I got this error c-0211 on olivetti d-colour mf45
Olivetti copia 9017 RESET ERROR E0000
Olivetti copia 9017 haw to RESET ERROR E220
Jan 09, 2014 | Office Equipment & Supplies
Epson stylus photo rx510
how do i reset error c6400 for olivetti d-copia 18
Sep 03, 2013 | Office Equipment & Supplies
Olivetti d-copia 16w error code H4
I need driver olivetti_d_copia_16w for winXp....
Sep 25, 2012 | Olivetti Office Equipment & Supplies
Hi I have a problem with the printer Olivetti 300- the error number is C2250- is there anything i can do to fix it?Sylwia
This error is for network connection outage. You may check the network/data cable connection to the printer.
Nov 22, 2010 | Olivetti Office Equipment & Supplies
Compaq presario v5000 keyboard error 0211
I think that possibly the keyboard isn't completely plugged in. Several things to try.
1] re-seat the keboard
2] swap keyboards with a 'known' good one [swa[ back is ok as well]
These 2actions should narrow done the issue, I have gotten replacement keyboards at re-sale for $3.00
Jan 08, 2009 | Compaq Presario 5000 PC Desktop
Olivetti ecr 350 cash register problem starting up
There is an ECR350 manual here that might help:
All of these manuals can be downloaded at:
http://the-checkout-tech.com/
olivetti CMS-140B User Programming
olivetti ECR-2100 User
olivetti ECR-2150 User
olivetti ECR-2200 User
olivetti ECR-2250 User
olivetti ECR-2300 User Programming
olivetti ECR-2350 User Programming
olivetti ECR-2400 User Programming
olivetti ECR-2450 User Programming
olivetti ECR-2500 User Programming
olivetti ECR-2550 User Programming
olivetti ECR-300 User Programming
olivetti ECR-350 User Programming
olivetti ECR-3550T
olivetti ECR-5000 User Programming
olivetti ECR-5100 User Programming
olivetti ECR-5700 User Programming
olivetti ECR-5800 User Programming
olivetti ECR-5900 User Programming
olivetti ECR-5920F User Programming
olivetti ECR-6100 User Programming
olivetti ECR-6700 User Programming
olivetti ECR-6800 User Programming
olivetti ECR-6900 User Programming
olivetti ECR-6920F User Programming
Jun 20, 2008 | Olivetti Office Equipment & Supplies
Malfunction Detected Error c-0211
C0211 Manual Tray Rise Descent Error
• The Bypass Lift-Up Sensor is not blocked even when the Tray 2 Vertical Transport Motor has turned for a given number of pulses after the sequence to move the Paper Lifting Plate from the standby position to the feed position was started.
• The Bypass Lift-Up Sensor is not unblocked even when the Tray 2 Vertical Transport Motor has turned for a given number of pulses after the sequence to move the Paper Lifting Plate from the feed position to the standby position was started.
This is a rank B error. To reset follow these steps:
Open and close the front door.
If error recurrs check the manual bypass again or call for service.
Dec 04, 2007 | Konica Minolta bizhub C250 All-In-One...
jasbo
jasbo
