
Smelly Clothes...yuck!
Well, hope you avoid a lawsuit.
Putting the machine in perspecive....It uses water, soap, movement, and drains.
So, you start at the source water, and GUARANTEE that it is clean and pure (same as all other sources in your home) No cheating, take it off and run water into a 5 gal bucket, EACH hose.
Then, witness the drain volume, Pull the hose and observe while draining. the most likely issue is water is restricted from exiting the machine by some foreign material...
Typically, the machine would not loose efficiency without something being broken....
Sep 20, 2009 | LG WM2688HWM TROMM SteamWasher
Lg Tromm Steam Washer
if not, just put some pool shock in the unit..I use the sulfate based and add a tesspoon with my clothes.. our towns used to smell moldy.. this stopped all..
Oct 20, 2008 | LG WM2688HWM TROMM SteamWasher
TROMM ultra capacity washer water levels
these machines are mean on water and you can open the door after wash starts
use good quality soap powder that suits front loaders and always wash at 40 deg or above
the black stuff is body fat that is still in machine called scud to me
also if you use conditioner in rinse cycle stop using that
it can cause same problem
Jan 28, 2008 | LG WM-1832C Front Load Washer
LG WM2487H Front Load Washer Logo
1,168 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
